  1. May 8, 2024 at 2:46 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Put front end on jack stands. Remove bothe wheels, remove break caliper, unbolt UCA from spindle, remove the 4 bolts holding the sway bar to the frame, replace the CO. Reinstall everything. Easy peezy. I have it down to a science and can do both CO in about 2 hours by myself.
  2. May 8, 2024 at 2:47 PM
    pursuit2550
    You aren't kidding.
  3. May 8, 2024 at 3:29 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    70° Saturday they say...but today, nope!
  4. May 8, 2024 at 3:31 PM
    SAGE63
    San Diego County
    Removed Max modular bed rack for two reasons 1, 18" risers are enroute to replace 14" 2, replaced retrax bed tracks. Old ones clamp mounts and rail mounts stripped flat no more bite left. Retrax replaced under warrentee. Had to remove from truck and dismantle to replace the rails. Yes this can be done by one person, not recommended but I did it... damn I am beat down. time for several beers. btw took this old dude 5 hours
    Interesting Retrax has rebranded. guess they were bought out...17152726375755135187177269891933.jpg
  5. May 8, 2024 at 3:33 PM
    SAGE63
    San Diego County
    Thanks Dave
  6. May 8, 2024 at 3:34 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Mag 2650 w/76mm pulley, ADS suspension, 35's, misc overlanding doo-dads and lights
    How come youre going to a higher rack?
  7. May 8, 2024 at 3:38 PM
    SAGE63
    San Diego County
    I need 1/2" more space to roll the 37" tires under the rack crossbars to fit on the bed rail spare tire mount. I don't like fighting a 100+lb tire to get the right angle... I could deflate them but... I am lazy...
  8. May 8, 2024 at 4:18 PM
    Retired Blue
    Retired Blue New Member
    Steven
    Round Rock, TX
    2020 Super White Platinum
    Awesome! Hadn't seen that method described before. Thank you! Unfortunately, my front skid blocks easy access to the bolts holding the sway bar to the frame. It was a PITA getting the sway bar link to line up attaching it back to the LCA, so I thought about loosening the frame bolts, looked at them and said, "No, grab a longer pry bar."
    I may need to take the calipers off soon. Pads are wearing unevenly. Is it typical to have the outboard pad wear twice as fast as the inboard?
    pursuit2550[QUOTED] likes this.
  9. May 8, 2024 at 4:22 PM
    pursuit2550
    I dont have skid plate so 1 less step for me and they are kind of a pain. I did manage to break both the welded nuts on the sway bar end links and this is why i stick to the frame bolt method. They are known for coming off and also a pain to put back on.
    As for the breaks, you have an issue. They should wear pretty even. Do a search for common issues with pad wear.
    Retired Blue[QUOTED] likes this.
  10. May 8, 2024 at 6:35 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Lucky duck
    RainMan_PNW[QUOTED] and koditten like this.
  11. May 8, 2024 at 7:21 PM
    RainMan_PNW
    RainMan_PNW SSEM #82 RGBA #4 “That Guy” Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    At the house? No
    On the mountain? Yep…until today
  12. May 8, 2024 at 7:24 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Damn! You got it way worse on that side of town. Bad here but not that bad! Lol
    HulkSmurf14[QUOTED] likes this.
  13. May 9, 2024 at 4:05 AM
    Bergy24
    Bergy24 New Member
    What's going on with the 4Runner?
    koditten likes this.
  14. May 9, 2024 at 6:11 AM
    HulkSmurf14
    2014 Tundra Limited
    Sooo many broken trees under the 14" we were given! Sounded like fireworks when I was working outside!
    Tripleconpanna likes this.
  15. May 9, 2024 at 8:19 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    Non-stop mods
    SDHQ Hidden winch bumper installed with a Warn evo-12s.
  16. May 9, 2024 at 9:28 AM
    It's making a clunking noise when the wheel is turned to the left, and also when hitting bumps. If feels like something is loose. Its a 2020 with 18K miles.
    bulldog93 likes this.
  17. May 9, 2024 at 9:31 AM
    SAGE63
    San Diego County
    18k miles that does not sound right...
    JMGmanAZ likes this.
  18. May 9, 2024 at 9:52 AM
    BreyTundy
    BreyTundy New Member
    Andrew
    Colorado Springs
    2016 White DC TRD
    Sway bar end links?
  19. May 9, 2024 at 9:55 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Also now that I think about it, my FJ and my Tacoma (same front suspension as your 4Runner) clunked when turning left the whole time I owned them. Checked the entire front end aside from ripping out the steering and never chased it down. Aside from the noise everything functioned perfectly for 100k+ miles between the two rigs.
  20. May 9, 2024 at 10:20 AM
    reneaux
    reneaux I've been around
    2017 SR5 CM 4x4
    I was going to say yours looks different than mine, then I saw the branding you mentioned, I guess mine is older. The canister spot in the back by the cab is decently smaller on yours and your rails look different. Mines held up pretty well though, and remained fairly waterproof. Best cover I've owned I'd say.
  21. May 9, 2024 at 10:22 AM
    SAGE63
    San Diego County
    mine is about 2 years old. the new rails have the new branding. the old branding was Retrax XR /Hero Truck.
    The canister cover only covers the back half of the canister.
    reneaux[QUOTED] likes this.
  22. May 9, 2024 at 10:53 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    Had this on my truck a while ago. Clunks on turning, in reverse, with slight articulation (on driveway slope). Turned out to be loose LCA bolts.
  23. May 9, 2024 at 10:57 AM
    4Runner or your Tundra?
  24. May 9, 2024 at 10:57 AM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    Bayou Spartan and Y0TA PR0 like this.
  25. May 9, 2024 at 10:58 AM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    [QUOTE="Hammerdog, post: 3576766, member: 17201"
    damn clean set up there! Sweet looking ride.[/QUOTE]
  26. May 9, 2024 at 11:00 AM
    JSKOOL
    JSKOOL New Member
    Jay
    Bay Area, CA
    2017 Black Tundra Limited
    Just got her back after adding Advanced Fiberglass front and rear fenders, ADD front bumper5B04F0EA-591F-411B-947C-521F3663BAD2.jpg
  27. May 9, 2024 at 11:04 AM
    Florida AF
    Logan
    North Florida
    setup auto payments from a funded account versus paying it off. basically reduced my interest rate by 1.5% and did not deplete my savings in the process.
    And then did truck stuff.
  28. May 9, 2024 at 11:07 AM
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
    Tundra...so may or may not be helpful. Not sure if 4Runner's have LCA setup like Tundra.
  29. May 9, 2024 at 11:10 AM
    Florida AF
    Logan
    North Florida
    Well... damn... there goes a pretty penny....
    I also just ordered my Ray 10's!
  30. May 9, 2024 at 11:14 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    The mod bug strikes again
    Florida AF[QUOTED] likes this.
