08 Tundra issues
Discussion in '2nd Gen Tundras (2007-2013)' started by ant71992, Mar 26, 2019.
  1. Mar 31, 2019 at 4:13 PM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    That's the carrier bearing. I think there is supposed to be a little play, at least my 07 with 180000 has a little play. You said it was a lot you may want to start there, or at least have a mechanic check it.
  2. Mar 31, 2019 at 4:28 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    That could be your problem
  3. Mar 31, 2019 at 4:35 PM
    ant71992
    ant71992 [OP] New Member
    Yea, checked the play on my 03 Tundra and there is some but it looks like there are no tears. In my 08, there is plenty of tears on it.
  4. Apr 1, 2019 at 9:18 PM
    ant71992
    Well I’ve had enough of the guesses. I feel that if it is transmission related I am only going to make the problem worse by waiting. I made an appointment with the dealer to inspect it this Saturday.
  5. Apr 1, 2019 at 9:37 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I'd be suspect of any of the ignition coil packs that were affected by the oil leaking into the spark plug tubes. And I'd be rechecking for oil in the tubes and on the spark plug isolators.
    Have them check the misfire count data while they are diagnosing, (Not just for misfire codes)
  6. Apr 2, 2019 at 8:30 PM
    ant71992
    Well I was driving it today and it shuddered pretty damn hard around 30 mph. Looks like I’ll be driving my first gen for a bit. Man this sucks!
    What I suspect is the previous owner did not maintain the truck properly and he let it go to shit. I swear he probably used that shudder fix because it did not shudder when I test drove it.
    Now I’m going to shell out lots of money to fix it. If the dealer wants to charge me 1300 for a damn valve cover fix, I can only imagine what they want for transmission work.
    This blows.
  7. Apr 2, 2019 at 9:56 PM
    Throwwire
    Throwwire New Member
    Gerry
    Humboldt county
    08 ext cab,16 platinum crew
    08 leveled 35s fab four bumpers light bars 16 leveled
    I think it's something alot more simple then a transmission.
    Sounds like usually comes on at a certain speed. Your already into it, get it fixed and drive it till the wheels fall off, which they wont. Ever., I have an 08 and beat the living shit out of it and all ive every had to do was put brakes on it , I'm at 180k I offroad it, river bar doughnuts, tow 10k of rock up 1000ft climb to my house, pull trees off the road,and not just off the road. I'll pull till the tree breaks or the truck stops, that truck is bulletproof you just have to figure out its 1 issue.
    Trooper2 likes this.
  8. Apr 3, 2019 at 3:09 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Let’s see how I can again break this down ...
    If you feel comfortable changing the spark plugs in a (simple) car, then double that feeling and then you now can change the VCG plus plugs!!!
    And instead of paying $1300, you can save $1150.........
    ....are you up for the challenge with some simple tools and a extra pair of hands?
    Yaaah?? Eh Nada??? This is no commercial.
  9. Apr 3, 2019 at 5:39 AM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    Does it have a lift? If so it may need the carrier bearing dropped. When I did my lift I got the same shudder you speak of
    If no lift it still could be the U joints before the get sloppy the freeze up the the needle bearings in the cups self destruct then the get sloppy but if there in the frozen state they can cause a nasty shudder/vibration only way to tell is take the D shaft out and check them for ease of movement
  10. Apr 5, 2019 at 8:07 AM
    Tamutundra
    Tamutundra New Member
    Frisco Tx.
    19 super white CM TRDoffroad 4x4
    Ant did you happen to find the problem of the shudder yet? This just started yesterday with my 08... she has been mine since day one I have driven all of her 276K miles on her.... so it is not an abuse of truck problem... just old age I am afraid... haven't looked under her yet but I have the same shuddering feeling while at a decent speed and giving a lil more gas... I have no clue what the problem is... I will take a glance under her later and see if the carrier bearing looks similar to yours.. if you determine what is causing the shudder could ya please let us know.... thanks... Tamu
  11. Apr 5, 2019 at 11:54 AM
    ant71992
    I have not. I am taking it to the shop tomorrow. I will let you know what they say.
    Tamutundra likes this.
  12. Apr 6, 2019 at 9:33 PM
    ant71992
    Update: Wow, this purchase is becoming more of a nightmare by the second.
    So the truck is still with the dealer. They did call me up and said what they think and it is not good. They think it’s the torque converter. They’re still going to check other things and see if they can fully rule out the torque converter. I’ll get a full answer tomorrow.
    The biggest problem is that the dealership noticed a discrepancy in miles. Turns out I got scammed hard. The true mileage is around 245,000 last reported. The odometer is wrong and I don’t know if the previous owner rolled it back or the owner before that.
    On the plus side, the truck barely shuddered when driving with the technician. Hopefully, all it needs is a transmission service.
    I am so bummed out. This is one huge lesson for me. I am young and inexperienced, a perfect target for scammers.
  13. Apr 7, 2019 at 12:48 PM
    ant71992
    I just got it back today.
    It is in fact the torque converter.
    They recommended a new transmission with an estimated price tag of $7,000.
    I am just going to rebuild the transmission where my father had his F150 rebuilt at. He charged him $1,500 and that was a year ago. And my father uses his F150 for work everyday so he did a great job.
    Tamutundra[QUOTED] likes this.
  14. Apr 8, 2019 at 1:38 PM
    Tamutundra
    Frisco Tx.
    wow... that sucks.. sorry bout that and the whole turning back mileage... If you bought this from a so called dealership you should have some recourse if they misrepresented mileage... hope you get it fixed... mine is a hit and miss feeling.. drove her yesterday and didnt happen once.. I will be looking I to a new truck with in the month thanks for the info and good luck!
  15. Apr 14, 2019 at 5:53 PM
    jallen1982
    jallen1982 New Member
    Jeremy
    2008 Tundra SR5
    It may have already been mentioned. But for your shaking problem, I would check your drive shaft carrier bearing.
  16. Apr 14, 2019 at 6:34 PM
    ant71992
    It’s the torque converter for sure. I added a bottle of the shudder fix and the problem went away completely. But I know I am on borrowed time. Still deciding whether to rebuild or just get a new transmission.
  17. Apr 18, 2019 at 5:04 PM
    E-Ski
    E-Ski New Member
    E-Rock
    2007 tundra RCSB
    3" lift, true duel exhaust, XD rims, custom grille, drilled and slotted rotors
    I have an 06, it had the same vibration. Turned out it was the parking brake staying slightly engaged, cables needed to be replaced. Even after replaced cables the vibration came back, I found if I tapped on the sheathing where the cables go into the rear disks it would be enough to dislodge the parking brake and no more vibration. So now I never use the parking brake ever!
