  1. Jan 14, 2025 at 10:26 AM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
    Thanks Shifty! going to order today.
    dang ordered the rad, hoses, t-stay and a cap for $200
  2. Jan 14, 2025 at 10:30 AM
    shifty` No Water in the Water Fountain
    Sounds devastating. And to think (A) a considerable amount was apparently intentional/arson while (B) billionaire talking heads are trying to politicize it. The whole situation sucks.
    Glad you and yours are safe. Talk about close calls...
  3. Jan 14, 2025 at 10:54 AM
    Dakillacore
    Dakillacore Professional Amateur
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    Had a nearly fatal incident after my roof repairs......
    The roofer replaced my vent covers for preventative maintenance as they were rusting and pulling up from the roof. This was completed a few weeks ago and all seemed well. Friday my wife decided to go ahead and get the Christmas items put up in the attic since I had the day off. She goes up and I start handing things up to her. Near the end I look up and see some steam rolling around the florescent tubes, which I though was odd. Then I noticed that the roof was extremely saturated around the vents. I automatically assume that there is a water leak now. I then get on my roof to clear the melting snow off the area to prevent any further issues and went back into the attic to put down a tarp and dry off the wood on the roof as much as possible. This is where it gets funky....
    Upon closer inspection the water soaking was more to do with condensation than with a central leak. There wasn't a water line and the water was dripping from multiple spots on the plywood. I start looking further and notice that my gas vent isn't venting at all anymore and the gas/hot vapors are rolling into my attic essentially pumping CO into my living space and has been since they installed the vent. If my attic wasn't vented in the front and back then I'm not sure that I'd still be here to tell the tale. The condensation was from the hot gas interacting with the cold attic.......
    I quickly made my way out of the attic and called the roofers. After 3 days of not having my heat turned on they came out and fixed everything, but not before I had to argue with the CEO of the company that its not HVAC related. The roofer came back out and removed the vent to see if it was vent related and low and behold it vented out of the roof as designed. After this they agreed to cover it all under warranty and now we are back in action.
    That was a close call.
    whodatschrome, Voss, BroHon and 6 others like this.
  4. Jan 14, 2025 at 11:01 AM
    bmf4069
    bmf4069 Something something Miller Lite
    Beau
    TX
    02 AC sr5 4wd v8
    :eek:
    Voss likes this.
  5. Jan 14, 2025 at 11:55 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Do you have a current link to where the best place is to buy the LED's? I did a little google searching....is it one of these here projector kits, and if so, which one? https://www.led-colight.com/collect...0XPqEgCSprL4Jy2N8hNrhFDmPBgzo-gr0DKhKQk2IEfUz
    FiatRunner[QUOTED] likes this.
  6. Jan 14, 2025 at 12:11 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
  7. Jan 14, 2025 at 12:25 PM
  8. Jan 14, 2025 at 12:57 PM
    whodatschrome
    lots of dents
  9. Jan 14, 2025 at 1:23 PM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    2001 Tundra SR5 Access Cab TRD 4.7
    G_unit3000 and 455h0le_dachshund like this.
  10. Jan 14, 2025 at 1:31 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Don’t you have a fire/carbon monoxide alarm like most households? You may want to buy one per your wake up call.
  11. Jan 14, 2025 at 1:55 PM
    Dakillacore
    Georgia
    I have a fire alarm and it's right next to the entrance to my attic door. It must not be dual purpose. It was installed in the house when we purchased it. I'm getting one on my next day off.
  12. Jan 14, 2025 at 1:58 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Make sure to get a dual smoke/CO detector with a built in 10yr battery so you don't have to worry about changing the battery so often.
  13. Jan 14, 2025 at 2:46 PM
    Dakillacore
    Georgia
    Good idea. Thanks for that. I will look into the 10 year battery versions.
    CodyP[QUOTED] likes this.
  14. Jan 14, 2025 at 2:58 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I need to order the dual units too. My house has a hardwire for them. I have NOT been able to find this info online, but if one of them goes off, do they ALL go off?
    They are powered together and wired together
  15. Jan 14, 2025 at 3:20 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm confused reading this. What was the root cause?
    FrenchToasty likes this.
  16. Jan 14, 2025 at 3:35 PM
    Dakillacore
    Georgia
    Sorry about that. The cause was the gas vent pipe that leads out of the attic. The new cover they installed didn't allow the gas to vent out upwards and was venting down back into the attic instead.
    Here's a picture of it. The only way I was able to notice it was because of the hot gas pumping into the cold attic causing the condensation.
    Voss and FirstGenVol[QUOTED] like this.
  17. Jan 14, 2025 at 3:40 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Good catch! Could have been much worse!
  18. Jan 14, 2025 at 3:46 PM
    455h0le_dachshund
    455h0le_dachshund Human tongue feels aluminum plate, it's a missile
    Reverend Hotdog
    TX...big surprise
    Saw this guy at the gym
  19. Jan 14, 2025 at 3:49 PM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    Someone DID try to carry a cord of firewood maybe?
    CodyP, BroHon and bmf4069 like this.
  20. Jan 14, 2025 at 3:59 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Gross
  21. Jan 14, 2025 at 4:00 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I’m assuming the snorkel on the quad is made of cast iron
    whodatschrome and BroHon like this.
  22. Jan 14, 2025 at 5:02 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    If they have a 12/3 running to them, they're interconnected. Just a 12/2 and they're only powered.
    Tundra2[QUOTED] and FrenchToasty like this.
  23. Jan 14, 2025 at 5:27 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  24. Jan 14, 2025 at 5:29 PM
    Yeah, I think they ultimately sold out. They have a flaw where they eventually burn out/melt down on the back of the LED square is.
    I personally don't like fanned bulbs, that's just me.
  25. Jan 14, 2025 at 5:29 PM
    There are. Avoid the Y7 tricolor. It's apparently very annoying.
  26. Jan 14, 2025 at 5:29 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I think its a 12/3
    I've had more important uses for funds for a minute
  27. Jan 14, 2025 at 5:30 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Something else that annoys me about combo detectors is do BOTH sensors have to be made for the alarm to go off or just one or the other?
  28. Jan 14, 2025 at 5:41 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Mine don't have fans, just heat sinks. At least that's what it looks like. I guess I'll know once I power em on. I had "Life Time LEDs" with fans in my Tacoma, years ago. They would die every 6-9 months, but were always warranteed. On the third or fourth set, they upgraded me to the latest, more expensive model for free, and I immediately sold them to a forum member on TW. I was so over changing em out all the time. I hope these last longer.
  29. Jan 14, 2025 at 5:42 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I'll have to either dig up my order or dig in the trash for the box to find out which I got I guess.
  30. Jan 14, 2025 at 6:11 PM
    BroHon
    BroHon Everything's clock is ticking
    Bro
    2000 SR5 AC 4x4 4.7
    Weight reduction, mostly rust.
    I "liked" that, as in I'd like to punch the dude in the face, with a chair. Look how beat to shit that thing is.. miss matched wheels, shit dangling from the front end, bashed fender broken tailgate, and the box is rubbing on the cab.
    some people don't deserve a FGT.:rofl: If I look at that picture long enough, I hear "HELP!!!"
