50statesoverland - 2018 SR5 Cement CM Overland Build
Discussion in '2.5 Gen Builds (2014-2021)' started by itsdchz, Feb 14, 2018.
  1. Feb 20, 2018 at 10:45 PM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    We gonna see that bad boy on some dirt soon?
    Sunnier and itsdchz[OP] like this.
  2. Feb 20, 2018 at 10:59 PM
    SlickRick2013Tundra
    SlickRick2013Tundra #10
    Rick
    Mandeville, LA
    13 TRD CM MGM 4x4
    Toytech Boss 3in Lift kit Iron Cross side step TRD Sway Bar TRD Cold Air Intake Blacked out Badges Blacked out front and rear bumpers
    Definitely watching this thread...great looking tundra and sick build man
    itsdchz[OP] likes this.
  3. Mar 5, 2018 at 3:42 PM
    itsdchz
    itsdchz [OP] 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    Added the HiLift and Rotopax to Rack:
  4. Mar 5, 2018 at 3:46 PM
    itsdchz
    Clovis, CA
    After our trip 2 weeks ago to Utah, without the trailer, I did not like the cab area full of the luggage and such for the trip. Too cluttered. I promptly ordered the AeroBox from www.ecoological.com and am very happy with the results, and how easy I can remove it, store it, or get it out of the way for loading into the bed. It even has wheels for transporting. I had one small install issue, and they promptly sent me the replacement hardware AND changed their hardware that is sent, and directions, based upon my recommendations. VERY AWESOME Customer service! If you order. Tell Grant that Lee sent you! They are offering a deal for Free shipping right now. Email them for a special code!
    As you can see, I took the pics in the rain, and the inside stays nice and dry!
    Stroke250, joonbug, TRD15559 and 2 others like this.
  5. Mar 5, 2018 at 5:40 PM
    [DELETED]
    [DELETED] New Member
    Jeff
    That looks cool. Never seen boxes like that before.
  6. Mar 6, 2018 at 5:12 AM
    itsdchz
    Clovis, CA
    I know! The fact that they work, and hold a lot are great! We ran to IKEA this weekend. 2 minutes later I had the aerobox out and was able to load everything and put the box sideways in bed, and not a worry at all. Unloaded, and a minute later aerobox was back in ready to go!
    Watt maker and [DELETED][QUOTED] like this.
  7. Mar 6, 2018 at 7:14 AM
    [DELETED]
    Jeff
    So cool.
  8. Apr 3, 2018 at 5:01 PM
    itsdchz
    Clovis, CA
    Few from the weekend:
    MTN_Tun, Stroke250, joonbug and 3 others like this.
  9. Apr 6, 2018 at 10:56 AM
    itsdchz
    Clovis, CA
    SSO Slimline comes next week, and the front chrome will be painted blank even removed for install. Cannot have the rear inconsistent from the front, so... until rear bumper is acquired:
    Clean, sand,mask.
    3-4 coats Duplicolor Bumper Trim.
    3-4 coats Duplicolor Spray on Bed Liner!
    Watt maker likes this.
  10. Apr 6, 2018 at 1:28 PM
    itsdchz
    Clovis, CA
    Thank you very much!
  11. Apr 11, 2018 at 9:27 AM
    itsdchz
    Clovis, CA
    Commence the install of SR30 LED Bar and the X20 winch.. Then on to some cutting!
  12. Apr 12, 2018 at 5:18 AM
    itsdchz
    Clovis, CA
    Added the SSO Slimline last night. Took too much on for the night with the painting off the end caps as well. Finished at 2:30am with a little alignment issues of the end caps that I can fix later. But more importantly the X20 could not fit with the SR30 Rigid, and the solenoid is just sitting next to it. I will need to reposition that as well.
  13. Apr 12, 2018 at 9:28 AM
    itsdchz
    Clovis, CA
    UPDATE UPDATE UPDATE
    Talked to Kevin at SSO im great length. It seems they have had one other problem with the fitment and thought it was just the winch (Not an X20 or Xeon). The tabs they use for the lightbar mount are standard tabs. The Tundra being so shallow seems to need a little more cut out of the tab mount to allow the bolt to drop a little further down and out towards the front of the bumper. Due to this issue, there will be a redesign (slight) of the bracket, which will basically consist of extending the hole a little more where the bolts slide in. This will make the light bar flush, or protruding from the front slightly, rather than flush to the inside metal wall of the bumper. Not a big deal at all, but if it stops the possibility of such a tight fit, then it is a good thing
    Incidentally, the Heise and BD bars are not nearly as deep and "styled" like the Rigid has for heat sinks, and this is where the issue is, the Light bar. It is all a learning experience, and I have to commend Kevin at SSO for being right there with me and taking the time. They have been excellent, and ever offered a discount that I declined, as the money doesnt mean as much as the support and empathy.
    I will drop the bumper, use a dremel to bring the tab mount forward a little, and figure out the relocation of the solenoid to a better more aesthetically appealing position (for my peace of mind).
    Hope this dialogue helps everyone!
    Copper Man and pbcolt like this.
  14. May 11, 2018 at 9:02 AM
    itsdchz
    Clovis, CA
    Updated SSO install pics after a slightly better placement of the SR30. I dremeled the mount as much as I could to bring the light forward, but it still doesn’t fit as well as it should. Also zipped down the control box solenoid and double sided taped it.
    Added the Smittybilt 8’ extension as well for the winch power.
    Adjusted bumper ends for better fit and even lines..
    WolfPac_Outdoors and Watt maker like this.
  15. May 11, 2018 at 9:11 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    curious about this. are you running your CB through this or the one attached to the bed? i've been looking for options to replace the AM/FM factory antenna with a Firestik for the CB. i'll be putting the HAM antenna into the roof. any info you have would be appreciated.
  16. May 11, 2018 at 9:13 AM
    itsdchz
    Clovis, CA
    Pics from Pismo prior to updated SSO mounting:
  17. May 11, 2018 at 9:16 AM
    itsdchz
    Clovis, CA
  18. May 11, 2018 at 9:55 AM
    itsdchz
    Clovis, CA
    Firestik in bed is for HAM and the lack of flexibility on the AM/FM, along with a very thin screw into the antenna base, has caused it to snap 2 times for me. I have since returned to stock until I can figure out a stronger attachment, or more flexible CB looking antenna.
    smslavin[QUOTED] and GodlessPro like this.
  19. May 11, 2018 at 10:21 AM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Am I correct that that is only a 2M antenna or do they make a dual band? My favorite Diamond antenna got snapped off by a tree the last time out, so I need to find something more forgivable to using on outings.
  20. May 11, 2018 at 12:14 PM
    #50
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    i'm going with two different antennas. a comet ssb-1 nmo for on the trail. it's short, 16", and flexible so it'll bend if you hit a branch. then i'll use a longer ssb-5 nmo for longer road trips or more open trails like down in the swell.
  21. May 11, 2018 at 12:29 PM
    #51
    GodlessPro
    Matthew
    NorCal
    I'll take a look at the ssb-1, flexible would be nice. I'm going to be using my short Diamond NR72B until I get a new 1/2 wave.
  22. May 17, 2018 at 1:57 PM
    #52
    itsdchz
    Clovis, CA
    Changed to mount of the iPad from the floor with extension to the dash:
    The rubber cover will cover up any holes. Drilled one for the power cable too.
    All RAM mount pieces. I took the setup from my 4Runner based on Lifestyle Overland's setup:
    Parts list:
    http://www.lifestyleoverland.com/ram-mount-solutions/
    Tried to mount it to the floor of the Tundra, but it wasnt very secure. Decided.."What the Hell, might as well drill it down to be stable, and cover it up when/if I remove" Sure enough, quick and easy. It uses the X-Grip RAM mount, RAM 2.5" Round ball mount on the RAM mount iPad holder, and one on the dash, and 2 of the Short Double Socket Arms and 1 of the Long length Socket Arms.
    TRD15559, joonbug and Watt maker like this.
  23. May 24, 2018 at 3:37 PM
    #53
    GodlessPro
    Matthew
    NorCal
    Where did you have the color matched grill surround and bulge done and how much did it cost?
    joonbug likes this.
  24. May 24, 2018 at 4:21 PM
    #54
    itsdchz
    Clovis, CA
    GodlessPro[QUOTED] likes this.
  25. May 24, 2018 at 4:24 PM
    #55
    GodlessPro
    Matthew
    NorCal
    joonbug likes this.
  26. May 24, 2018 at 4:30 PM
    #56
    itsdchz
    Clovis, CA
    Last I knew, you can order the hood bulge and surround for a trd pro model. That’s what I did.
  27. May 24, 2018 at 4:32 PM
    #57
    itsdchz
    Clovis, CA
    joonbug and GodlessPro[QUOTED] like this.
  28. May 24, 2018 at 4:33 PM
    #58
    GodlessPro
    Matthew
    NorCal
    Ordering a '17 makes sense if you just need the surround. I asked him specifically about an '18 honeycomb grill with cement surround.
    joonbug likes this.
  29. May 24, 2018 at 4:34 PM
    #59
    GodlessPro
    Matthew
    NorCal
  30. May 29, 2018 at 8:40 AM
    #60
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Yep, if you like the insert you have, ordering the Pro grille is the way to go. If you don't like it, ordering a Sport/Platinum grille and having the surround painted is what you'll need to do.
