2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by 0.S.T., Apr 6, 2020.
Who has actually used the front tow hooks?
  1. Never
    204 vote(s)
    52.6%
  2. 1-5 times
    111 vote(s)
    28.6%
  3. More than 5 times
    45 vote(s)
    11.6%
  4. Almost daily
    7 vote(s)
    1.8%
  5. I'm an off-roader and definitely need it.
    28 vote(s)
    7.2%
  6. I mall crawl
    17 vote(s)
    4.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Jul 4, 2021 at 2:44 PM
    #8731
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    FI5.7L
    Forced Induction
  2. Jul 4, 2021 at 5:57 PM
    #8732
    JuicyJ
    JuicyJ New Member
    More like 90%
    Lovetrucks[QUOTED] likes this.
  3. Jul 4, 2021 at 6:37 PM
    #8733
    Trbspr1
    Trbspr1 New Member
    I have a second Gen 08 5.7 and been keeping a close eye for years to see what toyota was going to do with the next Gen tundra. The primary function of my truck was to pull our 31 ft toy hauler. It's done a fine job other than gas mileage. Still waiting for the Tundra numbers to come out to see if I am going step up to a 3/4 or 1 ton.
  4. Jul 4, 2021 at 11:24 PM
    #8734
    tomharr51
    tomharr51 New Member
    2019 Toyota Tundra Sport Crew Max
    I have a 2019 TRD Sport. I may consider the 2022 Tundra if and when it's finally released.
  5. Jul 5, 2021 at 7:59 AM
    #8735
    Dilleytech
    Dilleytech New Member
    I wonder how the Nissan Titan can get over 20 mpg with a v8 but Toyota can’t..
  6. Jul 5, 2021 at 8:03 AM
    #8736
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Downhill with a tail wind, they get that number in a lab, on a dyno.
  7. Jul 5, 2021 at 8:04 AM
    #8737
    GODZILLA Introverted Troglodyte
    ColoradoTJ and Cpl_Punishment like this.
  8. Jul 5, 2021 at 8:31 AM
    #8738
    JuicyJ
    JuicyJ New Member
    If it's the new 2gen Titan, that'd be best case scenario standard cab 2wd, with a tail wind.
    My 6200 pound 4x4 big tow crew cab with 33's only gets 17.9 (never seen 18.0 or more) hand calculated on long road trips.
    In town is more like 12-13.
    GM V8s are the benchmark for fuel economy
  9. Jul 5, 2021 at 9:01 AM
    #8739
    JJtruckon
    JJtruckon New Member
    JJ
    2018 Tundra
    Undercoating
    Because the 5.7 is an ancient design.
    GODZILLA and Doofus like this.
  10. Jul 5, 2021 at 9:15 AM
    #8740
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    :rolleyes: Compared to what? Its an all-aluminum DOHC, 10:1 compression set up that pulls 10,000lbs on 87 octane, makes damn near 400hp and regularly goes 250k+ miles with oil changes.
    If the tundra had a 10 speed and weighed a couple hundred pounds less like the others it would be near the top of every performance category.
    Pretty shit “ancient” design. If anything it makes Toyota look like rocket scientists considering how old it is compared to the unreliable trash the others put out and their 3mpg “improvement” today.
    #offthatsoapbox
    Terndrerrr, mtndds98, nhw544 and 8 others like this.
  11. Jul 5, 2021 at 9:24 AM
    #8741
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    If Toyota can’t even tune their 5, or 6 speed transmission right, why you’ll think a 10 speed transmission will help???
  12. Jul 5, 2021 at 9:25 AM
    #8742
    Cpl_Punishment
    Cpl_Punishment I know you're gonna miss me when I'm gone.
    Neil
    2020 MGM SR5 CM 4X4
    What exactly is wrong with their 6 speed?
  13. Jul 5, 2021 at 9:44 AM
    #8743
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Nothing much, just never in the gear I wanted, so I change it to manual mode and find out it’s a semi auto.
  14. Jul 5, 2021 at 10:02 AM
    #8744
    Jonross227
    Jonross227 New Member
    We've got a fleet model or whatever the hell Nissan calls it that I was in for 4 months last year. Extended cab, no carpet, no rear seat.
    Its usual load is 1 guy and 600lbs of equipment in the bed. Cruise set on 82 most it averaged 20 on the interstate hand calculated. It honestly suprised me because I'm not light footed when it's the company card buying gas.
  15. Jul 5, 2021 at 11:51 AM
    #8745
    JJtruckon
    JJ
    2018 Tundra
    Undercoating
    :monocle::monocle::monocle:
    Compared to all other 1/2 ton trucks. Sure I have a tundra, but I don’t live in a bubble. I guess Toyota doesn’t either, TTV6? :D
  16. Jul 5, 2021 at 12:45 PM
    #8746
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Where would you like me to begin?
    For starters it’s slow to shift, particularly on downshifts. Then it wants to upshift too soon. Constantly trying to get into a taller gear too soon when I’m calling for acceleration. This effectively neuters the engine because it takes a fucking act of Congress to get full power acceleration in lower gears. Truck ends up feeling flat footed all the time.
    The manual mode is utter trash and shifts on its own program with only a limit to the top gear selected. Manually selected shifts happen sloooooooooowwwwwwwlllllllyyyyyyy.
    Tow-haul mode helps make it more tolerable but still not perfect, and needing to activate tow-haul just to get acceptable performance is pretty annoying.
    In 2007 when the truck came out it was the best transmission you could get in a 1/2 ton. That ship sailed a long long time ago.
    Same can be said for the 3UR-FE. Class leading in 2007, but times change.
    The only people buying the current Tundra are Toyota fan bois, who are too blind or biased to acknowledge the antiquity of the current Tundra, and troglodytes who want Stone Age technology because they hate new things. The Tundra may be more reliable, but judging by the tiny number of users here that have a truck much older than 5 years old I’d say it’s a non issue for most. You guys are talking up a benefit: long term reliability; that virtually none of you will end up utilizing. Unless you are the 2nd or 3rd owner, or a cheap ass like me who keeps the truck long term.
    So pretty much all of you guys with a Tundra still under warranty who will trade out before or shortly after it expires (most of you in this thread) have roughly zero credibility making the only argument for a 2021 Tundra. Reliability is indeed nice, but if you get a new truck every 3-4 years and you pay the premium for a Tundra with Stone Age tech, a choppy ride, bad fuel economy, no towing capacity unless you pay to put a auxiliary transmission cooler on, and mid pack power you’re kind of making a questionable decision.
    As much as I like Toyota if I were most of you guys and content to have truck payment and be under warranty all the time, I’d probably be driving a new F150 3.5EB or GMC Sierra with the 6.2L on a rinse and repeat cycle every 4 years or so taking advantage of the normal big discounts and financing deals. If I gotta have a payment it might as well be on something nice to drive and both of those options currently hand a 2021 Tundra it’s ass in the enjoyable to drive department.
  17. Jul 5, 2021 at 1:03 PM
    #8747
    Jaxyaks
    Jaxyaks New Member
    So it works just like the Tacomas....thats funny because I hear from guys with Tundras all the time that talk about the trash transmission in the Tacoma. (I currently own a Tacoma and am looking at buying the
    new Tundra for hauling and towing)
  18. Jul 5, 2021 at 1:05 PM
    #8748
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Also, direct injection.
  19. Jul 5, 2021 at 1:11 PM
    #8749
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    I’m just gonna leave this little
    Gem here for the GM fan bois. To thinks that some dimwit bought it despite the stickers. And his only concern is the bed to cab body lines hence it being in the collision center….
    ScottsBad and JuicyJ like this.
  20. Jul 5, 2021 at 1:15 PM
    #8750
    Coal Dragger
    Kung Fu Dick
    I haven’t driven a current Taco with the 6 speed, but generally Toyota/Lexus have a habit of programming transmissions for fuel economy above all else.
    Suffice to say I am not a big fan of that programming strategy as a default. If they want to offer an Eco mode for saving fuel at my discretion I can just ignore that function. Don’t foist it on me at all times and make me drive around it, or deactivate it.
  21. Jul 5, 2021 at 1:18 PM
    #8751
    Coal Dragger
    Kung Fu Dick
    Was going to point that out as well.
    Direct injection and a higher compression ratio to go with it. Also often overlooked is the improvements in cylinder heads over time. If you can make a head flow more air in and out, you can make more power.
    Toyota has had 14 years with the 5.7L and revised the intake and exhaust ports….. never.
  22. Jul 5, 2021 at 1:18 PM
    #8752
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    And a whole 200 lbs more payload than my truck (assuming that's 672 kg). :D
  23. Jul 5, 2021 at 1:20 PM
    #8753
    YotaMan
    Colorado Springs
    2021 Platinum
    Geez, you sure are making yourself sound like an ass around here..
    I myself have plenty of power and a joy to drive with the added whipple. Why don't you step your game up from your busted ass 07 then ;)
    :burnrubber:
  24. Jul 5, 2021 at 1:22 PM
    #8754
    JuicyJ
    JuicyJ New Member
    Nissan has a similar issue with the 7AT they have been using for a while. On low-torque engines, like the VQ37 (G37 and EX35) the 7AT is annoying, doesn't seem matched to those low-torque, high revving VQ37 3.7 V6.
    However, the 7AT in the Titan and twin turbo Q50 and Q60 cars is a much better match, those vehicles have the torque to cover for early upshifts, reluctant downshifts.
    I suppose that's the real issue for the Tacoma, I have heard the 3.5 is relatively low-torque, so if the trans shifts too early, it brings down the entire driving experience. Just a guess.....
  25. Jul 5, 2021 at 1:28 PM
    #8755
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Seriously, Toyota drive mode is nothing but a paddle commander. Eco is 80% full throttle, normal is 100% full throttle, and sport is 100% @ 80% throttle…
  26. Jul 5, 2021 at 1:36 PM
    #8756
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Sounds like you have us all figured out, lol.
    I can only speak for myself, but getting my Platinum for about $15k less than Ford wanted for theirs had a lot to do with my decision. I really liked the F150, but not as much as they did.
    And reliability is not just about going 300k miles in a truck. It's also about spending my time fishing instead of going back and forth to the service department.
    You seem mad. Are you angry at us? :)
  27. Jul 5, 2021 at 1:36 PM
    #8757
    Coal Dragger
    Kung Fu Dick
    You have had your truck for all of 3 years, and already modified because it lacked adequate power for your needs or wants. That kind of says it all.
    How long did you have your last truck? Curious if you’re a long term owner or a rinse and repeat guy? Not judging either way, your money your choice.
    I will point out that if you wanted a faster truck a GM 6.2 with a blower would be the more effective route just due to the huge aftermarket.
    twolf likes this.
  28. Jul 5, 2021 at 1:38 PM
    #8758
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    For buying a 2007 in 2007 and still having it. Congrats! You want an award…or a chest to pin it on?
    Cpl_Punishment likes this.
  29. Jul 5, 2021 at 1:40 PM
    #8759
    Coal Dragger
    Kung Fu Dick
    Angry no. More amused than anything else. There is a lot of cognitive dissonance in automotive forums where owners/fans of a certain vehicle convince themselves in an echo chamber that not only was their choice the best, but that those who chose other vehicles will literally be stranded on the side of the road or spend every waking hour in the shop.
    Unless you buy something made in Britain or Italy being stranded or in the shop perpetually are highly unlikely for the first owner of any vehicles sold today in North America.
    Doofus likes this.
  30. Jul 5, 2021 at 1:41 PM
    #8760
    JuicyJ
    JuicyJ New Member
    I wouldn't mind owning a domestic truck if the service departments were better. But, if you own a $60K vehicle and take it to a place that sees Escorts, Focuses, Neons, Cavaliers, Cobalts, all the time it's gonna suck.
    I've had troublesome cars before, but the dealers treated their customers really well (German car) so it wasn't a big deal.
Thread Status:
