2017 Tundra SR5 Sound system upgrade (proposed)
Discussion in 'Audio & Video' started by brownsno, Feb 16, 2018.
  1. Mar 17, 2019 at 7:47 PM
    #121
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    it might. Depending on the ohms. The dash 3.5 speakers over power everything with 6 ohm. Not sure how they draw all that power. But they do.
  2. Mar 30, 2019 at 8:45 PM
    #122
    SiberianTundra
    Greg
    War Machine
    Ok added 3.5 dash speakers
    GiantsFanDan likes this.
  3. Mar 31, 2019 at 10:35 AM
    #123
    Jra8
    Jra8 New Member
    Tampa Fl
    2018 Inferno
    What about the second bolt? What's your plan.
    SiberianTundra likes this.
  4. Mar 31, 2019 at 4:08 PM
    #124
    SiberianTundra
    Greg
    War Machine
    not yet sure might have to just plastic tap screw
    but at least i did not have to trim anything
    Jra8[QUOTED] likes this.
  5. Apr 4, 2019 at 7:53 AM
    #125
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
  6. Apr 4, 2019 at 7:55 AM
    #126
    SiberianTundra
    Greg
    War Machine
    Ok I was busy with upgrades to Stereo Speakers, Mirrors, Wheels and Fender Flares
    Now I will start researching this again starting this week.
  7. Apr 4, 2019 at 8:04 AM
    #127
    FirstTruck
    Stock, for now
    Hello members. Im trying to upgrade the front speakers on my 18 CM. Does anyone know whats the max depth that we can go with? I found some Infinity Kappa 6x9. 135 RMS each!!! They are components and upgradable to add a midrange. The only downside is the depthness needed: 3 3/16” with top mount installation. Any input will be greatly appreciated.
  8. Jun 18, 2019 at 8:25 PM
    #128
    xando
    xando New Member
    Oregon
    Tundra TRD OFF ROAD 2015 crewmax/ silver metallic
    Another happy customer.
    Thank you @SiberianTundra and @brownsno for all the help on this tread.
  9. Jun 18, 2019 at 8:52 PM
    #129
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Super easy to use a short self tapping screw. That's what I did. Just used a stubby screwdriver to put it in. It's too tight against the windshield to use a power tool other than a 90° drill, but really there is no need, stubby Phillip's took care of it with a few turns
  10. Jun 25, 2019 at 9:15 PM
    #130
    SiberianTundra
    Greg
    War Machine
    I left it with just 1 screw. Seems to hold it in place.
  11. Aug 18, 2019 at 4:27 PM
    #131
    Hunterdan
    Hunterdan New Member
    2017 Inferno DC SR5
    OEM TRD led lights, TRD exhaust, s&b intake
    So, ordered the parts for this on Friday, finally got time to do this today. About an hour's worth of wiring, using the 4438 wiring harnesses, and everything works. Just running factory speakers for now, but may upgrade in the future. Thanks to the OP for starting the thread.
  12. Aug 19, 2019 at 9:14 AM
    #132
    SiberianTundra
    Greg
    War Machine
    How is the sound for you? Better?
  13. Aug 19, 2019 at 2:14 PM
    #133
    Hunterdan
    2017 Inferno DC SR5
    So far it's a marked improvement. Still trying to get the gains set. I do believe a set of speakers front and rear will be the next step. Well worth the time and money.
  14. Aug 20, 2019 at 7:25 AM
    #134
    SiberianTundra
    Greg
    War Machine
    Sounds awesome. Be aware that in dash speakers are not powered by the amp but are directly powered by the OEM head unit.
  15. Aug 20, 2019 at 11:42 AM
    #135
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    I'm still up in the air as to the 1st step for mine,new HU or follow this route and amp the factory stuff,non premium here...dont want tons of boom just wana let my 80s hair metal rock loud and proud!
  16. Aug 21, 2019 at 3:59 PM
    #136
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I upgraded to a alpine 309. Sounds way better than stock. Plus I can finally hear, usually I have the stock unit’s volume at 50+
  17. Aug 21, 2019 at 4:05 PM
    #137
    SiberianTundra
    Greg
    War Machine
    Nice. I am still OEM. However considering Alpine iLX-F259
  18. Aug 21, 2019 at 4:09 PM
    #138
    BeachyTundra
    BeachyTundra New Member
    Brandon
    Spokane
    2017 MGM 5.7L DC, Bilstein 5100s
    Damn, that was a lot of reading.
    So, my ultimate question here; I am the proud owner of a non-JBL system, and I've recently replaced my factory HU with a Dasaita one (see the thread on here, it's pretty badass). Is there a way that I can install an amp, upgrade my factory speakers, and NOT have to run new speaker wires from the new amp to the new speakers? Or is that a no, because my original HU powered all the speakers without an amp in the first place?
  19. Aug 21, 2019 at 5:33 PM
    #139
    SiberianTundra
    Greg
    War Machine
    I kept OEM wires TBH.
  20. Aug 21, 2019 at 7:10 PM
    #140
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    That's what I did :thumbsup:
  21. Aug 21, 2019 at 10:09 PM
    #141
    Hunterdan
    2017 Inferno DC SR5
    You should have had an OEM amp under the front passenger seat. It's there, my DC had it. Basically, you're removing the stock amp and running the upgraded, better aftermarket amp through factory wiring, pushing about 45 watts rms. The wiring diagram from Alpine left a little to be desired, but the 4438 harness is color coordinated with the Alpine harness for the most part. But doing this mod should do exactly what you want, run a better amp through factory wiring, and be able to run better speakers.
    All that said, what speakers is everyone running in the double cab? Im pretty sure I want to keep max power of the new speakers to around 50 watts rms since the amp maxes out at 45.
  22. Aug 22, 2019 at 8:39 AM
    #142
    BeachyTundra
    Brandon
    Spokane
    So if I'm understanding this correctly; If I wanted to upgrade my full system, I could buy the Alpine KTP-445U and the 4438 harness and I would have 45 watts rms to all my door speakers, with the dash speakers being powered directly from the HU?
    It sounds like the 4438 might require some splicing? And what is this "add an amplifier" for at the bottom of the thread? Is this an easy way to add an additional amp? Cause I have a 2 channel and a 4 channel amp laying around from my previous vehicle that only had 4 door speakers, then i bridged the 2-channel for a 10" sub. I wouldn't mind having a sub again if I can make things an easy install
  23. Aug 22, 2019 at 3:16 PM
    #143
    Hunterdan
    2017 Inferno DC SR5
    There was splicing, but it only involved connecting the 4438 harness to the Alpine wiring harness. Wiring would be a bit different, though not much more difficult if you were using a different amp. You would have to run a heavier wire for your power and ground since you'd exceed what the factory wires were capable of handling. Now, im not sure what I'd have to do in order to add an amp for a sub if I wanted one. But, the Alpine setup with the 4438 harness, once wired up is essentially plug and play. I am however finding the shortcomings of the factory non-jbl speakers.
  24. Aug 23, 2019 at 2:28 AM
    #144
    Hunterdan
    2017 Inferno DC SR5
    So, figured I'd ask this here since this is going to be in conjunction with the Alpine amp, what does everyone think of running these speakers, sound ordinance p-67b?
    https://www.crutchfield.com/p_777P67CB/Sound-Ordnance-P-67CB.html
    Price seems reasonable, I can pick up the sail panels already cut for a tweeter and somehow make these tweeters work in that panel. That would speed up the install time since I'd could just swap everything out instead of having to modify.
  25. Aug 23, 2019 at 8:32 AM
    #145
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Pillar Tape, Bullet Liner, 20% Tint, Tyger Star Armor Kenwood Amp Tech12volts JL Tweeters Dasaita G13 Head Unit Fumoto Oil Valve Driver Side Grab Handle
    Hey ST - found your thread and those PB's look interesting. I have a 2016 CM SR5 and was looking at the FoCal's, but may have to rethink that after finding this thread.
    Question for you - looks like these fronts and backs come with tweeters. I assume front corner dash tweets and rear door tweets?
    But you said you didnt use them cause the wires dont match?
    What exactly do you mean - the front or backs which set(s) did you not use?
    Thanks
    Tom
  26. Aug 23, 2019 at 10:42 PM
    #146
    SiberianTundra
    Greg
    War Machine
    I did not use both due to the factory oem plug did not match. I know I can splice it and make them fit. But I felt that OEM tweeters did a good enough job in front and rear doors.
    purplenova[QUOTED] likes this.
  27. Aug 27, 2019 at 10:17 AM
    #147
    SleeperTRDPro
    SleeperTRDPro The small package good things come in
    Austin, Texas
    I did this mod this weekend and will say it's exactly what i needed for my truck. Night and day difference. I always hated how 'quiet' the stereo was and how high you had to turn it up just to hear some tunes with the windows down. I was not interested in spending $700+ on a system. Use to i would have to turn the dial to 40 but now 20-25 does the trick. I'm even surprised how well the door speakers sound now that they have a little more juice.
    purplenova likes this.
  28. Aug 27, 2019 at 10:26 AM
    #148
    purplenova
    Tom
    Ohio
    Was looking at the PB Toyota speakers and found one of my local shops carry them. I think my next mod will be to install fronts and rears.
  29. Aug 27, 2019 at 11:29 AM
    #149
    SiberianTundra
    Greg
    War Machine
  30. Sep 9, 2019 at 9:59 AM
    #150
    Hunterdan
    2017 Inferno DC SR5
    So, if I were wanting to run a small powered sub to take some strain off the speakers and add some bass, what's the best way to get the signal to the sub? I know I'd have to run new power and a ground.
