2023 Tundra Oil Change Interval
Discussion in '3rd Gen Tundras (2022+)' started by drcuface, May 24, 2023.
  1. May 29, 2023 at 9:38 AM
    EddieBolt
    EddieBolt New Member
    David
    2020 CM SR5 4x4
    I always feel comfortable at 5k.
    Mattedfred likes this.
  2. May 29, 2023 at 11:10 AM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    I don’t expect the engine to have a catastrophic failure due to lack of lubrication when an extended drain interval is used. For example a spun bearing or something of that nature is pretty unlikely. Modern oils will still lubricate well enough to keep parts like that alive since they enjoy priority oiling within the system and have dedicated oil passages to feed them oil.
    What I do expect, and have observed with 15,0000 mile/1 year OCI’s is lots and lots of varnish in the engine where oil isn’t being force fed. Cracking open the valve cover for example and finding everything aside from the surfaces of the cam lobes covered in mahogany colored oil varnish and gunk. I expect the oil control rings on the pistons probably aren’t moving as freely as they should and the engine will be using oil. The cylinder bores are probably also scuffed a bit and the corresponding piston skirts will be too. These were on vehicles with full service history running Castrol Syntec specifically called for by BMW.
    Sure the engines made it past the warranty period, but the 2nd owner sure wasn’t happy about it.
    An oil analysis is nice don’t get me wrong, but it’s only telling you about the condition of what actually drained out of the oil pan. All oils will show some degree of breakdown in high heat areas and smoke a bit leaving varnish if you allow them to run too long.
  3. May 29, 2023 at 3:51 PM
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    Yeah, I don't care either when or where people change their oil. Under the conditions listed by Toyota which included towing, uber driving and excessive idling then you should change your oil every 5k miles, I agree. I however do not and have not been doing any of those with my truck. It is a hybrid and a full synthetic oil can last a longer time than blended and or organic based Dino oils. I change it a little early than suggested because I have found that from analysis oils with 7-8k miles is the sweet spot for where they start to break down or sheer. They then tend to not offer the same cold start protection and wear protection. The wife's explorer timberline 2.3 liter turbo 4 ford app gives the percentage of oil life remaining. It specifies synethtic blend oil every 5k miles, we run synthetic and extend that out to the same 7-8k miles. As I stated before the sports car I have gets a fresh synthetic oil change every 6 months and that mileage could be 20 miles to 100 miles. Regardless I do believe in oil changes but from the research and tons of hours I spent on bob is the oil guy this is what I came up with. I will say I have owned 20 plus turbo vehicles and have never had one fail on me yet, posting many hundred of thousands of miles on them.
  4. Jun 2, 2023 at 4:56 PM
    raylo
    raylo not so new member
    Frederick, MD
    The other thing you will learn from CarCareNut and watching some of his engine tear downs is that even if oil is changed within 10,000 mile intervals and the oil molecular structure is still good, the contaminants that accumulate can over time foul these low tension piston rings. Some motor models seem to be more susceptible than others but for the minimal additional cost to do 5000 mile oil change intervals it is simply not worth pressing the issue... if you plan to keep your truck long term, anyway.
  5. Jun 2, 2023 at 6:14 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    And how can we not link to the legend himself!
    https://youtu.be/TJhFAwFv-O0
  6. Jun 3, 2023 at 4:07 AM
    raylo
    Frederick, MD
    Clockwatcher68 likes this.
  7. Jun 3, 2023 at 5:16 AM
    raylo
    Frederick, MD
    It's not really 50% more. Remember the stipulation for severe use, which most of us fall into. Short trips and time are major factors. And about diffs, trannies, and xfer cases? No, those are different animals. Without the contamination products from combustion they are much more stable and don't require anything more than the standard intervals for most of us. Now if you tow heavy... like you pulling cows and huge round bales... that might be a little more frequent, especially for the tranny.
  8. Jun 3, 2023 at 8:55 AM
    Coal Dragger
    Kung Fu Dick
    Yep. Euro you should probably plan on dumping diff and t-case fluids at about 1/2 the listed interval. Also don’t buy the bullshit about the transmission being a lifetime fill, at least not if you tow or do a lot of stop and go driving.
  9. Jun 4, 2023 at 1:39 PM
    Texan-1794
    Texan-1794 New Member
    2023 Tundra 1794
    2023 Blueprint Tundra 1794 - Stock to the Bone!
    That says it all :yes:
  10. Jun 4, 2023 at 8:08 PM
    Pandarturo
    Pandarturo New Member
    Ok now what about pecan?
  11. Jun 4, 2023 at 9:26 PM
    drcuface
    drcuface [OP] New Member
    Ah so its similar to subaru? My subaru has to use the OEM filter too. I wasn't aware toyota has issues with non OEM filters. Any reason why?
  12. Jun 4, 2023 at 9:29 PM
    drcuface
    I think I am just giong to get a fumoto drain valve and do my oil changes every 7500!
    Boomer08, Tom976 and FLYH2O like this.
  13. Jun 5, 2023 at 7:08 AM
    Clockwatcher68
    Clockwatcher68 New Member
    23 MGM Tundra TRD Offroad
    I'm 100% convinced not to go past 5K miles between oil changes.
    Side note: I just did the first oil change on my '23 Tundra at 1,450 miles. Used Mobil 1 0W-20 and OEM filter 90915-10010. I bought some new drain plug crush washers from the dealer, but ended up not changing it out. The damn thing was stuck on the oil pan with zero interest in coming unstuck. I tried prying it off with a flat head screwdriver, but no luck. I didn't go crazy on it, as I didn't want to damage the pan. I figured it would hold during this change, which it is just fine.
    I've never owned a Toyota before, and I haven't seen the washer stick to the pan before. Any tips or advice to remove it from you long-time Toyota guys? Apparently the blue crush washers are used across many Toyota vehicles.
  14. Jun 5, 2023 at 7:31 AM
    nodak67
    nodak67 New Member
    JR
    lol, on my 14 4runner, only fluids i have replaced from oem (excluding oil/filter)
    1. all 3 diffs
    2. coolant
    thats it. i still have the oem brake pads :) at 95k miles.
    i am looking into getting the trans, brakes (maybe spark plugs, but car care nut doesnt advise under 120k or mis firings) done this summer/fall.
    Soupbean77 likes this.
  15. Jun 5, 2023 at 7:35 AM
    nodak67
    nodak67 New Member
    JR
    well any canuck worth thier salt says "eh" anyway for most things :)
  16. Jun 5, 2023 at 11:48 AM
    ScottW714
    ScottW714 New Member
    When I was selling my 2016 I took it to the dealer to get an oil change because the light had come on.
    I pull in and mention I need the light reset, they mention recommended oil change is 10k and I only had 5k on it.
    I had taken my truck to the same dealer for an oil change every 5k and not until I hit 115k did anyone mention 10k.
    The stickers were always out 5k.
    Not really sure the point, but if I had to believe someone in court, the dealership or Toyota, I would side with Toyota every single time.
    But I am in my 50's and grew up with 3k oil changes and as much as I want to do the recommended miles, I cannot bring myself to drive 10k miles without changing the oil. That just sound bananas to me.
    At 15k per year, that is 1.5 more oil changes than recommended per year, which is roughly $120, which is peanuts for most of us.
    I like 5000 and I am sticking to it.
    I did take my 2023 for an oil change at 1200 miles, it was $60 which surprised me.
    My 2016 was $80 and I think the 2023 takes more oil.
    Philipl and Mattedfred like this.
  17. Jun 5, 2023 at 9:18 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Idk about issues or not, but car care nut recommends to use Oem filter because it supposedly was designed for your particular model and has correct oil flow specifications that your engine was designed for. Whether this matters or not idk.
    Either way, it's best to do oil changes every 5k miles and Oem filter will work just fine for such short oil change intervals.
    Basically, it's a Toyota, so you don't need to try be smarter than others and use other non Oem filters. If your engine won't go past 300k miles, it won't be because of oil if you stay with Oem. Just change oil every 5k miles, with any regular oil such as Oem or mobil1 and you'll be fine
  18. Jun 6, 2023 at 4:27 AM
    raylo
    Frederick, MD
    I installed a Fumoto my last oil change, on 5000 interval. It's gonna make this job even easier and neater. Get the long nipple version.
  19. Jun 6, 2023 at 4:34 AM
    #49
    raylo
    Frederick, MD
    I actually find it helps to use ramps. There is less room under the Tundra than the 2009 Tacoma I sold... and the TRD skid pan needs to come off the Tundra, which is easier if I have a little extra room to work. So, I use my set of Rhino Ramps. If I didn't have a front skid to remove, I'd just do it on the ground, though. But at least there is no need to take the extra time and effort to pull out and setup the QuickJack for oil changes.
  20. Jun 6, 2023 at 7:56 AM
    #50
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    Same. Have done one oil change since installing it and it makes it so much easier.
  21. Jun 6, 2023 at 9:15 PM
    #51
    FLYH2O
    FLYH2O Earth First. We will log the other planets later.
    British Columbia , Canada.
    2023 Limited Double Cab TRD Off Road
    2/1 lift, Bedrug, Leer 180 cap, BFG At 285/65/18
    I installed a Fumoto on my first oil change as well. Every truck I’ve had since 2006 gets one. Clean and easy.
  22. Jun 8, 2023 at 2:04 PM
    #52
    Clockwatcher68
    How does the dealership handle the aftermarket drain plugs? I'm guessing they've seen it all?
  23. Jun 30, 2023 at 7:16 PM
    #53
    Breathing Borla
    Northern Illinois
    Too late, I’m coming over for beers , see you soon. :p
    Pandarturo and Mattedfred like this.
  24. Jul 1, 2023 at 12:10 PM
    #54
    MrKABC
    MrKABC Not so new Member
    Art
    Corona, CA
    2023 Mesquite 1794 TRD OR Hybrid
    Miller Cat Shield, Sumo Springs Blue, Diode Dynamics Stage Series hidden light bar.
    Which model Quickjack do you use? I have 5000TLXs which work fine for my Mustang and Tacoma but are too small for my Tundra. 7000TLXs?
  25. Jul 1, 2023 at 1:33 PM
    #55
    raylo
    Frederick, MD
    I have the standard 7000SLX, not the extended one. I have not yet tried it with the Tunrdra but it worked fine on my old Tacoma with the truck/suv adapters. Not sure but I might need to get the extension kit.
    MrKABC[QUOTED] likes this.
  26. Jul 1, 2023 at 4:10 PM
    #56
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    What’s your owners manual say?
  27. Jul 1, 2023 at 4:26 PM
    #57
    PNW Tundra Mike
    Southern Cal
    Thanks for sharing this. I plan on doing same after first and second changes for comparison.
    Mattedfred[QUOTED] likes this.
  28. Jul 1, 2023 at 5:54 PM
    #58
    Pandarturo
    Well don’t start another forest fire
  29. Jul 2, 2023 at 10:21 AM
    #59
    Pandarturo
    should have added an “/S” after that lol. Have fun!
  30. Jul 2, 2023 at 10:38 AM
    #60
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    Speaking of oil changes, my truck is at 4540 miles and it started displaying “service due soon” message. I thought they have it programmed for every 10k miles ? Or is that something else ?
