Gas mileage
Discussion in '3rd Gen Tundras (2022+)' started by tomt96, Apr 26, 2024.
  1. Apr 26, 2024 at 12:11 PM
    tomt96
    tomt96 [OP] New Member
    Tom
    2023 Tundra Limited non hybrid
    2023 Tundra V6, Twin turbo,,,, started out at 20/21 mpg based on dashboard....has been gradually decreasing. Now with just over 6k miles my total avg mpg from the dashboard is 15.7....last fill-up was hand calculated at 15.6 mpg. I'm in North Florida with minor rolling hills. I drive on cruise. For the most part speed limit in Tallahassee is 45mph and I drive 55. Out of town speed limits are 55 and I drive 65...85 on an occasional I-10 run of 4 miles. Gas mileage is not what I expected...my 2017 F-150 Lariat with 8 foot bed gave me 16.5 under the same conditions ..Any comments, clues, or suggestions? I have a case number assigned by Toyota in Houston.
  2. Apr 26, 2024 at 12:14 PM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    Dozens of threads on this already
    It's most likely just your driving though and the mpg on the screen has been learning your habits the more you drive it.
    Cruise kills. Going more than 60-65 kills. Start stop kills.
    I get better than that in my 2020 with big tires. Much better.
    Terndrerrr likes this.
  3. Apr 26, 2024 at 12:18 PM
    Markus
    Markus Hermitic Member
    Mark
    Boring, MO
    2 1794 Tundys 2014 and 2023 AG TRD
    A few
    Idle time will kill it as well
  4. Apr 26, 2024 at 12:58 PM
    kirkb
    kirkb New but aged
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    Interesting your experience is almost exactly opposite of mine. Started in the 15's and now getting 17-19 and sometimes 20'ish. My drives are nearly the same as they've always been. The only things that have changed are my driving habits, not using cruise, transmission recall(not sure this would impact), different gas(winter vs summer), and break in period.
  5. Apr 26, 2024 at 4:11 PM
    PNW Tundra Mike
    PNW Tundra Mike New Member
    Western WA
    MX4 Tonneau, Talon's Trans/Cat Shield
    Lifted? Oversize Tires?
  6. Apr 26, 2024 at 4:19 PM
    Hella Krusty
    Hella Krusty New Member
    This > Cruise kills. Going more than 60-65 kills. Start stop kills.
    I will add any e-rated tire/lift/level
    People come on here and wank away that their lifted truck with 35's at 80 MPH get shit milage LOL
    Rcflyersd and PNW Tundra Mike like this.
  7. Apr 26, 2024 at 4:35 PM
    b6graham
    b6graham New Member
    When towing an 8k trailer into a 30mph headwind. Don't forget that
  8. Apr 26, 2024 at 4:43 PM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    Sorry that your upset with the mileage but....
    It's a truck:deadhorse:
  9. Apr 26, 2024 at 4:44 PM
    Hella Krusty
    You could of just stopped at towing Lol
    Blufin and b6graham[QUOTED] like this.
  10. Apr 26, 2024 at 5:04 PM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    '24 1794 HV 6.5' MGM w/ AVS, HUD, RB
    @op....wonder what the gas mileage would look like if you respected the speed limit more.
    Hella Krusty and b6graham like this.
  11. Apr 26, 2024 at 5:30 PM
    sno1
    sno1 In search of quality
    In need of a new truck
    The odd part is that it's decreasing, usually mileage will increase slightly after break-in. Maybe brakes dragging, stuck caliper?
  12. Apr 26, 2024 at 5:57 PM
    2494 New Member
    2024 Tundra 1794
    I’ve never once looked at mpg…I also drive in sport mode all the time. Have fun with it or go get a Prius.
  13. Apr 26, 2024 at 6:09 PM
    pwpblue
    pwpblue Reading, try it sometime.
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    2 post and disappointed already.
    Probley wasting your time with a case @ Toyota so soon.......dealer will plug into it most likely tell you everything is normal.
    Tire pressure/ alignment
    Ac on
    Using oil weight other than 0w20
    Oil Over filled
    E85
    15% ethanol
    Head wind/tail wind
    Don't compare with a Ford thats alot lighter vs even the current Tundra steel/alum half breed.
    My 2018f150 failure unladen weight was 4757 vs my reliable Tundra is 5592.
    835 lbs plus of reliability and trailer towing stability.
    Obviously I bought a Toyota for reliability not mpg's. You most likely are focused on mpg and will never match a lighter vehicle as you past truck.
  14. Apr 26, 2024 at 6:10 PM
    pwpblue
    Greensburg,PA
    Very possible.......
  15. Apr 26, 2024 at 6:13 PM
    Colotundie
    Colotundie New Member
    Another guy buys a $70,000 truck and is worried about $2000 in gas to run it.
    Math problem not a truck problem.
    Terndrerrr, Blufin, BigEasy72 and 2 others like this.
  16. Apr 26, 2024 at 8:27 PM
    Hella Krusty
    Well done LOL.
  17. Apr 28, 2024 at 11:40 AM
    Tim P
    Tim P New Member
    I noticed when I changed the gas mileage read out on the dash from overall mileage to per trip mileage I got a better idea of what I was getting per trip. Each trip being different based on were I was going and highway or city driving.
  18. Apr 29, 2024 at 11:11 AM
    xc_tc
    xc_tc New Member
    Florida = A/C ON
    AC kills gas mileage.
    EPA fuel economy number does not include AC.
    pwpblue and Mattedfred like this.
  19. Apr 29, 2024 at 3:21 PM
    D&MTundra
    D&MTundra New Member
    2024 SR5 TRD Off Road 4x4
    Is your rear differential acting up? Mine is needing to be replaced under warranty, and I have seen a drop in mpg, not as bad at yours, but it’s noticeable.
