SAFETY (NONCOMPLIANCE) RECALL J0X (Remedy Notice)
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2018Tundra, Oct 5, 2018.
  1. Oct 5, 2018 at 8:36 AM
    2018Tundra
    2018Tundra [OP] New Member
    2019 Super White Tundra SR5 CrewMax 5.7L 4x4 TRD OFF ROAD
    Anyone else get this? Attached a PDF with an FAQ.
    SNO BUS likes this.
  2. Oct 7, 2018 at 4:43 PM
    SNO BUS
    SNO BUS Professional Moneywaster
    Nick
    Washington
    White '18 CM 4x4 Limited+
    LEER Canopy, Line-X, Bed mat, Wireless charging
    I got an alert on myCARFAX. Guess I better get to the dealer
    2018Tundra[OP] likes this.
  3. Oct 7, 2018 at 4:51 PM
    SNO BUS
    Nick
    Washington
    So here's what I found.
    The recall for Tundras issued 2/20/18 (recall J0H) says "a vehicle diagnostic function may unnecessarily turn off the Vehicle Stability Control System and affect other systems." And the remedy was for dealer's to FLASH the software on the center airbag sensor assembly.
    The new recall for Tundras issued 10/4/18 (recall J0X) states that "a fault may be erroneously detected during vehicle startup which would disable one or more of the sensors used to detect crashes. This could result in the side and curtain shield airbags and/or front and knee airbags not deploying as designed in a crash". The remedy for this is that a Toyota dealer will UPDATE the software on the center airbag sensor assembly.
    Both have to do with the center airbag assembly sensor, one is a software flash to make the stability control system work properly and one is a software update to make the SRS system work correctly.
    https://toyota.oemdtc.com/278/recal...ity-control-system-2018-toyota-tundra-sequoia
    https://www.nhtsa.gov/recalls
