Simple oil change question
Discussion in '1st Gen Tundras (2000-2006)' started by wildduk, Apr 24, 2024.
  1. Apr 26, 2024 at 9:50 AM
    shifty` Got more stories than JD's got Salinger
    Left hand flutes are the extractors on the right-hand side of the package.
    Right hand drill bits are in the left-hand side of the package.
  2. Apr 26, 2024 at 10:38 AM
    Teutonics
    Teutonics New Member
    2005 DC SR5 4WD
    It appears the "left hand flutes – grip the metal firmly" is in reference to the extractors, not the drill bits. :-/
  3. Apr 26, 2024 at 10:42 AM
    Teutonics
    2005 DC SR5 4WD
    If you were drilling in reverse with a right hand drill bit, that's why you were having such a tough time of it.
    And on separate note, if you apply pressure to a drill with a floor jack something is going to break (drill bit, drill, or ???).
    Jack McCarthy, shifty` and tvpierce like this.
  4. Apr 26, 2024 at 11:56 AM
    And wear out your drill bit fast as hell. And it'll be difficult as shit to keep the drill straight.
  5. Apr 26, 2024 at 4:23 PM
    Jack McCarthy
    Jack McCarthy Truck repair enthusiast; Rust Aficionado
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    They make drill guide kits. Ones for bolt heads and ones for recessed screws. You can make your own if you have a professional drill press.
  6. Apr 27, 2024 at 3:31 AM
    FishNinja
    FishNinja Hide Your Daughters
    Lee
    SATX
    Sixxer DC SirCinco 8pistons 2WheelPeel
    51hundies & 2885's
    No skid is best, oil change takes zero effort, also the middle bolt on the rack is accessible from the front now.IMG_4480.jpg
    shifty` and MT-Tundra like this.
  7. Apr 28, 2024 at 10:37 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    2000 Tundra 4wd AC, 2004 Tundra AC 2wd to 4wd conversion no ABS
    lots of dents
    Without the factory slash (skid) plate installed, it does leave the radiator more susceptible to damage from debris. For instance my BOL left the splash plate off of his truck (which was the wrecked 2000 truck that i bought from him) after an oil change. His daughter went off the road and crashed the truck. A stick jammed stabbed directly through the radiator. My tundra spends most of the time offroad and in 4wd in the woods. There has been multiple instances where the radiator would have been punctured with random tree limbs if i didn’t have that splash plate installed. Of course that isn’t an issue for most people though. But maybe random road debris could be? I also wonder how much the splash plate helps out with fuel economy at highway speeds? Probably not very much at all, but it would help direct air flow.
  8. Apr 28, 2024 at 1:06 PM
    MT-Tundra
    MT-Tundra New Member
    2002 AC 4wd V8 Limited
    I imagine it does help. I even have some rubber air deflectors that bolt onto the sides of the skid plate for additional aerodynamics. Wonder how many people immediately ditched those...
    The bottom of the radiator is absolutely more vulnerable with the skid plate off. My preference would always be to leave it on. I also spend a lot of time on dirt roads. But once I hit the point where there were only two bolts left holding it on, and at that time I couldn't figure out how to work a bolt extractor kit, leaving it off was the best option.
