2019 TRD Pro CM SuperWhite Overland Build
Discussion in '2.5 Gen Builds (2014-2021)' started by Punisher29073, Oct 30, 2020.
  1. May 19, 2021 at 11:55 AM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    Been thinking about this. How tall are you?
  2. May 19, 2021 at 1:56 PM
    Punisher29073
    Punisher29073 [OP] New Member
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Clearance lights, Light bar in front bumper, Ditch lights, CB Radio, AGM Battery, SLEE Sliders,
    Payload, adding a Habitat campershell/tent and i tow atvs on a 16’ tandem axle trailer. Ride, wanted to retain plush ride and my experience with add a leafs doesnt do that. I plan to use the truck as an overlander.
    Ryan
    FortyNorth[QUOTED] likes this.
  3. May 19, 2021 at 1:58 PM
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    6’3”. The original position didnt bother me but didnt feel right. It is much better now. I stumbled a bit at the price but do not regret it afterwards.
    Ryan
  4. May 20, 2021 at 4:06 PM
    Jacob37
    Jacob37 New Member
    Jacob
    Hattiesburg MS
    2018 Tundra crew cab TSS
    Looks awesome. Nice build !!
    Punisher29073[OP] likes this.
  5. May 21, 2021 at 6:44 PM
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Installed 1 of my Alcans tonight, welded in a lateral support to the shackles. I am too old to be wrestling these stupid things in there by myself if anyone was wondering. Gained 2.5” more over my 2” blocks with just the leaf spring. Happy to see the truck with rake again. Passenger side misses the exhaust pipe too! Hopefully the drivers side does as well.
    Ryan
    Wallygator likes this.
  6. May 22, 2021 at 10:31 AM
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Alcan spring and shackle install complete. Truck squats 1/2” with trailer and teryx4 now. Was 3-4”. Springs gave me 2 1/2” over the 2” blocks so 4 1/2” total lift in rear. Gives me about 2” of rake. Much better than a little squat.
  7. Jun 4, 2021 at 5:51 PM
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    The body mount chop is set up to begin in the AM.
    Wallygator and abomb60 like this.
  8. Jun 4, 2021 at 6:43 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Looking good! Suspension is next on my list. After 3 days of logging roads up in the North Maine Woods my wife has signed off on the upgrade (TRD off-road Bilsteins in there now). Now I just need to find the $$$ :rofl:
  9. Jun 5, 2021 at 1:58 PM
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    BMC and Duraflaps installed. BMC took about 3 hours. Not as bad as I expected. Added the clearance i needed. Happy so far. 1 step closer. To what i dont know, but 1 step just the same…
    ryan
  10. Jun 26, 2021 at 8:16 AM
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Original trip to Cape Lookout got canned due to tropical storm. We were able to make it to Corolla beach for a beach ride though.
    Wallygator, Metro14536 and 300BLK like this.
  11. Jul 3, 2021 at 9:50 AM
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Got the FRAC installed today. I think the VIM bypass may have been worth the cost of admission.
    TundraTex likes this.
  12. Jul 3, 2021 at 9:54 AM
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    I had to mount the camera off center because of my running lights behind the grill.
    Wallygator and TundraTex like this.
  13. Jul 15, 2021 at 11:15 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Glad you're enjoying it. Great job on the installation!
  14. Jul 24, 2021 at 3:59 PM
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Changed differentials and transfer case fluids today. Installed driveshaft carrier bearing drop as well. Front diff and transfer case fluids looked great. Rear diff had shards. Hope they are just from break in.
  15. Jul 31, 2021 at 6:23 PM
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Valhalla shields ordered today. 1/4 Aluminum bare
  16. Aug 13, 2021 at 6:45 PM
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Started install of SSO Slimline bumper and Warn Zeon 10s winch tonight. Made good progress. Plastic cut out, new bumper mounted, winch mounted, started fabing a bracket to mount the solenoid to the left of the trans cooler.
    Wallygator and Black@Blue19 like this.
  17. Aug 14, 2021 at 3:17 PM
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Finished SSO Slimline bumper and Warn Zeon 10s install. Had to get Warn solenoid relocation kit and made a bracket to mount it behind grill on left side. For others looking at this combo: Free spool lever is extremely hard to reach. I have to go through access hole in top of grill and reach arm aaaallllllllllllll the way down to disconnect the clutch and then reach through the front access hole and push it back to engage the clutch. Platinum or not getting the light bar would have made this a non-issue. Other than that, i like the solenoid mounted behind grill with access hole cut into top of grill so hood must be open to access the solenoid. Will eventually wire in a dash switch, im sure.
    Also adde Barnes 4x4 tapered washers to slider bolt that was exposed.
  18. Sep 26, 2021 at 2:22 PM
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Installed some reverse lights last weekend.
  19. Sep 26, 2021 at 2:31 PM
    #49
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Picked up some 1 1/4” square tube handrails from a building we will be demoing in the near future. Repurposing them as a frame for my fridge slide and cooking slide. Will also serve as a step up into my AT Habitat, one day, and a small table top if sitting in the bed with the tent up in the rain.
  20. Sep 26, 2021 at 4:28 PM
    #50
    infidel
    infidel New Member
    Jesse
    SE Wisconsin
    2016 Silver SR5 Crewmax
    Procomp 3/1 Method 307 18x9 +25 Falken Wildpeak AT3W 295/70r18
    I was thinking about doing this on my truck, but with diode dynamics. How do you like the nilight?
  21. Sep 26, 2021 at 5:24 PM
    #51
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    For rear lights, i like them fine. Plenty bright enough for doing stuff in reverse and lighting up behind you. We will see how long they last. Im sure the DD would be better. I went from a Nilight front light bar to Heise and it is a big improvement. For the front, probably worth it. For the back??? Ehhhh????
  22. Oct 3, 2021 at 3:06 PM
    #52
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Starting to take shape!!
  23. Oct 3, 2021 at 3:36 PM
    #53
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    WOW!!! Outstanding!! And A Good On Ya!!!!:). Very nice setup!!!:)
  24. Oct 9, 2021 at 3:41 PM
    #54
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Getting closer. Anyone have any suggestions on slides? Need 2 40” heavy duty. Looking at locking slides on Amazon.
    Wallygator, Kgfit85 and Black@Blue19 like this.
  25. Oct 9, 2021 at 4:42 PM
    #55
    Black@Blue19
    Ken
    SE Texas
    Tooo Cooool!!!:)
  26. Oct 23, 2021 at 3:57 PM
    #56
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Getting closer…..
    Wallygator, vanthesupreme and B.Ross like this.
  27. Nov 1, 2021 at 5:31 PM
    #57
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Almost ready for install….
    Wallygator and vanthesupreme like this.
  28. Nov 2, 2021 at 3:58 PM
    #58
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    And without further adieu….. Barnes Scrap Iron Fridge Slides presents!!!!! Prototype 1.0.
    tinman10101, GarTX526, Mattyc and 9 others like this.
  29. Nov 3, 2021 at 5:39 AM
    #59
    CoryShap09
    CoryShap09 New Member
    Cory
    2020 CM XP
    Did you have any trouble cutting through the plastic cover and metal bumper?
  30. Nov 3, 2021 at 9:22 AM
    #60
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    No sir. I positioned them so that it was mostly plastic though. Cut with a sawzall bi metal blade.
