Supercharger Running Lean
Discussion in 'Performance and Tuning' started by mralanle, Apr 9, 2024.
  1. Apr 21, 2024 at 12:09 PM
    #91
    mralanle
    mralanle [OP] New Member
    What hoses did you buy?
  2. Apr 21, 2024 at 12:09 PM
    #92
    mralanle
    Will do. Thanks
  3. Apr 21, 2024 at 12:46 PM
    #93
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.2 SC pulley, ASP crank overdrive pulley, DD Full 3inch dual exhaust, Airbox mod, 4.5 intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, DIY Traction Bars, Tuning by snivspeedshop.com
  4. Apr 21, 2024 at 12:57 PM
    #94
    mralanle
    That Amazon link comes with all of that right? Sorry if it’s a dumb question, never really dealt with any of the fittings and things that are in this thread and thanks for helping me and whoever else that may be in the same boat as me
  5. Apr 21, 2024 at 1:31 PM
    #95
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The one I linked to has the 1/8 npt male and a female for the port on fuel rail and one for the gauge. Just need to see about length...
    3ft will just about get you there but 4ft should work fine
  6. Apr 21, 2024 at 3:00 PM
    #96
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    No clue if these are the right parts so I’ll see what shows up.
    AZTundra likes this.
  7. Apr 21, 2024 at 3:38 PM
    #97
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Looks good! After testing you can install the gauge in the port. I installed an electronic fuel gauge in the port.
    ZPhilip[QUOTED] likes this.
  8. Apr 21, 2024 at 3:50 PM
    #98
    mralanle
    Which would be a better buy? The link you sent or what he bought?
  9. Apr 21, 2024 at 4:10 PM
    #99
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Have you made AN fuel lines?
    It really comes out the same if you already ordered the gauge and fitting. If Amazon is free shipping
  10. Apr 21, 2024 at 4:17 PM
    #100
    mralanle
    Negative. Reading all of this I feel like I’m learning another language
  11. Apr 26, 2024 at 11:02 AM
    #101
    mralanle
  12. Apr 26, 2024 at 12:05 PM
    #102
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Does the pressure drop correlate to the increase in afr? Have you set up to do boost referenced? You shouldn't see a drop in psi.
  13. Apr 26, 2024 at 12:07 PM
    #103
    mralanle
    Yeah, when I got to 35Psi, I was at 12ish AFR. I’m not boost referenced
  14. Apr 26, 2024 at 12:11 PM
    #104
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR / Austin, TX
    Seems to me like with fuel pump output isn't keeping up, seems odd with a 450 in a FFV basket tho. Who's familiar with the geometry of the FFV basket?
    Mdl likes this.
  15. Apr 26, 2024 at 12:26 PM
    #105
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'm non FFV. I am running a FFV canister with a Walbro 450 #267 using the FFV venturi system with no problems. Have it hot wired for 14 volts.
    I'm not sure what model 450 he's running. It's my understanding only the #267 fits to keep the FFV venturi system.
  16. Apr 26, 2024 at 12:28 PM
    #106
    mralanle
    I have the 274
  17. Apr 26, 2024 at 12:28 PM
    #107
    VWTim
    Ding! Venturi, that's what I was thinking about and have heard you and others mention. I'd start there OP.
    Mdl[QUOTED] likes this.
  18. Apr 26, 2024 at 1:07 PM
    #108
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    There are 2 things to try before dropping the tank. If it were me...I would do boost reference and test. Then ground out the vsv pump relay so it will give a constant voltage/increased amperage to pump and test.
    How is the 450 wired in?
  19. Apr 26, 2024 at 3:21 PM
    #109
    mralanle
    I’m not sure how it’s wired as I didn’t do the install but I remember buying the pump and the installation kit. Is there more to it?
  20. Apr 26, 2024 at 4:10 PM
    #110
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I ran it on the stock wiring with no issues. It does draw more amperage than others.
    Did you try any other testing?
  21. Apr 26, 2024 at 4:15 PM
    #111
    mralanle
    No other testing. Not sure what other tests to do. With boost reference do I need a boost gauge?
  22. Apr 26, 2024 at 4:43 PM
    #112
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You can try running a vacuum line from the boost port on the rear drivers side to the fpr. Plug or cap the line to intake. Post #66.
  23. Apr 26, 2024 at 5:34 PM
    #113
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  24. Apr 26, 2024 at 5:35 PM
    #114
    mralanle
    Yeah I’m willing to try those out. Going to be trying all of them out within this week
  25. Apr 27, 2024 at 6:15 AM
    #115
    mralanle
    From my understanding, my trucks low pressure mode was removed by forcing it into high pressure mode with the non FFV fuel lines. The relay doesn’t give extra voltage to the fuel pump for high pressure mode, it just sends it through the 60 psi regulator instead of the 43.
  26. Apr 27, 2024 at 7:28 AM
    #116
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    The fuel pump flow (pressure) depends on voltage, which is adjusted by the fuel pump control module based on engine load, not accounting for supercharger as this is not standard equipment. Grounding the relay faults the control module to supply battery voltage instead of adjusting the voltage. So, this makes the fuel pump operate at a higher level, ensuring you get the flow to maintain that 60PSI at the regulator. This is the next best thing to running a dedicated relay and wiring for the pump straight from the battery.
    reywcms, Mdl and Wynnded like this.
  27. Apr 27, 2024 at 8:18 AM
    #117
    ZPMAN
    Minnesota
    Mdl likes this.
  28. Apr 27, 2024 at 8:29 AM
    #118
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Ffv trucks have a different fuel control module. Just switching to the 60psi regulator will cause it to be at 60psi. But the pump is not at full power. Under load pressure will fall off.
    It's a quick test to see if that's your issue!
    This person ran the 450 in his FFV. Tried many fixes. He finally swapped to a different pump and is running good.
    Process of elimination to find what your lean issue is. Easy things first...
    Wynnded likes this.
  29. May 1, 2024 at 6:23 PM
    #119
    mralanle
    I don’t hear a click when I ground it but I hear it when I put the relay in and put. Trying it now
  30. May 1, 2024 at 6:45 PM
    #120
    mralanle
    Looking back through the flex fuel truck install manual, how come it says to remove the relay?
