General Supercharger Thread.
  1. Apr 25, 2024 at 7:46 PM
    TurboKits.com
    TurboKits.com New Member
    MAF Sensor Update - UPS changed the delivery date to Monday, but they are in transit (no these are no overseas cheapo knock offs). These are from Michigan! Anyway, as long as they come in early enough Monday, we should be able to turn all order shipments around same day. Thanks again!
    Fastlane47, Wynnded and snivilous[OP] like this.
  2. Apr 25, 2024 at 7:50 PM
    TurboKits.com
    Yeah buddy!
    Fastlane47, e30cabrio[QUOTED] and Mdl like this.
  3. Apr 25, 2024 at 9:25 PM
    TurboKits.com
    We figured no one would mind, as everyone loves videos!!! But if anyone wants this removed, just ask!
    Just dumped a bunch of videos on our YouTube channel. Here they are as well.
    Our Channel - https://www.youtube.com/channel/UCSPo3Lfg5o3Vi46mWA58N0A
    Install, Rev and Drive T51R Mod on the 2014
    2014 Stage 1 DYNO Run
    2019 Stage 1 DYNO Run
    2019 In Cab Drive
    2021 Stage 1 DYNO Run
    2021 Stage 1 DYNO Run *Open Dump
    Quick Drive in the 2021
    Messing with the 2008 and the intercooler on the DYNO, no numbers and this is from over a year ago, but another one in the stable running turbo. This is a 2008 with 230K
    2008 Offroad Mudding Fun w- Boost
    https://youtube.com/shorts/CSEKST1zK8U?feature=share
    Something else fun we are working on!
  4. Apr 25, 2024 at 11:23 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    No complaints here!
    TurboKits.com likes this.
  5. Apr 26, 2024 at 2:49 AM
    koditten
    koditten New Member
    Ditto!
  6. Apr 26, 2024 at 7:59 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.2 SC pulley, ASP crank overdrive pulley, DD Full 3inch dual exhaust, Airbox mod, 4.5 intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, DIY Traction Bars, Tuning by snivspeedshop.com
    @e30cabrio when you first ran the walbro 450 did you have the vsv relay grounded to give the high psi voltage to it? Just trying to help the guy in running lean thread.
    ARES35 likes this.
  7. Apr 26, 2024 at 8:07 PM
    e30cabrio
    Yup, all the mods were done because it "needed" more powa.
    The pumps were the problem.
    ARES35 and Mdl like this.
  8. Apr 26, 2024 at 8:28 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks. If testing doesn't pan out. I recommended the deatsworks dw300.
    e30cabrio[QUOTED] likes this.
  9. Apr 26, 2024 at 10:27 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra Cement DC
    Just logged using the HP Tuners VCM for the first time (thanks to Sniv). Was interesting to see for my near sea level 725 injectors with a Walbro 450 just barely get to 99% usage right at 6000/6200rpm, and the Maf gets almost to 100% right at that point as well. (Magnuson 1900, 2.3", Longtubes/3" exhaust, RCF TB, OV Magnuson 2021 tune). Likely will get alot better after a real tune!
  10. Apr 27, 2024 at 12:06 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    There's nothing like getting it dialed in! @snivilous will get it going. It was like driving a different truck. A bonus is he will help you understand the tuning too.
    ARES35, reywcms, e30cabrio and 3 others like this.
  11. Apr 27, 2024 at 11:04 AM
    e30cabrio
    Off topic but if you can move fast you better be able to stop.
    Brakes were new when I bought the Tree, (unbeknownst to me) I bought new brakes before I got it. I have had worsening shudder on the freeway so figured the rotors were warped & just installed them.
    New pad on the right, I put 25k miles on them, kinda shocking how much is left.
  12. Apr 27, 2024 at 11:11 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    So the SC is in. Have a few questions?
    First is the fuel pump. Is it supposed to look identical? The OEM was a Denso, the Magnuson pump was also Denso. No way to tell them apart other than some different numbers on the pump. I am sure I am over thinking it and should know better that Magnuson will put the correct pump.
    Second is, can I turn the truck on, on the stock tune just to check for leaks and refill the radiator? I sent an email to Snivilous but he's off racing so I don't expect for him to answer.
  13. Apr 27, 2024 at 11:14 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yes to running and starting it. Technically you could drive it as well if you wanted to, just don't be romping on it. Grampa driving permitted.
    koditten, HulkSmurf14, ARES35 and 4 others like this.
  14. Apr 27, 2024 at 11:51 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It's on topic. You can go but ya gotta stop!
    I had wrapped rotor brake fade with OEM, powerstop, and oem again.
    Installed Raybestos r300 rotors all around with element3 pads. They work great even with some hard 110-0 stops. Also after hard braking don't leave the pads touching the rotors can lead to warpage. Now I need to install the stainless lines to complement them. Been 2 years still going!
    ARES35, e30cabrio[QUOTED] and Wynnded like this.
  15. Apr 27, 2024 at 12:02 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    You need some of these
  16. Apr 27, 2024 at 12:04 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's where it's at! Some stopping power...
    ARES35 and Fastlane47 like this.
  17. Apr 27, 2024 at 12:11 PM
    blenton
    blenton New Member
    Still waiting for mine :(
    ARES35 and reywcms[QUOTED] like this.
  18. Apr 27, 2024 at 12:11 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This can also lead to brake pad material transfer which can feel like a warped disc. I've been able to scrub the disc lightly and cure this, in the context of a motorcycle.
  19. Apr 27, 2024 at 12:22 PM
    e30cabrio
    Possibly, in however many miles it takes to make these need replacing.
    I had no memory of what I got, the post below was from 6/21! I forgot I got SS lines, need to look for those suckers.
    Mystery solved!
    Mdl likes this.
  20. Apr 27, 2024 at 1:27 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I bought but never installed some stop tech stainless lines. Should get those installed and do a fluid change. As soon as my thumb heals...
    Wynnded likes this.
  21. Apr 27, 2024 at 1:28 PM
    blenton
    blenton New Member
    Those pesky stringed instruments. Finger guillotines, I call them. Prolly safer to play paddy cake with a pair scissors..
    HulkSmurf14 and Mdl[QUOTED] like this.
  22. Apr 27, 2024 at 1:29 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    :thumbsup::rofl:
    Mdl[QUOTED] likes this.
  23. Apr 27, 2024 at 1:51 PM
    NatesNightMare
    NatesNightMare Is what it is
    Nate
    Pinetop Az
    Why would you want to risk driving it without the tune? Though you can but I wouldnt pull into traffic or anywhere where you need to get up to speed fast. Like what wynnded said, gramps x10 type driving if you MUST drive! Usually why the instructions tell you to get the tune subbmitted the first steps that way if you end up into the weekend and finish you have to flash and be done! I eneded up getting sent the wring kit with wring dongle and had to wait all weekend then to wait for tune to be sent back. I wouldnt even start the truck and risk even that.
    e30cabrio likes this.
  24. Apr 27, 2024 at 2:06 PM
    e30cabrio
    The BMW is running great, SC is giving good boost, second to last tune I dragged from the tuner had it running fine but he said it was rich so sent a new file. It runs & drives fine, but at stops/lights etc, 50% of the time it stalls.
    I messaged, emailed & called all day yesterday looking for input on logs I sent TUESDAY and got nonsense pull shit apart responses at 5pm my time, 8pm his (he is in Fla)
    I paid this freaking company just shy of 7k and have to literally beg for help. Pisses me off.
    He ignored that (A) the car runs fine on tune 1 and will not idle with the slightest vacuum leak, these motors are crazy sensitive to vacuum leaks, and (B) the things he is asking me to check require massive tear downs & seeing as literally EVERY hose, fitting, fastner & sensor is NEW NO, Not tearing into it at least until he addresses the simple question, what did you change between tune 1 & 2???
    /rant
    :D
  25. Apr 27, 2024 at 2:07 PM
    e30cabrio
    I totally forgot I have a full set of ST SS lines :p
  26. Apr 27, 2024 at 3:00 PM
    pursuit2550
    I didn't do the tune first because I am doing a custom tune. The tuner, @snivilous, is out racing this weekend and I had no issue waiting till tomorrow. I just wanted to check for leaks and make sure everything else was fine. I wasn't going to go a round town racing, lol. I haven't had a vehicle tuned in over 15 years so, I dont know how things have changed, ECM wise, compared to back then. Back then I wouldn't have even asked.
    Mdl, Wynnded and Silver17 like this.
  27. Apr 27, 2024 at 3:12 PM
    pursuit2550
    That was from the group buy awhile back? I would love to get those but the SC was tempting me first.
    Mdl likes this.
  28. Apr 27, 2024 at 3:16 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Eibach pro 2.0s, toytec progressive mini AAL, ARE CX cap, Airlift bags, Harrop Supercharger, 650cc injectors, 77.5mm pulley, TRD Dual exhaust, J&L catchcan, Powertrax LSD, RRW RR7-H, 305/70r17 Toyo AT3s
    About time you get some spice back in your life. :thumbsup:
    pursuit2550[QUOTED] likes this.
  29. Apr 27, 2024 at 3:34 PM
    pursuit2550
    Yeah, just a little though. I will not be chasing big number anymore. I did that back when I had a 06 Silverado SS w/MP112. I was always looking for more. At the end of the day it was a heavy fat pig, but fast. On the stock setup, before I started to build on to it, It did 475 but can't remember if that was TQ numbers or HP numbers. But that was pretty good for a MP112 on a 6.0 LQ9. When the Radix came out, I thought about swapping. But that was just more $$$$.
    Silver17[QUOTED] likes this.
  30. Apr 27, 2024 at 3:44 PM
    NatesNightMare
    Nate
    Pinetop Az
    I just did the stock tune from mag just to get running. I installed back in feb and just had a tune done a few weeks ago.
    Mdl likes this.
