15 tundra differential fluid change and drain plug gaskets
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1794TRD, Oct 6, 2017.
  1. Dec 20, 2018 at 8:13 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Well shit. Now THEY tell me.
    I have $140 worth of 75W90 (I bought two gallon jugs) sitting in my geeeeerage. Sigh. That's what's going in her when I get to it. I'm at 42,500 miles right now. So just when the time and weather are right for me.
    Xsnrg2006 likes this.
  2. Dec 25, 2018 at 11:28 PM
    l3LUEFALCON
    l3LUEFALCON RIG MECHANIC
    Josh
    North Houston Area
    2014 5.7 FFV MGM CM SR5 4WD TSS-OR AKA: MILDRED
    (DIY) CB Radio, Tool Box, ESP Under seat storage, Husky front/ Weather tech rear floor mats, (DIY) Console Safe (Bio-metric), 275/60/R20 Conti Terrain Contact, Magnaflow Exhaust, Katskin leather seat covers, LRA 46 gallon replacement fuel tank, TRD Pro shocks Front/Rear.
    I've used this Ravenol now for more than 25,000 miles (Used it on all my other vehicles too). It purrs like a kitten. This stuff is legit and there is a lot of science that goes into developing this and matching it with the equipment. If it comes to mechanical know how, the Germans know exactly what the're doing. Don't get me wrong, the Japanese do too, but I'm going with the Germans on this one.
  3. Mar 2, 2019 at 3:24 PM
    crishard
    crishard Occasional Member
    Cris
    2014 Barcelona Red CM
    3" level in front, ICI Bumper & Skid, 12k lb winch, UCAs, Radtech 2.5s, Kenda 35s, Dual Batteries, 3500w inverter
  4. Mar 3, 2019 at 5:32 AM
    crishard
    Cris
    Here is the VOA (virgin oil analysis) for Toyota's 75w gear oil. Many manufacturers do not have a comparable gear oil.
    From what I've read, the two most important values are in the Properties shaded section where it says "values should be".
  5. Mar 3, 2019 at 5:45 AM
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    I used the Revoil in the rear Diff. As far as i can tell it decreased my MPG a little, but then again it could be due to the cold weather starts in the AM to warm up the truck. I would think that the German oil system and testing will exceed all manufacture standards.
  6. Mar 3, 2019 at 11:17 PM
    aldouschiu
    aldouschiu New Member
    aldous
    2017 Tundra 1794
    Hi @1794TRD,
    I have 2017 Tundra 1794. I am about to do transfer case fluid change. I figured the transfer case drain plug and fill plug changed. I wonder if the torque spec is still the same 27 ft lbl? Let me know if you have this information!!
    Thanks,
    Aldous
  7. Mar 4, 2019 at 5:07 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    I recently changed the transfer case and differential fluids on my truck.
    Rear differential and transfer case were easy, but the front differential was a problem.
    I couldn't remove the drain plug and I had to take it to a mechanic, not the dealership.
    I have since read this is a fairly common problem and the drain plug tends to come from the factory over tightened.
    I reused the the washers that were originally installed and I haven't had any leaking. I probably flipped the washer before reinstalling, but I'm not sure.
    Good luck.
  8. Mar 4, 2019 at 10:39 PM
    acmesupply
    acmesupply New Member
    2018 SR5 CM Silver TRD
    Please review the Ravenol 75w mtf3 voa I posted and compare to OEM Toyota. Similar viscosity , yes, similar wear package, no.
  9. Apr 12, 2019 at 1:31 PM
    Krabage
    Krabage New Member
    2014 DC TRD
    does anyone have the torque specs for the 14' on the front diff, transfer case and rear differential, both drain and fill plugs? TIA
  10. Jun 16, 2019 at 4:48 PM
    tAcomaPueblo
    tAcomaPueblo New Member
    Tampa Bay
    2014 SR5 TRD OR CM 4x4
    Ever find the torque specs? Selling my tundra and I want to ensure all the fluids are good to go so i want to replace the transfer gear and differential oils.
  11. Jun 16, 2019 at 5:02 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Rear is 38 and front is either 26 or 28. I have it written down somewhere and will verify.
    Hartc90 and tAcomaPueblo like this.
  12. Jul 20, 2019 at 3:14 PM
    Hartc90
    Hartc90 New Member
    2015 Toyota Tundra Crewmax
    Anyone know the torque specs for the rear diff filler and drain plug? I’m trying to find it on the inner web.
  13. Sep 21, 2019 at 4:27 AM
    tstieb
    tstieb New Member
    2014 CM TRD
    Know this is old but for future reference:
    Rear: 36ft lbs
    Front: 29ft lbs
    Tc: 26ft lbs
    Found this from a you tube video, so...
    Flyinryank and _Jim_ like this.
  14. Apr 22, 2020 at 7:13 AM
    Xsnrg2006
    Xsnrg2006 Smiley the Tundra
    Dale
    SoFla
    2006 Limited Crew Cab
    Was it over when the Germans bombed Pearl Harbor?
    NO!!!
    Haggis777 and Rex Kramer like this.
  15. Jun 30, 2021 at 5:25 PM
    CTundraForMe
    CTundraForMe New Member
    I found two places that said the front ones have TWO specs:
    Front diff drain plug - 48 lb-ft
    Front diff fill plug - 29 lb-ft https://empyreoffroad.com/blogs/res...toyota-tundra-diy-maintenance-reference-guide
    However, I also have the service manual and it clearly says 29 for both:
    Maybe this is why one of the plugs is overtightened at times?
  16. Sep 30, 2021 at 10:13 AM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    Edit: I found the answer to my original question below. P/N 9043024003 is for the front diff drain, and is copper. Front diff fill is the same as rear diff drain/fill washers
    For 2014+ trucks, the transfer case plugs are NPT threads that do not have crush washers.
    Which of the part numbers is the copper crush washer? There's discussion in this thread about 2014+ models not needing t-case washers, as well as unique washers for drain vs fill plugs.
