Removing fender grommets without breaking them
Discussion in 'General Tundra Discussion' started by treihing, Jun 22, 2017.
  1. Jun 22, 2017 at 9:41 AM
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    2018 Black Limited CrewMax
    I am sure this post has been covered a million times over the years but I cannot locate a thing when Searching.
    I am replacing my headlights and want to know how to remove the Fender Grommets without breaking them. I know they can be purchased on ebay and other stores but I would rather just get the ones I have out in one piece without ruining them.
    Thoughts?
    TR
  2. Jun 22, 2017 at 9:42 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Eh? Are you talking about the plastic trim piece below the headlight? Or something with the grill?
  3. Jun 22, 2017 at 9:44 AM
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    The trim pieces to get access to the headlights :)
  4. Jun 22, 2017 at 9:45 AM
    T-Rex266 Moderator Staff Member
    Just pull
  5. Jun 22, 2017 at 9:46 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    You have to take your front grill off first. Then there are two little christmas tree push grommets in the front to pull out. Then just slowly pry the other side off. There are no screws.
  6. Jun 22, 2017 at 9:48 AM
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    Sorry, I did not describe them correctly. These are the plastic push pin/grommets that holdsthe fender liner together to access the headlight bulb, not the actual headlight.
  7. Jun 22, 2017 at 9:51 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
  8. Jun 22, 2017 at 9:53 AM
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    This is the clip that I want to remove
  9. Jun 22, 2017 at 9:55 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Where is that. zoom out and take a photo
  10. Jun 22, 2017 at 9:58 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    2015 Platinum Super White Crewmax 4X4
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Looks like its already missing the push pin part of the fastener. The center pin and top appear to be broken off.
  11. Jun 22, 2017 at 10:04 AM
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    Everyone of them on my truck looks like that. I checked online and that appears to be the way they came.
  12. Jun 22, 2017 at 10:25 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    JohnLakeman and MistrRoboto like this.
  13. Jun 22, 2017 at 10:44 AM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    Sorry these are not quite what I thought
  14. Jun 22, 2017 at 7:24 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    That particular push-in connector is designed as a one way, and will get pretty much destroyed when removing. They make aftermarket connectors, but I would get the OEM from the local dealer. About 50 cents each. Just my real world experience.
    CaptSpaulding and NewImprovedRon like this.
  15. Mar 23, 2019 at 8:09 AM
    Chaton602
    Chaton602 New Member
    Anthony
    2018 Tundra
    Leveled larger tires on 18's (more rubber for the road and trails) and rock lights. Adding more soon.
    20190323_075006.jpg 20190323_075123.jpg 20190323_074945.jpg If you're trying to remove these with the trim kit tools you're on the right track. Just know that the fork of the tool has to massage the whole clip to push in the popouts of the retaining clip. Here are some pics. Once you get one side of the clips popouts pushed in, apply a little pulling pressure and it'll begin to come out. The photos might not be in the correct order, this is my first post so I'm still getting used this. I hope this helps.
    One more thing, these clips act as a thread point for the screws that hold on various parts on the truck including the mudflaps.
  16. Apr 26, 2024 at 10:26 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    Used a set of better trim tools and it worked! Thank you for these tips!
