2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Sep 25, 2023 at 6:07 PM
    #1921
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Is there a similar thread in the GEN 3 forum?
    mtnkrew likes this.
  2. Sep 26, 2023 at 2:13 AM
    #1922
    mtnkrew
    mtnkrew New Member
    Oxnard, CA
    2022 Mag Gray Tundra TRD Offroad
    Icon Vehicle Dynamics Stage 9 suspension lift, OME rear springs, 37x12.5R17 Nitto Ridge Grapplers, 17x9 +18 offset KMC Km542 Impact wheels in satin black, AFE Momentum GT Cold Air Intake w/ Pro 5R filters, AFE Scorcher Blue bluetooth Power Module
    i have a 2022 sr5 trd off road with the 8” screen, will your harness work with my truck? Not sure what the multi terrain monitor is
  3. Sep 26, 2023 at 4:23 PM
    #1923
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    MTM is also known as the Panoramic View System. Unfortunately all 3rd Gen Tundras use the special connectors that are commercially unavailable. As soon as they are available, I’ll be building 3rd Gen FRAC Harnesses.
    bulldog93 likes this.
  4. Sep 26, 2023 at 4:25 PM
    #1924
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I’ll be posting updates here as soon as the new connectors are available.
    Yota802[QUOTED] likes this.
  5. Sep 26, 2023 at 5:53 PM
    #1925
    Yota802
    Yota802 New Member
    Could you build a camera system for the bed area? I believe the trucks equipped with PVS have a camera above the rear cab that looks into the bed.
  6. Sep 27, 2023 at 7:58 AM
    #1926
    brutalitybob
    brutalitybob New Member
    Wondering is it possible to get the 360 camera top view option in the near future with the FRAC harness for 3rd gen. Not sure how hard that is to do with the OEM head unit or would it need to be done on an aftermarket one? I see they sell kits out there but definetly not a plug and play like yours is for 2nd gen.
    TundraTex[OP] likes this.
  7. Sep 27, 2023 at 5:04 PM
    #1927
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    The FRAC Harness already supports an additional camera by use of the Video Switch Module (VSM). This can be used to tie in a trailer rear cam or a bed cam. It will work with the Gen 3 FRAC installation as well. Just need those connectors!
  8. Sep 27, 2023 at 5:08 PM
    #1928
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes this could be done as well. I haven't looked into the specific hardware needed, but the FRAC could support this kind of feature.
    Yota802, bulldog93 and Tripleconpanna like this.
  9. Oct 5, 2023 at 10:40 AM
    #1929
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    I was going to inquire as well. I saw on the FRAC website that it references that the 2.5 Gen harness is compatible with some 22's without the 360-degree cams. My truck is a basic SR5 without MTM or any cameras (other than the backup cam).
    Just want to confirm based on your comment above, you're saying all 3rd Gen Tundras use the same newer harness? Could it be used on some 22 models that haven't changed much, like the 4Runner, without the additional cams?
    Thanks for being so responsive. It's nice to be able to converse directly with a vendor. It's such a rare thing nowadays. I (we) really appreciate it.
  10. Oct 5, 2023 at 11:52 AM
    #1930
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    The FRAC Harness can be installed on 22+ models of the 4Runner, Tacoma, and some others without panoramic. Unfortunately all tundras use the new connectors regardless of which camera option is installed.
  11. Oct 5, 2023 at 12:44 PM
    #1931
    KroppDuster
    Bilstein 5100s
    Appreciate the response. Thanks.
  12. Oct 5, 2023 at 12:59 PM
    #1932
    luxury4play
    luxury4play New Member
    are thre any options for the people that dont have a available blank spot?
  13. Oct 5, 2023 at 5:51 PM
    #1933
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Yep...
    You'll just order w/the round rocker switches and drill small hole for them if you're not connecting to a SwitchPro or something similar :thumbsup:
    TundraTex[OP] and bulldog93 like this.
  14. Dec 9, 2023 at 2:09 PM
    #1934
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    I have a 2021 Tundra. The harness below is labeled as the harness I need for the '21 model (my truck). My harness has an extra set or wires coming out of the harness bundle that are braided together, purple and yellow in color. Doesn't take a lot to confuse me, so I am thoroughly stumped. As if this weren't enough, the lead wire that connects to the camera wire is not like the same example as in the explanatory video. Any help is much appreciated. [​IMG]
  15. Dec 9, 2023 at 2:17 PM
    #1935
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    From this page: Installation Help – LG Technology (fracharness.com)
    This provides info.
    OEM SWITCH MANUAL v012823
    Those wires are for the backlight illumination if you got the OEM-looking switch.
  16. Dec 9, 2023 at 2:24 PM
    #1936
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    Got it. Thanks. From the instal guide, the Yellow and Purple wires provide power to the OEM style rocker switch (which I plan on installing). I sincerely appreciate the help.
  17. Dec 10, 2023 at 12:26 PM
    #1937
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Chuck, I just sent you a PM with the answer to your camera harness question as well.
  18. Dec 10, 2023 at 1:30 PM
    #1938
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    Thanks T.Tex. I received your PM. Your explanation has provided a tremendous gain in understanding of how to proceed. Looking forward to providing some pics and feedback very soon.
  19. Dec 17, 2023 at 8:05 AM
    #1939
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    So after watching this thread for years I decided to get one. Just ordered it and it's Christmas present from my wife. I'm looking forward to the install.
  20. Dec 17, 2023 at 11:44 AM
    #1940
    Tripleconpanna
    One of the best 'values' out there for a mod that I use almost every time I'm in the truck :thumbsup:
  21. Dec 18, 2023 at 6:02 AM
    #1941
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Just confirmed your order in the morning batch. Should go out tomorrow. Since you've been around the forum for a while you probably know this already, but you can review all the installation instructions at https://www.fracharness.com/pages/installation-help. Let me know if you have any questions along the way.
  22. Dec 18, 2023 at 6:50 AM
    #1942
    NCTundra18
    Jeff
    Candler, NC
    Thanks for letting me know and thanks for the link.
  23. Dec 18, 2023 at 7:22 AM
    #1943
    PixelPusher
    PixelPusher New Member
    New Hampshire
    2020 Tundra Limited, Super White
    By far the best customer service I have ever had the pleasure to deal with. Plus, an amazing product to boot.
    Plus, if you post a question regarding install... Lou will respond (if someone else here doesn't beat him to it.)
  24. Jan 12, 2024 at 10:14 AM
    #1944
    DirkS
    DirkS New Member
    Dirk
    Abbotsford, BC
    2016 Tundra Limited
    So, just started looking at this, and I think it’s a great idea. Parking my truck is something I’m still getting used to.
    But, I’ve installed one of the CarABC CarPlay units, which also connects through the factory harness. Anyone know if the two systems will happily coexist? Tried searching the forums but didn’t find any mention of it.
    Thanks!
  25. Jan 12, 2024 at 12:23 PM
    #1945
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Max
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
    If it's PayPal count me in.
  26. Jan 14, 2024 at 11:25 AM
    #1946
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    The FRAC Harness is plug and play so it was designed to pass through all signals on the vehicle harness - even those not needed by the FRAC functions. This means as long as your other in-line devices are designed the same way (most are that I know of) they will coexist just fine.
  27. Jan 14, 2024 at 6:15 PM
    #1947
    DirkS
    DirkS New Member
    Dirk
    Abbotsford, BC
    2016 Tundra Limited
    Thanks @TundraTex! Now, the only bad news is that means now you’re going to make me spend more money…:spending:
    Tripleconpanna likes this.
  28. Jan 16, 2024 at 10:58 AM
    #1948
    NCTundra18
    Jeff
    Candler, NC
    20240116_135237.jpgSo I have a question for anyone who used the OEM switch. Where and which wires did you tap into for the illumination? It's been way too cold here to do the install. I'm just trying to have everything ready for when I get around to it.
    Thanks
  29. Jan 16, 2024 at 12:37 PM
    #1949
    RainMan_PNW
    Casey
    Clark County, WA
    For 2018-2021, these are the illumination circuits for the instrument panel switches (part of the taillight circuit). Pick whichever is convenient for you.
  30. Jan 16, 2024 at 12:39 PM
    #1950
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    following
