1st Gen General Questions
Discussion in '1st Gen Tundras (2000-2006)' started by FlightSimGuy, Nov 21, 2018.
  1. May 6, 2019 at 3:35 PM
    #121
    Casper421
    In the woods
    06 DC
    I changed the boots on mine and it was a pain in the ass! Messy and time consuming. I recommend buying a cvjreman like @FirstGenVol mentioned or have a shop deal with it.
  2. May 6, 2019 at 4:48 PM
    #122
    FirstGenVol
    East TN
    2002 AC
    I was hoping to get your feedback. I'll take those boots off the list for now.
    FlightSimGuy[OP] likes this.
  3. May 6, 2019 at 5:43 PM
    #123
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    I just replaced the aftermarket CVs the PO had installed with new Toyota CVs. I also installed new Toyota lower ball joints and tie rod ends. I have the upper ball joints, but haven’t done those yet. Plenty of YouTube videos to show you how or if see you even want to tackle it yourself. Having the right tools helps.
    The 2006 white paint should be single stage. If you get the black deposits on it like I do, Zymol works great at removing them.
    The gas nozzles in California suck. This is my third 1st gen Tundra and Costco has just recently changed to nozzles that work without holding them in.
  4. May 6, 2019 at 5:49 PM
    #124
    SoCalPaul
    Paul
    Most shops I talked to won’t do boots. I ordered Replacement boots for Toyota CVs, only to find the PO had installed aftermarket CVs & I had to use 2 outer boots just to fix one side. I ended up ordering Toyota CVs which meant that one side was done twice.
    If yo do them yourself, watch some YouTube videos and mak sure you replace the differential case CV shaft seals. There is a left and a right.
  5. May 12, 2019 at 11:21 AM
    #125
    FlightSimGuy
    FlightSimGuy [OP] New Member
    2006 Tundra SR5 V8 DC
    ICON 2.5 shocks with King 14" 700lb coils, Camburg UCAs, ICON V2.0 rear shocks.
    So I'm thinking of ordering this https://www.cvjreman.com/product/9550-r/ and trying it myself. From reading the comments above changing the axle is easier than the boot. Should I do both sides or just the bad one. Btw, this isn't from the lift, it was torn before.
  6. May 12, 2019 at 1:37 PM
    #126
    FirstGenVol
    East TN
    2002 AC
    I would probably replace the pair, not just one. That's just me though. No harm in doing just one I suppose.
  7. May 13, 2019 at 7:19 AM
    #127
    FlightSimGuy
  8. May 14, 2019 at 9:28 PM
    #128
    FlightSimGuy
    I'm running Kendall full synthetic as that is what the shop has and I've ran Valvoline FS a lot as well. Trying BG MOA as my mechanic highly recommended it. Opinions/thoughts? I'm thinking of switching to Amsoil, does anyone run it and does it live up to the hype? Maybe Amsoil mixed with MOA?
  9. May 15, 2019 at 3:50 AM
    #129
    Professional Hand Model
    Hand Protectors
    I’d just make sure you change the oil 3-5k miles which ever oil you use whether its full syn or dino. Keep it fresh using the proper viscosity.
    Wally wurl has been selling 5 qt mugs of Mobil1 for about $22.
    Mobil1 has a rebate of $12 per 5qt. jug (up to 4 jugs per household). Thats something like $2 a quart!
    Something to consider.
  10. May 15, 2019 at 4:14 AM
    #130
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    I see you are still running the halogen bulbs. I swapped them out for 6k LED bulbs, brighter
  11. May 15, 2019 at 6:36 AM
    #131
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    I think the Mobil 1 High Mileage Full Synthetic is great. Have not had any issues with it, and it is what I run in all of my vehicles. Just my opinion, hope it helps!
    I also second the changing religiously at proper intervals. Even though my full synthetic can go 5K miles, I still change at 3k. Worth it to me.
  12. May 15, 2019 at 7:22 AM
    #132
    Hooptytrix
    Dirty South
    Mobile 1 was group 4 synthetic then they switched to a group 3 to be more competitive price wise with the other brands but I think they switched back to group 4, not sure. The only group 4 synthetic I'm aware of that is readily available is Amsoil and Royal Purple.
    In America, group 3 is petroleum based oil using a different refining process that removes more sulfur. In the rest of the world, group 3 is considered regular oil. Our group 4 is synthetic every where
    FlightSimGuy[OP] and 00TundraZ like this.
  13. May 15, 2019 at 7:23 AM
    #133
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    I was not aware of this. Knock on wood, it has always been a good oil for me as far as I know. All my vehicles have always had over 150,000 miles and the high mileage has been great.
  14. May 15, 2019 at 7:28 AM
    #134
    FlightSimGuy
    Some good info. I still may switch to Amsoil, though. I wonder if their 10-15k oil change is accurate?
    00TundraZ likes this.
  15. May 15, 2019 at 7:33 AM
    #135
    Hooptytrix
    Dirty South
    3k Oil changes are necessary due to the additives that give you the winter rating, 10W would be the winter rating. Right around 2800 miles they begin to separate. In group 3 oil that happens around the 5k mark, group 4 is man engineered with the winter rating from the ground up but still needs changing somewhere around 10k and some as high as 20k. Problem is some group 4 oil does have some petroleum oil in it.
  16. May 15, 2019 at 10:42 AM
    #136
    Hooptytrix
    Dirty South
    I may be wrong but if I remember correctly, Castrol GTX was once upon a Time 1 of the better oils on the market (1970's to 80's). Then came the whole synthetic oil and categories. The GTX oil was rebranded Castrol Syntech, a group 3 petroleum based oil. Now we have synthetic oil from brand under the sun.
    I will clarify though, it is good oil but I wish they would have been more truthful about what it is. Corporate lobbyist doing what they do best.
    On another note. I remember being told many years ago not to use group 4 synthetic in Toyota motors, some crap about the lubricating properties can cause issues. Anybody here running Amsoil?
  17. May 15, 2019 at 3:03 PM
    #137
    Hand Protectors
    I used Castrol on all my original vehicles back when I was young and good looking. Changed oil/filter every 3k and gas filter every 6k. It was so cheap and easy to do both. 3.5 quarts of Castrol and filter was something like $4. Gas filter was $3 with two little spring clamps that took 30 seconds to change.
    Back to the future: That Mobil1 ‘Extended Performance Synthetic’ seems like group 4 as the stuff was climbing out of everywhere in straight even lines (like a haze film). Switched to the ‘Full Synthetic’ and the haze weeps have slowed. Next change is to the ‘High Mileage’ of which I literally backed the truck up on the sale/rebates. Sitting on 6 (5qt) jugs. Getting ready to make another score on more whilst the sale is in effect.
    Hoping on the ‘reconditioning of seals/gaskets’ advertising to work.
    Here is what the ‘Extended Performance’ did the first 1k miles. It really cleaned out my engine and left some cottage cheese snot on the underside of my oil cap. Never saw it before or since the first 1k miles of driving.
  18. May 17, 2019 at 8:39 AM
    #138
    FlightSimGuy
    All this wasted space... Anyone know if there is a way you could attach anything here? I think it would be cool to attach a holder for my binoculars.
  19. May 17, 2019 at 9:07 AM
    #139
    Casper421
    In the woods
    06 DC
    Why stop at binoculars? A fab shop could easily make something similar to this molle rack that mounts to the grab handles.
    https://mesocustoms.com/products/tacoma-molle-rack
  20. May 17, 2019 at 9:12 AM
    #140
    FirstGenVol
    East TN
    2002 AC
    Nationwide Products makes a peg lock system that's neat looking. You don't have to mount your AR-15. You could use it for other things.
    https://acclamp.com/pages/peglock
  21. May 17, 2019 at 10:43 AM
    #141
    FlightSimGuy
    That is freaking brilliant! Binoculars are just the start. I'd like to get my truck organized where I can keep it organized and that would help. Problem is that the driver's side doesn't have a grab handle.:confused:
    That is cool. I wonder how they attached the board, though? And I'm not saying I wouldn't mount my AR-10 to it. :D
  22. May 17, 2019 at 10:45 AM
    #142
    FirstGenVol
    East TN
    2002 AC
    I have no idea but I'd like to know. If you find out please let us know. I'd like to mount some things on the ceiling as well but I don't want to accidentally drill through my roof. :sawzall:
  23. May 17, 2019 at 10:47 AM
    #143
    FlightSimGuy
    Yeah, that's what I'm worried about. I do have two bolts in the roof where the PO had the light bar.
  24. May 17, 2019 at 10:51 AM
    #144
    Hooptytrix
    Dirty South
    This thread has just become very interesting
    Outbound and FlightSimGuy[OP] like this.
  25. May 17, 2019 at 11:33 AM
    #145
    dbcsa
    dbcsa New Member
    2003 toyota tundra sr5
    Does anyone have or know where to buy nfab style side steps for a 2003 Toyota Tundra Access Cab? I can't seem to find any only for the double cab. Thanks
  26. May 17, 2019 at 12:10 PM
    #146
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Looks like my next mod is to fab up a rack to my grab handle mounts! Thanks for the idea guys!
  27. May 17, 2019 at 12:14 PM
    #147
    FlightSimGuy
    Same here. :thumbsup:
  28. May 17, 2019 at 12:33 PM
    #148
    Casper421
    In the woods
    06 DC
    I’ve had this idea in the back of my head for a while but it’s been put on the back burner with more pressing projects to finish first. I wonder how the ac and dc differ in grab handle locations or if it would be universal. Guess I gotta creepily look in an ac, or maybe @Brown Bear can help me out one afternoon.
  29. May 17, 2019 at 12:47 PM
    #149
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Good question. While my father in law and I are fabbing up my flatbed I will have him look at that. He and I both have way too many Molle items :spy:
    Casper421[QUOTED] likes this.
  30. May 19, 2019 at 6:37 PM
    #150
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    What's you're idea?
