Suspension Lift Height Measurements with Visual Guide
Discussion in '2nd Gen Tundras (2007-2013)' started by csuviper, Mar 5, 2014.
  1. Mar 5, 2014 at 2:39 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    This thread is to encompass as much lift height information as possible to help those that are looking for it.
    Please post up your tire size, lift details, wheel well measurement, top cab height, etc.
    I found the below pictures on another forum. Thank you Steve G PW.
    Bugs571, yoshi82, TundrA145 and 13 others like this.
  2. Mar 6, 2014 at 7:16 AM
    T-Rex266 Moderator Staff Member
    Thanks Bry!
  3. Mar 6, 2014 at 7:19 AM
    csuviper
    Broomfield, CO
    No prob. Let's get all your measurements when we get together again.
  4. Mar 6, 2014 at 2:54 PM
    csuviper
    Broomfield, CO
    Here is a comparison to my RW with Toytec leveling spacers and P285/70R17 Nitto Terra Grappler tires:
    7.5" between top of truck and garage
    14 3/8" Frame under front door
    38" - front wheel well
    7 3/6" - front ww gap
    39 3/4" - rear wheel well
    8 5/8" - rear ww gap
    77" - true max height (level at highest point)
    14.5" - clearance front bumper
    32 1/16" - top front bumper
    29 3/4" - top rear bumper
    55 9/16" - top of bed rail centered over rear tire
    8 5/8" - rear diff clearance
    12" - gas tank skid clearance
    Jgarcia6820 and Crewmax Chris like this.
  5. Mar 28, 2014 at 7:45 AM
    csuviper
    Broomfield, CO
    The spreadsheet below is a good comparison between lifts and tires:
    Toytech Ultimate 3/1 lift and 315/70/R17 Goodyear Duratracs
  6. Mar 28, 2014 at 8:42 AM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    excellent thread...stickied
  7. Apr 24, 2014 at 9:09 AM
    csuviper
    Broomfield, CO
    @Sean266 2012 Tundra 5.7L OME 3/1 lift with 315/70/18 TOYO Open Country tires:
    41.5" - front wheel well
    7 1/4" - front ww gap
    35 13/16" - top front bumper
    42 5/8" - rear wheel well
    8 1/8" - rear ww gap
    32.5" - top rear bumper
    58 3/8" - top of bed rail centered over rear tire
    80.5" - true max height (level at highest point)
    JtTundra87 likes this.
  8. Oct 5, 2015 at 6:38 PM
    Deepwaterwolf
    Deepwaterwolf New Member
    How hard is it to install the Toytech ultimate 3/1
  9. Oct 5, 2015 at 9:21 PM
    Depends on your skill set. @csuviper did it himself.
  10. Oct 6, 2015 at 4:25 AM
    csuviper
    Broomfield, CO
    It's really not that hard. You lift the front but let the front suspension extend out. Disconnect sway bar and steering. Then remove the coilover and replace with new. Rear is easier as you let the rear axle droop and remove the shock and u bolts. Replace shock, add shim and replace u bolts.
  11. May 14, 2016 at 6:22 PM
    csuviper
    Broomfield, CO
    Anyone with stock truck at the moment want to provide the measurements on the table in post #5. I would like to know start point and actual lift heights. This would help everyone understand what their lift coilovers are truly set at. 2nd Gen and 3rd Gen needed.
    I will measure Sean's 3rd Gen with 3/2 soon if we can find time to meet up.
  12. May 14, 2016 at 7:29 PM
    Steve New Member
    2015 Tundra Crewmax SR5 TRD 4X4
    TRD dual exhaust
    Hey guys, I have a stock 2015 trd 4x4. Found this really interesting since I'm in the beginning stages of researching a 3-4 inch lift kit. Here's my measurements. Measured twice to be as accurate as possible.
    Front wheel well 36 15/16
    Front ww gap 6
    Top of front bumper 27 3/4
    Rear ww gap 8 13/16
    Top of rear bumper 30 1/4
    Top of bed rail 55 14/16
    Max height 75.5
    Hope this helps
  13. May 14, 2016 at 8:39 PM
    csuviper
    Broomfield, CO
    Awesome. Thank you. Now I need a stock 2nd Gen as double check.
  14. May 15, 2016 at 8:56 AM
    Mines a 3/1....
    Edit: unless u meant with in comparison to a 3/2
  15. May 15, 2016 at 10:09 PM
    csuviper
    Broomfield, CO
    Thought you said you had a 2" block on the rear?
  16. May 16, 2016 at 6:06 AM
    It's a 1.5"
  17. Jul 7, 2016 at 12:31 AM
    dragon_coma
    dragon_coma New Member
    Sky
    2008 CrewMax 4x2 5.7L
    I have an 08 CM stock I can get you measurements for if you are still interested.
  18. Jul 7, 2016 at 7:06 AM
    csuviper
    Broomfield, CO
    Absolutely. That would be great.
  19. Oct 3, 2016 at 7:55 PM
    csuviper
    Broomfield, CO
  20. Oct 3, 2016 at 8:00 PM
    csuviper
    Broomfield, CO
    PDF
  21. Oct 3, 2016 at 11:14 PM
    dragon_coma
    Sky
    That's good work right there!
  22. Mar 29, 2017 at 4:45 AM
    shockinyall
    shockinyall Hillbilly
    West Virginia
    2017 TRDOR CM
    In Queue...
    I hadn't seen this forum until this morning, but I will add the measurements I took the other day.
    Stock 2017 Crewmax TRD Off Road 5.7L. Only change is that I added a toolbox with some tools. Measurements are with almost full tank of gas and nobody in truck.
    BlueBottle and csuviper[OP] like this.
  23. Mar 30, 2017 at 12:42 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    hmmm I have a 2.5 inch suspension lift and my rear is sitting at 42 and my front is sitting at 38... think my lift is off
  24. Oct 13, 2017 at 10:31 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    This is a great thread. Thanks for contributing 3rd gen info. Measurement to hub means center of wheel I assume? That's how I normally measure so tires don't interfere with the data.
    shockinyall[QUOTED] likes this.
  25. Oct 13, 2017 at 10:33 AM
    csuviper
    Broomfield, CO
    Yes
  26. Oct 14, 2017 at 9:59 PM
    TheBeast The Beach
    my specs: TRD crewmax 5.7L
    33" Toyos r/t
    Kings 2.5 front coilovers 7 threads showing
    Kings 2.5 rear
    ground to top of wheel well. Measured at center.
    39 3/4 rear
    39 3/8 front
  27. Apr 20, 2018 at 9:25 PM
    csuviper
    Broomfield, CO
    Saw a tech tip from Toytec on measurements for lift. Will have to get updated measurements on mine and others to compare center of wheel to fender and compare downtravel https://m.youtube.com/watch?v=NXCHb_NPbnY
  28. Jul 7, 2018 at 5:27 AM
    tnbndr
    tnbndr New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    So I just acquired a 2012 Tundra Rock Warrior. It appears stock suspension as the front is 3" lower than the rear. So I was thinking the ToyTec 3"Eibach Lift.
    What is the benefit of a 3" Lift Kit, won't that just lift everything 3" but leave it raked low in the front? Not the look I am going for, I want it to sit level.
    TIA
    Redviking likes this.
  29. Jul 8, 2018 at 1:46 PM
    scharring100
    scharring100 New Member
    Houston, Texas
    2016 Tundra Limited 4X4 Crewmax
    2016 Crewmax, Bronze 4X4
    Stock 2016 4x4 limited crewmax. Thinking about 2/1 leveling kit, any issues with the front stock sway bar and any idea of what size tires I can run n stock 20" rims without any trimming? I'm adding a rear sway bar after the leveling kit....never seen a pick up without a rear say bar as stock. I read this blog a number of times and I don't think it addresses my issues directly. As with the post above, I want it to sit level. Ok, I just researched blistein 5100 front shocks, they do look like a viable option. Any issues with stock front sway bar? Besides alignment I'm sure that's required.
  30. Jul 10, 2018 at 6:28 AM
    csuviper
    Broomfield, CO
    3” lift kit typically refers to a 3” front lift and 1” rear lift. This will get the truck looking level.
    tnbndr[QUOTED] and Boerseun like this.
