Overheating issue 2014 5.7
Discussion in '2.5 Gen Tundras (2014-2021)' started by Trucks n Dogs, Apr 25, 2024.
  1. Apr 25, 2024 at 3:45 PM
    Trucks n Dogs
    Trucks n Dogs [OP] New Member
    2014 Black SR5 Double Cab
    My 2014 5.7 is overheating but I can drive it for an hour with the heater on full. When the truck has cooled down I slowly started to realease the radiator cap and the coolant reservoir starts to bubble badly, like a pot of boiling water. I just bought a thermostat but I'm concerned about the bubbling reservoir. And I just got a tuneup yesterday.
    Ct. Rich likes this.
  2. Apr 25, 2024 at 3:57 PM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    What’s a tune up?
  3. Apr 25, 2024 at 4:12 PM
    Trucks n Dogs
    Replaced all plugs and coil for #4. So not really a tune up.
  4. Apr 25, 2024 at 4:19 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    How long have you had it? What have you done to it? What were conditions driving it??
    Welcome from VA
  5. Apr 25, 2024 at 6:28 PM
    Bad thermostat or water pump? :notsure:
    Trucks n Dogs[OP] likes this.
  6. Apr 25, 2024 at 6:33 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    What condition is your radiator cap in?
  7. Apr 25, 2024 at 6:47 PM
    zeekevin
    zeekevin New Member
    Sounds like a bad radiator cap, common problems on the 5.7s
  8. Apr 26, 2024 at 7:10 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Things to check, radiator cap, waterpump functon, fan clutch and of course any signs of leaks.
  9. Apr 26, 2024 at 2:37 PM
    Trucks n Dogs
    I've had the truck since 15'. Besides a bad alternator this is the only major issue I've had. I have 306k on it so I'm leaning towards the thermostat and will be replacing it regardless. I'm actually considering buying a used motor just to have on hand. I figured I'd buy one now before prices get out of hand.
  10. Apr 26, 2024 at 2:42 PM
    Trucks n Dogs
    It's good.
    Wynnded[QUOTED] likes this.
  11. Apr 26, 2024 at 2:43 PM
    Trucks n Dogs
    I did find a pinhole leak in my muffler.. other then that nothing.
  12. Apr 26, 2024 at 2:44 PM
    Trucks n Dogs
    Since I've never replaced the thermostat and I have over 300k that will be replaced.
  13. Apr 26, 2024 at 8:31 PM
    :thumbsup:
  14. May 2, 2024 at 12:37 PM
    Trucks n Dogs
    So the Thermostat has been replaced, radiator fluid replaced and the truck runs good for the most part except the check engine/traction control off warning is back.
    Here's the thing. When I start it cold the engine misfires/shakes leading to a blinking check engine light. I then wait for the engine to warm up, the shaking goes away then turn off my truck. When I start it back up the check engine light is no longer flashing but solid and no longer misfires.
    Im thinking that I have a small leak in the headgasket. Any thoughts?
    Has anyone had success using an additive to seal the headgasget. If so, how long did it last and is there any downside?
  15. May 2, 2024 at 1:38 PM
    AZBoatHauler
    AZBoatHauler SSEM#140/ASCM#3/2ndGenNaysayer/BAF140
    So.Arizona
    Paul from FabRats poured this in his Tacoma and says it has held for a couple years. It will put a nasty coating on everything it touches.
    FrenchToasty likes this.
  16. May 2, 2024 at 2:10 PM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Use OBD2 codes to find which cylinder misfires. Test compression, look inside spark plug holes with boroscope camera, you can see a difference inside compared to other cylinders. Then you might even see the leak too, Test coolant for exhaust gases, etc. No need to just guess it has a blown head gasket.
