TRD Sway Bar 2023 1794
Discussion in '3rd Gen Tundras (2022+)' started by LouALouA, Mar 23, 2023.
  1. Aug 11, 2024 at 8:41 AM
    #91
    maldo012
    maldo012 23 tundra hybrid
    Eric
    Chicago
    23 Tundra Hybrid-Limited
    3inch dobinsons ims struts w/Rough Country 1.5inch spring/M1 shocks in the rear— Icon Uca — Hostile maniac 20inch w/general grabber atx tires — Perry parts front bumps - alpharex luxx headlights— swapped many parts with trd body components— race off-road trd grill etc
    so did you end up needing the 90105-A0232 bolts and PT983-34340 cap , link adapters? and you used the 48820 and 48810-0c030 stabilizers? For the trd sway bar?
  2. Aug 24, 2024 at 3:06 PM
    #92
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    Ok.... I am getting to this late... I wanted to wait until I completed the install before giving further advice.. Had this stuff laying around for months and figured today was the perfect day to get it done (Been working on the wife's 4runner and house stuff most weekends). Here is everything I know from my experience today.
    For reference, I am installing this on a stock suspension SR5. This is what I did to replace the front black antisway bar for the red TRD antisway bar.
    Parts needed:
    1X Bar Sub-Assy, FR Stabilizer
    Part Number: 48804-0C020
    1X Link Assy, FR Stabilizer, LH
    Part Number: 48810-0C030
    Part Number: 48820-0C030
    Removing the stock bar and end links was easy. Retain the 4 bolts that attach the brackets to the frame, the 2 bolts to attach the end link to the control arm, and the 2 nuts that attach the end links to the sway bar ends. I discarded the stock sway bar and the stock end links.
    Now I ran into some confusion when laying out the new equipment. I ordered the longer bolts and caps(spacers) as mentioned above. However, When I compare the stock end links to the TRD end links, they appear to be the same thickness. These are not thicker!
    Here is a comparison of the stock end link to the TRD end link. Stock on the left and TRD on the right. You do need the new end links due to the angle of the studs compare to the stock ones. Part numbers listed above.
    Now I took a break and did a bit of digging. I found the instructions for the 3 inch TRD lift kit and also looked up some install videos. The end links part numbers referenced in the instructions and video are different than the TRD ones used for this sway bar. These are black end links and are noticeably different in size and construction. Also, some pictures of TRD Pros show the silver end links that are angled the same why that my new ones and no caps(spacers).
    Check out this video at minute mark 56:00, they install the lift kit end link and the cap/longer bolt... these are not what is used for this TRD sway bar. So don't order those longer bolts and caps for this upgrade.
    https://www.youtube.com/watch?v=MKDMZraUBjs
    Also used this picture as reference for the TRD Pro setup. You can see these do not use the caps and the bolts resemble the stock ones.
    Mocking up the end links on the studs, you can tell you don't need the longer bolts.
    Installing the new red one was simple. Reusing all the hardware that the black one used. My advice is to attach the end link to the sway bar then to the lower control arm. once those are attached, raise up the bar and attach to the frame.
    I am using the TRD Pro BBS wheels but I do not have any rubbing.
    Heres more pictures. I also attached the TRD skid plate after this.
    STOCK:
    UPGRADE:
  3. Oct 7, 2024 at 2:43 PM
    #93
    lunar_rock_sr5_24
    lunar_rock_sr5_24 New Member
    Sorry to bring this thread back but what is the torque spec for the 4 bolts that mount to the frame?
  4. Oct 8, 2024 at 6:37 AM
    #94
    sudobash
    sudobash New Member
    @lunar_rock_sr5_24
  5. Oct 8, 2024 at 7:52 AM
    #95
    lunar_rock_sr5_24
    Thank you! One more thing what is the torque spec of the endlink that is connect to end of the sway bar not the control arm? Also got a link to all the torque spec?
  6. Oct 8, 2024 at 7:55 AM
    #96
    sudobash
    sudobash New Member
    @lunar_rock_sr5_24 - Did you even read all the pages of this thread?
  7. Oct 8, 2024 at 7:56 AM
    #97
    sudobash
    sudobash New Member
  8. Oct 8, 2024 at 10:42 AM
    #98
    lunar_rock_sr5_24
    Thank you!
    sudobash likes this.
  9. Oct 8, 2024 at 10:50 AM
    #99
    lunar_rock_sr5_24
    Ohhh I guess I skipped over the info. Thanks again @sudobash
  10. Oct 10, 2024 at 10:59 AM
    #100
    Rocco2Gen
    Rocco2Gen New Member
    Rocco
    202e Tundra TRD
    2023 TRD Sport
    Thank you everyone for getting to the bottom of this upgrade option.
    maldo012 likes this.
  11. Oct 10, 2024 at 12:41 PM
    #101
    CringyDad
    CringyDad New Member
    Scott
    Fresno, CA
    2024 Tundra 1794 TRD (blueprint/saddle tan)
    Nothing.
    May I ask why anyone would want a stiff sway bar on a truck where compliant suspension and independent wheel travel/articulation are advantageous. Personally, I have zero drivability issues with my stock TRD/OR suspension, either on or off the pavement, so the thought of spending $500+ on a stiffer sway bar seems like a waste. If I'm wrong, please enlighten me.
  12. Oct 10, 2024 at 12:46 PM
    #102
    az 3rdGen
    Arizona
    cuz it red...
    jk. personally, I prefer the stiffer handling when driving around town. This is my daily and not an off road toy for me.
    CringyDad likes this.
  13. Oct 10, 2024 at 2:19 PM
    #103
    CringyDad
    Scott
    Fresno, CA
    Nothing.
    The red does look good, no argument there. :)
  14. Oct 13, 2024 at 7:39 PM
    #104
    lunar_rock_sr5_24
    When I lift it I wanna have more torsional stability that the solid TRD sway bar provides. Don’t really plan to rock crawl more high speed desert stuff.
  15. Oct 13, 2024 at 10:56 PM
    #105
    Tom976
    Tom976 New Member
    Tom
    Your TRD offroads may already have the sway bar in question. Non trd models have a slighlty smaller diameter front sway bar.
    So as you complement your zero disability issues, the lower trim folk can lessen that truck roll.
    I have a 23 1974 myself. I dont mind doing trd upgrades.
    Their fairly solid upgrades and will last the life of the truck as any oem part.
  16. Oct 17, 2024 at 10:41 AM
    #106
    CringyDad
    Scott
    Fresno, CA
    Nothing.
    I suppose that could be true; however, my sway bar is black. Not sure if that means anything or not.
  17. Oct 17, 2024 at 4:03 PM
    #107
    lunar_rock_sr5_24
    So the black sway is larger in diameter however is a hollow bar. The trd pro is solid and slightly smaller in diameter in theory it should be better.
  18. Oct 17, 2024 at 4:34 PM
    #108
    Raven67
    Raven67 New Member
    Central Ky.
    24 Limited
    Not sure if I'd want to do this or not, my truck drives great, I'd hate to make it stiffer. But a good thread & I saved all the part #s just in case. Thanks to all that contributed.
