2013 Sequoia Limited to TRD FAUX build now with BOOST!
Discussion in 'Sequoia Builds' started by e30cabrio, Apr 19, 2021.
  1. Apr 10, 2023 at 6:30 PM
    #931
    e30cabrio
    e30cabrio [OP] I'm e30cabrio, I'm a modaholic
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Thanks, I'll do it tomorrow, Ordered this, thanks!
    And this.
  2. Apr 10, 2023 at 6:38 PM
    #932
    TheBeast The Beach
    you been busy :D
    e30cabrio[OP] likes this.
  3. Apr 10, 2023 at 7:42 PM
    #933
    e30cabrio
    I'm not bored.
    lol
    TheBeast[QUOTED] likes this.
  4. Apr 11, 2023 at 10:16 AM
    #934
    e30cabrio
    The line from the front of the driver side rail goes down to a fitting, not to the passenger side rail.
    I moved the gauge out of the cabin and mounted the FPR
  5. Apr 11, 2023 at 10:21 AM
    #935
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    The fitting next to that one is the return line (there is a plastic cover over both, easier to see from wheel well), where your FPR return should attach to...the diagram from Toyota is confusing, but the one I circled is at the end of the return line, and not on the driver rail.
    e30cabrio[QUOTED][OP] likes this.
  6. Apr 11, 2023 at 12:39 PM
    #936
    e30cabrio
    Auto Meter is made to order & it's 5-7 business days, I'm first in line for the kind I ordered wheee
  7. Apr 11, 2023 at 3:11 PM
    #937
    e30cabrio
    Am I running hoses between the return lines on each side and the Y to the FPR Return?
  8. Apr 11, 2023 at 3:37 PM
    #938
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I was just suggesting a way to eliminate that fuel line currently routed back over your supercharger, and connecting to the stock return hard line instead.
  9. Apr 11, 2023 at 3:43 PM
    #939
    e30cabrio
    OK, thanks.
  10. Apr 11, 2023 at 3:56 PM
    #940
    e30cabrio
    I believe I found the hose/hardline, am I capping off the passenger side hardline?
    Thanks
  11. Apr 11, 2023 at 3:59 PM
    #941
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Run the fuel injection hose from the bottom of your FPR to that hardline, and remove the line you unhooked from the return hardline.
  12. Apr 11, 2023 at 4:22 PM
    #942
    e30cabrio
    Thanks, I was missing the fact it is a single return & the hose was connecting it to the passenger side.
    It's done.
    armyoffoo likes this.
  13. Apr 11, 2023 at 4:51 PM
    #943
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Stock is one feed, one return, with a cross-over between the rails. Once you get up higher in power, you might want to switch over to the dual feel/dual return, and/or replace the stock 5/16” lines with 3/8”. And if you do that, you’ll need to cut 1/8" off the tip of the barbs on the fuel rails, as those will be a choke point.
    To convert from single feed over to dual feed, you need one Y adapter for Feed (Green) and one for Return (Red), but your FPR can act as the Y if you buy an additional barbed fitting to replace the FPR plug.
  14. Apr 11, 2023 at 4:55 PM
    #944
    e30cabrio
    Thanks, I have 99.9% of the parts needed to do the dual/dual. I'm just trying to get it tuned and enjoy it a bit before I rip into it.
    I have that Y I posted & another barb for the FPR as well.
  15. Apr 11, 2023 at 4:59 PM
    #945
    armyoffoo
    armyoffoo Member
    Cypress, TX
    You should be good to go then, only need more fuel injection hose, and lots of clamps!
  16. Apr 11, 2023 at 6:29 PM
    #946
    e30cabrio
    You said I need the right tools for the hose. What tools?
    Where is the best place for the filter?
  17. Apr 11, 2023 at 6:51 PM
    #947
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Aluminum vise jaws to hold the fittings while you push the hose in, and aluminum wrenches to tighten without marring the fittings. There is also an assembly lube to help prevent the threads from galling. Are you replacing the lines all the way to the top of the tank?
  18. Apr 11, 2023 at 6:53 PM
    #948
    e30cabrio
    I'd rather not drop the tank again if I can avoid it. :p
    armyoffoo[QUOTED] likes this.
  19. Apr 12, 2023 at 4:11 PM
    #949
    e30cabrio
    Mount looks lonely with the open one. Hopefully, Auto Meter is faster than they said.
    AZTundra likes this.
  20. Apr 12, 2023 at 5:14 PM
    #950
    AZTundra
    Paul
    Phoenix, AZ
    Nice! I think I need to change zip codes...I ordered the pump hardwire kit and the cravenspeed gauge pod a couple hours before you and you always seem to get them first. My Cravenspeed pod did show up today at least so there's that...
    Looking good.
  21. Apr 12, 2023 at 5:22 PM
    #951
    e30cabrio
    Thanks, sorry they are messing you up.
  22. Apr 13, 2023 at 1:48 PM
    #952
    e30cabrio
    Walbros seller has no shame.
    In response to this claim, Express Fuel Pumps offered you a partial refund of $100.00 USD. You have denied this refund offer and as a result we will continue our review of this claim. We will review the facts of the case and carefully consider all the material before making a decision. We'll let you know if we require additional information from you, and will send you an email when a decision has been reached.
    I said no, I want my 194.xx & if there were justice you would be paying for the week wasted trying to find other possible solutions & removing the tank again.
  23. Apr 14, 2023 at 7:06 PM
    #953
    e30cabrio
    Made some big power with the belt slipping!
    AZBoatHauler and hoof hearted like this.
  24. Apr 15, 2023 at 5:46 AM
    #954
    e30cabrio
    This was being done when I got there.
    Going on the dyno.
    Got a new sticker!
    AZBoatHauler, Fotnot and AZTundra like this.
  25. Apr 15, 2023 at 7:01 AM
    #955
    e30cabrio
    I'm 99.9999% done, just need to get the electric fuel pressure gauge (Auto Meter Shipped yesterday), uninstall the mechanical gauge, install the adapter and new gauges.
    Oh & I still need a few blue switches.
    lol
    I forgot about this part, it kept downshifting and doing this.
    Which made it get to this amount of TQ
    omgboost, Fotnot and AZTundra like this.
  26. Apr 17, 2023 at 12:54 PM
    #956
    e30cabrio
    BLUE Switches!!
    I completed the center area today when the traction switch came. It's like playing switch bingo.
  27. Apr 17, 2023 at 1:14 PM
    #957
    e30cabrio
    Got a new flashlight Saturday.
  28. Apr 18, 2023 at 12:31 PM
    #958
    COSequoia
    COSequoia New Member
    I'm trying to move some switches like that too....I found one dedicated extension for the window but not the others -- are you just rewiring manually or are there harness extenders available? I'd like to get the power liftgate moved over there too.
  29. Apr 18, 2023 at 12:40 PM
    #959
    e30cabrio
    They are just pulled there. The traction control is very tight. It's been a year since I moved them, so I'm not exactly sure which were hardest but I just unwrapped the wires moved them where I wanted them & wrapped them again.
  30. Apr 18, 2023 at 5:08 PM
    #960
    e30cabrio
    Fuel pressure gauge came, it'll go in tomorrow, watching playoff hockey.
