Bearing? Tire? Invisible nail? What could it be...
Discussion in '2.5 Gen Tundras (2014-2021)' started by iamsmokey, Apr 26, 2024.
  1. Apr 26, 2024 at 1:42 PM
    iamsmokey
    iamsmokey [OP] Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    What's up everyone,
    Recently (+/- 2 weeks ago), started to hear what sounded like a nail/rock/object in my tire. Only heard it with my passenger side windows down and when I'm driving against a near surface (i.e. walls, parked cars, etc.). With every revolution, you hear a slight tap/slice/jingle. You can't hear it in the cabin with windows up, no humming either. The noise is consistent though, whether you're going 10 mi/hr or 60+ mi/hr. Noise doesn't get louder, just gets more consistent (which makes it louder/more noticeable?).
    Inspected my tires, no lodged objects. Recently did my brake pads in January, last rotation/alignment was January. Tires are relatively new with 70-80% tread.
    Did the back/forth swerve test while driving, noise seems to remain consistent, no matter where the weight is at on the truck. No steering wheel vibrations, alignment still feels good.
    Wanted to check in with the crew, any thoughts on what it could be?
    **Attached some videos, I apologize for the LOUD WIND, will need to listen closely**
    Any thoughts are appreciated. Have an awesome day!
    https://youtube.com/shorts/BNC9wdCh3Bw?feature=share
    https://youtube.com/shorts/KpgMp4voV9w?feature=share
  2. Apr 26, 2024 at 2:44 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Sounds like something could be rubbing against the backing plate. Try jacking up that tire and spinning it slowly by hand, might be easier to hear it that way. Good luck.
  3. Apr 26, 2024 at 3:04 PM
    Oolypoolay
    Oolypoolay Meh
    2015 Limited Crewmax
    Bilstein 6112/5160 Method 702 0 offet Toyo open country 285/75 17 Form led headlights OEM Toyota led fog lights Morimoto 3rd brake light
    Wheel weight hitting the brake caliper? What size rims do you have?
    frichco228 likes this.
  4. Apr 26, 2024 at 3:08 PM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Did someone put a zip tie on your driveshaft?
    Retired...finally likes this.
  5. Apr 26, 2024 at 7:06 PM
    iamsmokey
    Oahu, HI
    Followed your orders, captain! What do you think?
    I am still dumbfounded though. I can't seem to understand how this whining/scraping would then turn into a ratio of 1:1 - Tap Noise:Tire Revolution.
    https://youtube.com/shorts/MOAD25H_xcI?feature=share
    https://youtube.com/shorts/Plm1-9fndTQ?feature=share
  6. Apr 26, 2024 at 7:09 PM
    iamsmokey
    Oahu, HI
    I have the SCS Ray 10's:
    18x9 | 5x150 6.00" +25mm 27 lb 4 oz
    Tire size is 285/70
    I checked out my weights, nothing that led me to think but I'll have another look for sure
  7. Apr 26, 2024 at 7:12 PM
    iamsmokey
    Oahu, HI
    That's like, the best description to be honest. The sound is minimal when driving that I thought something may have been on my driveshaft, crawled under and could not find a thing.
    2mchfun[QUOTED] likes this.
  8. Apr 26, 2024 at 7:17 PM
    TILLY
    Massachusetts
  9. Apr 26, 2024 at 7:22 PM
    iamsmokey
    Oahu, HI
    Sounds like a plan. Will get back to you.
    Getting late here, the fiance will not be thrilled if I bail on date night to fix my obsession... :sadviolin:
    More to come. Appreciate you!
    TILLY[QUOTED] likes this.
  10. Apr 27, 2024 at 8:18 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Pad anti rattle clip
  11. Apr 27, 2024 at 9:03 AM
    Retired...finally
    Look for rust on the rotors in the areas the pads don't rub.
  12. Apr 27, 2024 at 12:19 PM
    iamsmokey
    Oahu, HI
    Pad retainer was touching the rotor on one side. Causing the whining/grinding noise. Easily can see the area where it was touching.
    Bent it back a bit. Unfortunately, it was raining the last time I drove it so I wasn't able to test thoroughly but will be listening for the tapping noise again.
    Do any of you know the part number for this little retainer clip? Did a Google search but several come up.
    Appreciate you all. Something so small was causing me the biggest headache
    @Retired...finally @agrestic1 @TILLY
    TILLY, Retired...finally and Jbehredt like this.
