Adding Overhead Console From 2nd Gen
Discussion in '2.5 Gen Tundras (2014-2021)' started by WFD473, Feb 6, 2021.
  1. Mar 26, 2024 at 9:57 AM
    #61
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    Thanks Fergie.
  2. Mar 26, 2024 at 10:04 AM
    #62
    JohnWhicker
    JohnWhicker New Member
    So this mod won't work for the CrewMax?
  3. Mar 26, 2024 at 12:17 PM
    #63
    shmabs
    shmabs New Member
    The console mod will work on a crewmax, I just finished installing mine. The difference is the rear most facing light on the console, the crew max console has a blank plate here as the crew max trucks have a separate rear light. The double cab overhead consoles have lights in the rear most pocket of the console, or at least I think that's the way it works. The console I installed in my 17 crew max, was also from a crew max and had a blank plate instead of a lighting fixture.
  4. Mar 26, 2024 at 12:18 PM
    #64
    lerbud1
    lerbud1 New Member
    Larry
    Waco, TX
    2021 Tundra SR5
    What is the clip part# that is needed?
  5. Mar 26, 2024 at 12:22 PM
    #65
    shmabs
    shmabs New Member
    I couldn't find this in a few online breakdowns. I had to adapt to not having them, I would not recommend installing without them.
  6. Mar 26, 2024 at 12:39 PM
    #66
    Fergie
    Fergie New Member
    The diagram on page one is showing 63412B and 63317A for the screw.
  7. Mar 26, 2024 at 1:07 PM
    #67
    shmabs
    shmabs New Member
    Thank you!
  8. Mar 26, 2024 at 1:56 PM
    #68
    Fergie
    Fergie New Member
    This is the gap at the back of the console:
  9. Mar 26, 2024 at 9:02 PM
    #69
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    Thanks Fergie. So there will be a gap for double cabs but not with crewmax. That is a bummer.
  10. Mar 27, 2024 at 8:11 AM
    #70
    Fergie
    Fergie New Member
    If you can pull the headliner from the donor vehicle, you wouldnt have the gap. More work though, obviously. I thought about do that on the truck I grabbed mine from, but the headliner was torn and broken at the rearview mirror.
  11. Mar 27, 2024 at 8:24 AM
    #71
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    The gap would bother me, however I think I could make some sort of trim piece to cover it.
  12. Mar 27, 2024 at 3:41 PM
    #72
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    if you know how to make this aesthetically pleasing, please let me know! i have this done and while i can't see the gap from the driver's seat, just knowing it's there bothers me
  13. Mar 27, 2024 at 3:51 PM
    #73
    RobertD
    Robert
    DFW, Texas
    I'm thinking either a yeti or Waldo cut out that is peaking out from behind the console would work :rofl:
    I would think a thin piece of plexiglass cut to mimic the shape of the console, painted to match, and then some adhesive or tape to hold it to the console. Just enough to cover the gap without really doing much else.
  14. Mar 27, 2024 at 5:33 PM
    #74
    seydou
    seydou Distinguished Member
    Pay a high school student to 3D print something up. Bet you could sell extras here.
    Fergie likes this.
  15. Mar 29, 2024 at 9:22 AM
    #75
    WFD473
    WFD473 [OP] Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Here you are, Sir. It measures 11.5" from the rear of the console to the front of the light.
    RobertD[QUOTED] likes this.
  16. Mar 29, 2024 at 10:56 AM
    #76
    RobertD
    Robert
    DFW, Texas
    Thank you!
    WFD473[QUOTED][OP] likes this.
  17. May 8, 2024 at 12:38 PM
    #77
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Got this mod done this week. It came from an '07. Got it cleaned up, swapped over my MESO kit, installed, looked great. Then found a problem. 20240505_140500.jpg
    Not sure when it happened, but the harness in the '18 has an additional wire that the '07 didn't have. I kept getting an error that 'speaker wasn't connected' and my phone wouldn't pair. Ultimately just swapped over the harness and speaker keeping my original wiring. Works like a champ now.
  18. May 12, 2024 at 7:51 PM
    #78
    What the!?
    What the!? New Member
    2017 Pro
    After putting it off for a year, I finally got some free time to install the overhead console. Like @Pillslinger i swapped over my Meso to the console. I also swapped the switches since mine were newer just in case.
    No issues at all. I took out the foam after I cut the headliner and put in some sound deadener I had. The harness was plug and play from my 2017.
    I took a pic of the screws and clips you need. It’ll be two of each.
    Overall, really happy how it turned out. Got some more usable space. It took about an hour from start to finish.
    Pillslinger and Northbound Train like this.
  19. May 13, 2024 at 4:46 AM
    #79
    Pillslinger
    Rollin
    SWMO
    :fistbump: looks great! I see you went with the DC extra light option. How's the extra candle power?
  20. May 13, 2024 at 7:01 AM
    #80
    JohnWhicker
    This is a cool mod I would love to do on my 2021. What is the part # for the overhead console, in gray? I don't mind buying a new one at all.
  21. May 13, 2024 at 11:57 AM
    #81
    Pillslinger
    Rollin
    SWMO
    JohnWhicker[QUOTED] and RobertD like this.
  22. May 14, 2024 at 8:32 AM
    #82
    JohnWhicker
    Pillslinger[QUOTED] likes this.
  23. May 14, 2024 at 8:52 AM
    #83
    What the!?
    2017 Pro
    The extra light was a nice bonus. I happen to have a couple of extra LED bulbs that I swapped in. Works great!
  24. May 14, 2024 at 9:49 AM
    #84
    Pillslinger
    Rollin
    SWMO
    :hattip:
  25. May 27, 2024 at 6:17 AM
    #85
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    What the!?, do you happen to have the p/n on the lighted console? I'm a whore for lighting and I'd love to illuminate the kids in the back a little more :yes:
  26. May 27, 2024 at 9:56 PM
    #86
    What the!?
    2017 Pro
    This is the PN the seller had on his eBay auction when I bought it. Hopefully this is the right one.
    63650-0C220-E0
    #86
