Lower Ball Joint Insurance Policy - Badass
Discussion in '1st Gen Tundras (2000-2006)' started by Diablo169, Apr 25, 2024.
  1. Apr 25, 2024 at 11:51 PM
    Diablo169
    Diablo169 [OP] ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 340k+
    2” Lift, Bilstein 5100’s and 885’s, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags with Daystar Cradles. Spider Trax 1.25” Wheel Spacers, Factory Wheels wrapped with Toyo 285/70r17 AT2’s.
    Just saw this on FB, sorry if a repost.
  2. Apr 26, 2024 at 4:43 AM
    shifty` Damn you! Let the rabbits wear glasses!
    Would require new, longer bolts, and figuring out the best torque spec for said bolts :D
    Tundra2 and JakeJake like this.
  3. Apr 26, 2024 at 4:59 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Bolts shearing off was one cause of failure, but the joint popping out was the other big one. If this can limit the upward movement of the cup from separating from the ball, then there maybe some value to it. Doesn’t seem like it would keep the joint from slipping laterally out into the Kachow position like we see all the time. Cool idea!
    Tundra2 likes this.
  4. Apr 26, 2024 at 7:09 AM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    I like the idea and have wondered why something like this wasn't already available for us.
    rrod likes this.
  5. Apr 26, 2024 at 7:11 AM
    Teutonics
    Teutonics New Member
    2005 DC SR5 4WD
    Could you even get a torque wrench in there to torque them to proper spec (whatever that may be)?
    Jack McCarthy likes this.
  6. Apr 26, 2024 at 7:17 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  7. Apr 26, 2024 at 7:27 AM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    We would need at least 10 pages debating what the proper torque spec should be.
    abcinv and shifty`[QUOTED] like this.
  8. Apr 26, 2024 at 9:03 AM
    rrod
    rrod 2005 AC Tundra SR5 4x4
    Rob
    Aluma Series, JBA UCA, Wheelers add a leaf
    I guess a related question, did Total Chaos ever come out with their LBJ for the Access cabs? It does seem like one of you super mechanically inclined persons can design something in this "after market" product World that can be marketed for the infamous LBJ issue. I realize the margins are limited but you throw in all Toyota platforms effected and you might be able to justify. Kudos to this enthusiast that came up with this!
  9. Apr 26, 2024 at 9:14 AM
    It looks like they intentionally tapered the tower in a way that you could get a standard deep well socket onto it. Notice how it narrows up to the bridge. If not, that's a bit of a critical design flaw.
  10. Apr 26, 2024 at 9:39 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I'd like to see the proof of concept. Is the concept that if the LBJ lets go, the spindle and castle nut will fall into the hole and will be held in place long enough to be able to come to a stop without the cascading catastrophic failures that usually take place? Can the tensile strength of the four bolts withstand the shock of the ball joint letting go? Once you hit the brakes, all kinds of other forces need to be taken into account, much more complex than just holding the ball joint up. Has that been taken into account? Interesting idea, nonetheless.
    The Black Mamba likes this.
  11. Apr 26, 2024 at 10:34 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    Was wondering the exact same thing. Was just thinking it would probably shear the bolt heads off.
  12. Apr 26, 2024 at 7:59 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    If it was shorter and actually kept everything fully captured, it'd be ok.
    Instead of hoping it'll fall into the hole.
  13. Apr 27, 2024 at 3:26 AM
    FishNinja
    FishNinja Hide Your Daughters
    Lee
    SATX
    06 DoubleCab SR5 V8 2WD
    I like it. I think the "catch" needs to be tighter and widened a tad, maybe even conical in order to facilitate it catching.
    and I was even thinking of an additional hanger to help with weight distribution
    TX-TRD1stGEN likes this.
  14. Apr 27, 2024 at 11:16 AM
    Welcome back!
    I think the tough part would be making it such that iyou could still manage to service the castle nut on the LBJ spindle.
    FishNinja[QUOTED] likes this.
  15. Apr 27, 2024 at 11:19 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Doesn't need access imo. Unbolt 4 bolts and it falls out of the way.
    shifty`[QUOTED] likes this.
  16. May 2, 2024 at 5:09 AM
    batman900
    batman900 Yep
    24-RAM 2500, 05-Tundra, 11-Accord
    I’m not part of that FB group. Is someone selling these? I’d probably grab some on the chance it might help even if there’s a chance it might not.
