Pressurized hissing from gas cap removal
Discussion in '1st Gen Tundras (2000-2006)' started by TET1, Apr 26, 2024.
  1. Apr 26, 2024 at 9:07 AM
    TET1
    TET1 [OP] New Member
    2000 Tundra V8 4WD
    My 2000 V8, 4wd AC does it every time I fill up. Thought if there was an issue with the charcoal canister that it would have thrown a code by now, but who knows? What causes this on the Gen 1 and is it an issue?
    Also, just curious how many other Gen 1 owners have pressurized hissing when they remove their gas cap?
  2. Apr 26, 2024 at 9:11 AM
    shifty` Damn you! Let the rabbits wear glasses!
    I don't recall hearing a hiss. But if you're not tossing a code, I wouldn't be concerned. Trust me, EVAP checks will let you know if there's an over/under pressure issue.
    That said, on earlier models the check engine light bulb can go out. So ... you may want to confirm yours is working, IIRC, it should show when you have the key at ON but not START/running.
  3. Apr 26, 2024 at 9:37 AM
    TET1
    2000 Tundra V8 4WD
    Is it possible for the charcoal canister to be "full" and not throw any codes, just bad gas mileage?
  4. Apr 26, 2024 at 9:41 AM
    SD Surfer
    Bruce
    So Cal
    How long does the "hissing" last, sustained or momentary?
    I can remember hearing my 1st gen make a momentary hiss noise of air being sucked in when I first removed the cap if I ran tank real low.
    Do you usually run it close to empty?
    tvpierce and jerryallday like this.
  5. Apr 26, 2024 at 9:47 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Mine does it too sometimes.
    Tundra2 and TET1[QUOTED][OP] like this.
  6. Apr 26, 2024 at 9:53 AM
    Define "bad gas mileage". At stock height and stock tire size, with the earlier-year 4spd transmission and stock configuration if you're getting 11-12mpg in the city and 16-17 highway on average that's pretty normal. ==> EDIT: Welcome to life with 4WD!
    If the canister was full, you'd be throwing a code, I would expect.
    TET1[QUOTED][OP] likes this.
  7. Apr 26, 2024 at 9:57 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Probably normal. My SC400 does it all the time, duration is how low my tank is almost like opening a brand new soda bottle. No codes and get about 18-20mpg on the highway. Assuming all Toyota gas systems are alike.
    TET1[OP] likes this.
  8. Apr 26, 2024 at 10:22 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    My 01 does it sometimes as well.
    Tundra2 and TET1[OP] like this.
  9. Apr 26, 2024 at 10:43 AM
    TET1
    2000 Tundra V8 4WD
    Hissing normally lasts about 1 or 2 seconds, so momentary. Strange, I thought it was air being pushed out?
    I usually fill up right when the gas light comes on, or at about 5 gallons left in the tank (I've just learned where my gauge is when I'll need to fill up 21 gallons worth).
  10. Apr 26, 2024 at 10:50 AM
    SD Surfer
    Bruce
    So Cal
    Maybe fill up at half tank and see if it does it... just for shits and giggles.
  11. Apr 26, 2024 at 11:25 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    When my sister borrowed my truck she gave it back to me on below empty empty and I hear a noise when I opened the gas cap
  12. Apr 26, 2024 at 11:41 AM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    Both of my Toyota vehicles do this. I assumed it was normal and a sign the gas cap was sealing properly.
  13. Apr 26, 2024 at 1:13 PM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    The Land Cruiser 100 is known to have excessive fuel vapor pressure and my 1999 will blow all sorts of vapor out of the tank when I remove the gas cap. My 2004 DC Tundra doesn't let out any vapor when the cap is removed.
  14. Apr 26, 2024 at 3:11 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I thought it was a vacuum hiss & my tank vent might be plugged.
  15. Apr 26, 2024 at 3:15 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Perhaps a new gas cap is in order?
    Leo's first likes this.
  16. Apr 27, 2024 at 3:53 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Mine does it too when the fuel level is run low. I try not to run it low often because fuel pumps work really hard and generate a fair amount of heat. When the pump is fully submerged in fuel, the fuel is helping to keep the pump cool. Regularly running your fuel tank to near empty means the pump is regularly running hot -- which can be detrimental to its longevity.
  17. Apr 27, 2024 at 4:11 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Wouldn't this be an indication that that the gas cap is properly sealing the tank?
  18. Apr 27, 2024 at 4:40 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Every vehicle I've ever driven, whether yota or not did this
