0 offset with 3 in lift
Discussion in 'Wheels & Tires' started by Dustydirt19, Feb 27, 2017.
  1. Mar 2, 2017 at 9:05 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Agreed! That being said, I just pulled the crap-tastic plastic from the front of the wheel well since that's where it was rubbing (mind you, no lift yet). I was then able to pull the bumper ends forward to their limit and re tighten the screws holding them in. Voila! No more rubby in the front.
    FYI a CMC is needed when the wheels are at full turn.
    The Juice[QUOTED] likes this.
  2. Mar 3, 2017 at 7:34 AM
    Dustydirt19
    Dustydirt19 [OP] Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    What was the process you had to do with the fender liner?
  3. Mar 3, 2017 at 7:35 AM
    Dustydirt19
    Dustin
    Duluth, MN
    What was the process you did to clear the liner?
  4. Mar 3, 2017 at 7:36 AM
    Dustydirt19
    Dustin
    Duluth, MN
    What was the process for clearing the liners?
  5. Mar 3, 2017 at 7:41 AM
    Bear
    Bear
    Custer, SD
    Easy dustydirt...
    You could use a 10mm socket and remove the screws...they pop right off
  6. Mar 3, 2017 at 7:50 AM
    Dustydirt19
    Dustin
    Duluth, MN
    You just took them off all together or chopped them then put them back on?
  7. Mar 3, 2017 at 8:14 AM
    Bear
    Bear
    Custer, SD
    I just took mine off, but then again, I'm going a 6 in lift next week so they'll likely go back on
  8. Mar 3, 2017 at 12:49 PM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    I marked mine before I took them off so I knew what had to be chopped.
    Then I removed them and cut them out using a Fein tool. It took all of 15 minutes per side. Pretty easy
  9. Mar 5, 2017 at 3:46 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I just took two screws off from the bottom, pushed the liner forward as far as I can, drilled two new holes, and put the screws back on. I have 2010 though. From what I understand, 2014+ models are more difficult to work on.
  10. Nov 15, 2018 at 7:02 PM
    Bmxrider1331
    Bmxrider1331 New Member
    Brendan
    NEW JERSEY
    2013 tundra 4x4 4.6....
    3 inch toytec eibach kit on 35s
    Soooo I guess 17x8.5 0 offset on a 35x12.5 will fit on a 3 inch lift ;) but with alot of cutting...??? Anyone quickly
  11. Nov 15, 2018 at 7:22 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    35x12.5 should clear with BMC and UCAs that give enough extra caster with +0
  12. Nov 15, 2018 at 7:38 PM
    Lambeau
    Lambeau New Member
    2024 Black Tundra 1794 Limited Edition
    285/60/R20 BF Goodrich KO2’s
    Wouldn’t wheel spacers fix the problem?
  13. Nov 15, 2018 at 7:41 PM
    ninjajay
    Spoolston, TX
    At that size spacers will make it worse
  14. Nov 15, 2018 at 8:00 PM
    Bmxrider1331
    Brendan
    NEW JERSEY
    I'm keeping stock ucas
  15. Nov 15, 2018 at 8:00 PM
    Bmxrider1331
    Brendan
    NEW JERSEY
    To pricey. I'm gunna have them do 3* or atleast try
  16. Nov 16, 2018 at 4:34 AM
    ninjajay
    Spoolston, TX
    It's gonna be close if it works at all
  17. Nov 16, 2018 at 4:36 AM
    Bmxrider1331
    Brendan
    NEW JERSEY
    I talked to 2 guys at toytec and they didnt seem phased at all. They were like yeah that will work but your gunna do the obvious triming. I even asked about the ucas and he said you'll be fine. So the only thing I guess I'll have a problem with is the alignment
  18. Nov 16, 2018 at 4:37 AM
    ninjajay
    Spoolston, TX
    Did you tell them you were running +0 with 35x12.5?
  19. Nov 16, 2018 at 4:37 AM
    #49
    Bmxrider1331
    Brendan
    NEW JERSEY
    You think a +18 would make that bette? Ucas are way to pricey
  20. Nov 16, 2018 at 4:38 AM
    #50
    Bmxrider1331
    Brendan
    NEW JERSEY
    Yes. Apparently the "boss" had the same setup but then got ucas cuz alignment
  21. Nov 16, 2018 at 4:40 AM
    #51
    ninjajay
    Spoolston, TX
  22. Nov 16, 2018 at 4:42 AM
    #52
    Bmxrider1331
    Brendan
    NEW JERSEY
    That's a 3rd gen. but still works. I found a guy on Instagram with the setup with stock ucas. He told me to not and sent me pics. I was suprised I wish he joined this thread
  23. Nov 16, 2018 at 4:43 AM
    #53
    Bmxrider1331
    Brendan
    NEW JERSEY
    The guy has a 2011 doing it with a mean cab mount chop
  24. Nov 16, 2018 at 5:00 AM
    #54
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    Ignore me. Apparently I had it ass-backwards
  25. Nov 16, 2018 at 5:59 AM
    #55
    Bmxrider1331
    Brendan
    NEW JERSEY
    What happened
  26. Nov 16, 2018 at 9:57 AM
    #56
    airgunner
    N-KY
    2015 DC MGM TRD
    Nothing I was thinking a +18 would stick out further then a 0 or +1 (makes sense no?) but after looking it up, I was apparently wrong.
    Bmxrider1331 likes this.
  27. Dec 13, 2018 at 11:38 AM
    #57
    Bmxrider1331
    Brendan
    NEW JERSEY
    Fitment after work:benchpress:
  28. Dec 13, 2018 at 4:25 PM
    #58
    Bmxrider1331
    Brendan
    NEW JERSEY
    BMC. And little mud flap out
    Bear likes this.
  29. Sep 23, 2019 at 5:14 PM
    #59
    Keithbickford
    Keithbickford New Member
    Keith
    Seattle
    2020 Cavalry Blue Tundra
    King 2.5” suspension, Method Race 313 wheels, Nitto Ridge Grapplers 35x12.5x17, TRD exhaust, RCI Skid Plates, Alpine ILX-F309 stereo, Alu-Cab roof top tent on Yakima Overhaul HD, Line-X spray in bed liner, VLED LED reverse light bulbs and VLED LED license plate reverse light. VLED brake/tail light bulbs. VLED third brake light and cargo lights.
    Dealers are independent companies and work done by them that is not in accordance with manufacturer's guidance is just the same as that work being done at any other third party place. Manufacturer's are not allowed to require us to have our vehicles serviced at a dealership. I'm not saying a lift doesn't void a warranty or at least cause warranty challenges, but it should not matter where you have it done. My local dealer lifts brand new trucks on the show room floor. We also have a third party shop here (Rad Customs) that sells brand new Chevy and Ford trucks that are highly modified. They are not affiliated with the manufacturer.
  30. Aug 26, 2020 at 10:49 AM
    #60
    a_double
    a_double New Member
    So 33x12.5 on 18x9 +0 will work without BMC? What about mid flap removal and fender trimming? TIA.
    BettyWhite20 likes this.
