2018 OEM LED Sequoia headlights
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Sep 21, 2017.
  1. Oct 13, 2017 at 2:17 PM
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    As far as I know, it's a straight swap over. BUT, nobody has attempted the swap yet, so I can't be 100% on that.
    Upper grille in 218
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-radiator-ou-531110c240c0
    It does not come in 202 if you have that color code.
  2. Nov 1, 2017 at 3:07 PM
    xrunnerdude67
    xrunnerdude67 New Member
    Does anyone happen to have a pic of the back side of the headlamps? Trying to confirm location of connector. In the process of making a PnP harness. Thanks!
  3. Nov 24, 2017 at 12:44 PM
    xrunnerdude67
    If anyone is interested in the harness for the 2018 Sequoia headlights, let me know. Not completely plug and play, but very easy to install. Black Friday/Cyber Monday special. $125, then goes up to $150 on Tuesday. Will be about a week for completion time on orders.
    Maxi13 likes this.
  4. Dec 27, 2017 at 7:36 AM
    Bulldog_tundra
    Bulldog_tundra New Member
    USA
    2006 Double Cab
    Bilstein 5100 (Top Notch Front) 1” Rear Block Flowmaster 40 w/ 3” Tip Bumperplugs Front Plate Delete
    Roman, do you have links to the parts for the entire grill swap? Blizzard pearl if you need that. I’d like to swap the grill off my 2016, lots of rock chips, and update it to the newest.
    Thanks!
  5. Dec 27, 2017 at 10:26 AM
    Roman
    Roman
    Franklin, TN
  6. Jan 1, 2018 at 9:42 PM
    Aktundra2018
    Aktundra2018 New Member
    Hi Roman
    I’m interested in swapping my grill and headlights from a 2010 sequoia platinum to the 2018 platinum
    With the harness from xrunner would it work and how much would all that cost?
  7. Jan 2, 2018 at 8:46 AM
    Roman
    Roman
    Franklin, TN
    Should work out just fine. Use the links in the OP for the headlights and filler panels. Which color grille are you needing?
  8. Jan 19, 2018 at 9:07 AM
    Bulldog_tundra
    USA
    2006 Double Cab
  9. Jan 19, 2018 at 9:11 AM
    Roman
    Roman
    Franklin, TN
  10. Feb 23, 2018 at 5:50 PM
    ReyesL
    ReyesL New Member
    Hi Guys,
    Has anyone successfully switch to the 2018 Sequoia grill and possibly with new Headlamps?
  11. Feb 23, 2018 at 5:53 PM
    ReyesL
    ReyesL New Member
    Hey Bulldog- did you switch to the 2018 Sequoia grill and did you stay with original Sequoia headlamps. How the fog lamps change out to 2018 go?
  12. Feb 23, 2018 at 9:13 PM
    Those are some BA! Headlights!
    GNTundra likes this.
  13. Apr 16, 2018 at 8:28 AM
    hoopin4you
    hoopin4you New Member
    As an '08 Sequoia owner, I was hoping for a reasonably priced HL upgrade from the '18 offerings. Obviously, MoTo has decided to stiff us for an extra $1K just because they can, I suppose. So my next question is, what exactly IS different between the '18 Tundra and the '18 Sequoia HLs? I'm tempted to buy the Tundra HLs and see if I can make them work on my '08 Sequoia.
  14. Apr 16, 2018 at 8:54 AM
    xrunnerdude67
    The ‘18 Tundra and Sequoia Headlights are totally different shapes. The Sequoia one is completely LED. So if you wanted to swap the Tundra ones into yours, you would need new hood, grille, fenders for sure.
  15. Apr 16, 2018 at 9:16 AM
    Roman
    Roman
    Franklin, TN
    This definitely.
    For the '18 Sequoia headlights, you would only need the new headlamp fillers beneath the new headlights. For the Tundra, you'd have to swap out basically the whole front end.
  16. Apr 16, 2018 at 10:02 AM
    hoopin4you
    Guess I should've done my "homework" before posting...DOH! Thanks for the replies.
  17. Apr 16, 2018 at 12:19 PM
    hoopin4you
    If I win the lottery and go with the '18 Sequoia HL (and fogs), will I need a harness for either/both?
  18. Apr 16, 2018 at 12:34 PM
    Roman
    Roman
    Franklin, TN
    You will definitely need one for the headlights, but I have no experience with the new fog lights.
    hoopin4you likes this.
  19. Apr 16, 2018 at 12:59 PM
    #49
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Worth every penny :)
  20. Apr 16, 2018 at 2:56 PM
    #50
    hoopin4you
    You and I were chatting back and forth on Facebook...recognize your truck from over there. BTW, how much was and where did you get the harness for the conversion?
  21. Apr 16, 2018 at 3:04 PM
    #51
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    hoopin4you[QUOTED] likes this.
  22. May 23, 2018 at 5:23 AM
    #52
    Okitundra
    Okitundra New Member
    Patrick
    2007 Tundra Crewmax Limited
    Pro Comp/RCX Hybrid Lift, Bushwacker Pocket Flares, , OME Dakar Leafs, Bilstein 5100's, Borla Dual Exhaust, BHL & Projector Mod, LED Taillights, Yokohama Geolandar 325/60R20 on XD Addict 20” x 9” O/S 18, Custom Mirror Turn Signals, Jaos Mud Guards, Amp Research Power Step & Bed Step, K&N Air Filter
    Has anyone tried the 2018 Sequoia Grill as well? Haven't seen any retrofits of the grill this far and was curious as to whether its a direct bolt on or of any mods are required.
  23. Jun 7, 2018 at 8:36 AM
    #53
    mkmarz
    mkmarz New Member
    Bump, I'm curious about the grill as well.
  24. Jun 7, 2018 at 11:19 AM
    #54
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    544E0E90-2D83-4CFC-B63E-094C8C391AC6.jpg I like my grille better :rofl:
    DalTee, Mountun Goat and Okitundra like this.
  25. Jun 13, 2018 at 1:36 PM
    #55
    mkmarz
    mkmarz New Member
    I love your bumper, but not sure I can handle that much grill.
  26. Jul 13, 2018 at 3:51 PM
    #56
    lsumatt1514
    lsumatt1514 New Member
    2008 Tundra Crewmax Limited
    What parts are needed for the swap (headlamps, harness, etc.)? I have an '08 Limited that I installed a '10+ Platinum grill on. Thanks guys!
  27. Jul 13, 2018 at 4:16 PM
    #57
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
  28. Jul 13, 2018 at 4:35 PM
    #58
    lsumatt1514
  29. Jul 16, 2018 at 7:27 AM
    #59
    Roman
    Roman
    Franklin, TN
    Parts are listed in the OP with pictures of each option on the headlights.
  30. Jul 29, 2018 at 9:12 PM
    #60
    the07tundra
    the07tundra New Member
    Cannon
    2007 White Tundra
    35" Toyo A/T tires, Black Rhino Gunmetal wheels, 2" bilstein lift kit and 2" ready lift leveling kit, recon headlights, leer canopy, custom 3" piping with 40 series flow master muffler.
    Hey if y’all have Instagram someone did it and it looks so awesome.
    Here’s his user name
    Rock_warrior808
