DIY 32" LED bar install.
Discussion in '2.5 Gen Tundras (2014-2021)' started by dcsleeper408, May 9, 2016.
  1. May 9, 2016 at 11:34 AM
    dcsleeper408
    dcsleeper408 [OP] BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Made this a while back for my friends at HID extra.
    2015 Tundra TRDPro 32" Light bar install
    DIY 32” LED Light bar Install – 2015 Toyota Tundra
    Tools Needed:
    3/8 Ratchet
    3/8 Small Extension
    10mm Deep Socket
    12mm Deep Socket
    Allen wrench (Provided w/Light bar)
    Drill
    Step drill bit
    Tape measure
    Masking Tape
    Marker
    Flat head
    Razor Blade
    Zip Ties
    Wire Cutter
    LED BAR:
    The kit will come with:
    2 mounting brackets
    2 small allen screws
    2 crush washers
    2 long allen screws
    2 rubber mount protectors
    Install mounting brackets on LED bar.
    Place the 2 crush washers into the 2 allen screws and tighten down the brackets onto the bar.
    Be sure to adjust the brackets to the angle you like (whether you want to point down/straight/up)
    INSTALL:
    First remove upper grille:
    Remove top 6 10mm bolts on grille.
    To remove lower part of grill, hold and pull away (lift up) from lower headlight pieces.
    Then remove grille to expose your mounting point (Upper grille support)
    Using the tape measure extend it from end to end on the upper support.
    Place the LED bar on the upper support and find where you would want/prefer to mount/center your LED bar. (Try to push the bar as far back away from the grille)
    Now mark the holes where you choose to drill
    Mount your LED Bar and angle it to your liking
    Route your connector wire (Connector wire will be long enough to for a nice tucked route)
    WIRE CONNECTION/ROUTE:
    Connect the plugs and route it to your liking.
    Disconnect the battery
    Connect the Positive from the LED Bar harness to the battery (Refer to website for diagram)
    Connect the Negative from the LED Bar harness to the battery (Refer to website for diagram)
    Mount the Relay onto the chassis
    Run the rest of the wire along the fender and run it through the cabin harness grommet
    The wire will come from under the dash towards the top
    Now connect the switch sub harness to the main LED Bar harness
    Mounting the switch is to your preference
    Remove OEM Switch plate/Drill a hole and notch
    Place the Switch in and Test for power.
    Once complete zip tie the harness in place/Hide excess in a concealed area for a cleaner look
    https://www.youtube.com/watch?v=M1Omuv0dxIE
  2. May 9, 2016 at 12:02 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Very nice. Added here.
    Bob, dcsleeper408[OP] and T-Rex266 like this.
  3. May 9, 2016 at 12:15 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Another thing to add to the list! Great write up, thanks!
    dcsleeper408[OP] likes this.
  4. May 9, 2016 at 1:43 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Very nice....
  5. May 9, 2016 at 7:33 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    I'll do that on my next truck. Thanks for the write up.
  6. May 9, 2016 at 7:38 PM
    T-Rex266 Moderator Staff Member
    o_O
  7. May 9, 2016 at 8:50 PM
    CaptTyler
    Tyler
  8. May 9, 2016 at 8:51 PM
    You said on your next truck...any plans? :popcorn:
  9. May 9, 2016 at 8:54 PM
    CaptTyler
    Tyler
    Don't tempt me...
    But not this year. I do have some cool plans for the current ride though.
    :thumbsup:
  10. May 10, 2016 at 7:02 AM
    Seanson
    Seanson New Member
    2010 Tundra TRD Reg Cab Short Box
    Will this same set up work on a 2nd gen ?
  11. May 10, 2016 at 8:21 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Hey bud. I don't see why it wouldn't work. It depends on where you would like to mount.
    If you choose this upper grille support mounting spot, You would have to check if you have that upper crossbeam. If you don't have that you can have custom brackets made or find a different area to mount.
    Everything is all the same concept.. Just really depends on your personal preference.
    Feel free to upload some photos of what it looks like behind the grille.
    I'll do as much as I can to help ya out!
    -Mark
  12. Aug 30, 2016 at 5:31 PM
    I see the power cord to light bar is on left side what if you flip bar so that the power cord is on right side will that affect beam of light bar??? Only ask cause I bought a bar of Craigslist and the cord was short so mine runs on right side
  13. Aug 30, 2016 at 7:49 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    You are fine. It doesn't matter which side cord runs.
  14. Nov 22, 2016 at 1:38 PM
    jwm9289
    jwm9289 New Member
    Very nice write up, ill be doing this.
    Thanks,
  15. Nov 22, 2016 at 1:43 PM
    cdkenne
    cdkenne Toyota Master Technician
    Corey
    KS
    2002 Tundra SR5 TRD Offroad
    285/70R17, '15 4Run Trail Wheels, Westin Shopping Cart Basher, SnapOn license plate cover that adds >50 HP
    Isn't a 3/4" ratchet a little overkill for 10mm and 12mm nuts and bolts?
    lol Nice write up though
  16. Nov 22, 2016 at 1:47 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    NewImprovedRon likes this.
  17. Nov 22, 2016 at 1:57 PM
    cdkenne
    Corey
    KS
    I mean I use 3/8" all day every day but I don't even own any 3/4" tools. 1/2" is the largest I use. ;)
  18. Nov 22, 2016 at 2:07 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    oops. yes 3/8 ** and not 3/4 :facepalm:
    cdkenne[QUOTED] likes this.
  19. Nov 26, 2016 at 2:53 PM
    Abrams65
    Abrams65 New Member
    Cliff
    WV
    16 Tundra MGM SR5 CM OR/15 Corolla S
    ICI Magnum RT Steps, 18' LED Foglights
    Great write up but I did notice one thing that makes me uneasy. The routing of your harness would have probably been beeter through the grommet instead of around it since water just like power take the least path of resistance.
    1_thirsty_tundra and Chukardog like this.
  20. Nov 26, 2016 at 3:09 PM
    Abrams65
    Abrams65 New Member
    Cliff
    WV
    Tundramax2016 and 1UPPER like this.
  21. Nov 26, 2016 at 3:24 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Very true. I have yet to re route and update everything. Once I get a blue sea fuse box I will re route and clean everything up with maybe a new light bar and other lighting options.
    That nsv light is really nice!
  22. Nov 28, 2016 at 5:19 AM
    cdkenne
    Corey
    KS
  23. Nov 28, 2016 at 6:07 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I researched the ASV auto company and they are located out of Dubai. This light was just premiered at sema this year. I can't find this light for sale yet. It's nice to see a light that is molded to fit into the stock hood bulge opening!
    Lilly likes this.
  24. Nov 28, 2016 at 6:57 AM
    cdkenne
    Corey
    KS
    http://dirtydeedsindustries.com/product/knightrider-lightbar/
  25. Jul 13, 2017 at 2:20 PM
    Avila enri
    Avila enri New Member
    Enrique
    2016 tundra sr5
    TSS off road package
    I installed a VOLANT cai on my 16 CM 5.7 and I'm getting less mpg
  26. Jul 14, 2017 at 9:41 AM
    gan
    gan New Member
    Rgv Texas
    2021 Black Tundra Pro
    Rago has LED option for the bulge
    Redviking likes this.
  27. Sep 14, 2017 at 4:25 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Great write up!
  28. Sep 19, 2017 at 1:58 PM
    AWO guide
    AWO guide New Member
    2001 white Tundra double cab TRD
    5 inch body lift
    I just got a 2001 Tacoma and I am wanting to have an LED light bar installed. Any suggestions?
  29. Sep 19, 2017 at 2:59 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
  30. Sep 20, 2017 at 9:18 PM
    stefan702
    stefan702 IG: 702stefan_
    Randy
    Las Vegas
    2015 Tundra TRD Offroad
    IG: 702stefan_
