22 TUNDRA BACK DOOR WINDOW SEAL
Discussion in '3rd Gen Tundras (2022+)' started by MJ_19Tundra, Feb 27, 2022.
  1. Jan 10, 2023 at 6:12 PM
    Adam B
    Adam B New Member
    2022 Tundra TRD OFF-RD LIMITED- Green & 2024 Tundra TRD OFF-RD LIMITED- Silver
    Mind taking a picture of your back window seal?
  2. Jan 10, 2023 at 6:34 PM
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    Henry1jg and Breathing Borla like this.
  3. Jan 10, 2023 at 6:37 PM
    Adam B
    Adam B New Member
    Thank you
  4. Jan 10, 2023 at 9:01 PM
    mchdtw
    mchdtw New Member
    My 2023 Limited has a gap in the seal,
  5. Jan 10, 2023 at 9:33 PM
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    They’ll all have gaps it’s just if it stays down or is jacked up
  6. Jan 10, 2023 at 10:16 PM
    mchdtw
    mchdtw New Member
    That was not the question. The pic above also shows NO gap. (2 pics prior to mine) So, your statement of “they will all have gaps” seems incorrect. The question asking about 2023 models was this…
    “2023 Still have this seal gap on the back window? “
    One person posted a picture that indeed showed NO gap on his 2023, however mine, which, again is pictured above does show a gap in the window trim.
  7. Jan 10, 2023 at 10:19 PM
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    Please show me the picture that has no gap
  8. Jan 10, 2023 at 10:21 PM
    mchdtw
    mchdtw New Member
  9. Jan 10, 2023 at 10:22 PM
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    Bro you should look at who posted that picture and the statement I made
  10. Jan 10, 2023 at 10:27 PM
    mchdtw
    mchdtw New Member
    My bad. Your post. Mine has gap amongst so much more going on at 1000 miles. Been in shop for 17 days so far, only owned 60 days. Trying to find out ALL the problems with this peach.
  11. Jan 10, 2023 at 10:28 PM
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    Walk the lot. The gap is on every single truck. It’s not a big deal unless it doesn’t stay down or comes unhinged
  12. Jan 10, 2023 at 10:30 PM
    mchdtw
    mchdtw New Member
    Thanks you. I’ll be keeping an eye on it.
  13. Jan 10, 2023 at 11:23 PM
    topdec
    topdec New Member
    AWD Sprinter, 2023 4R ORP, 2 3rd gen Tundras - sold
    How come my Limited doesn't have this tab? Are the window trims different between the SR5 and the Limited?
  14. Jan 11, 2023 at 4:33 AM
    Adam B
    Adam B New Member
    Zoidberg, I honestly had to look at your pic like 5x before I realised you also had the gap. Geez it's hard to see in your pic or these eye balls are getting old.
    Shocking they haven't fixed this yet, or that they thought it was a good place for draining :(
  15. Jan 11, 2023 at 4:59 AM
    Adam B
    Adam B New Member
    Firehawk, mind taking a pic so we can see? I''ve yet to see one without the gap.
  16. Jan 11, 2023 at 7:44 AM
    Jriedy85
    Jriedy85 New Member
    Josh
    2022 SR5 Tundra
    I'm going in Saturday to have these replaced. Toyota has acknowledge that there is a problem with those seals and released a new replacement seal to fix it. Mine has been peeling up since I bought the truck last March.
  17. Jan 11, 2023 at 7:57 AM
    Adam B
    Adam B New Member
    Acknowledged that the seal is lifting?or that the seal is short? Find it hard to believe they are installing a longer seal when all the 23's come with short seals. You have any part numbers for the new seals? Jriedy85 you mind keeping us up to date on this? Pics and such? Thanks in advance.
  18. Jan 11, 2023 at 8:00 AM
    Jriedy85
    Jriedy85 New Member
    Josh
    2022 SR5 Tundra
    That's what I took away from it is they acknowledge that the seal is too short. I remember seeing the paperwork and it showed that Toyota had a new part and a procedure to replace it. I'll see if I can get a hold of it when I'm at the dealer Saturday. Said it takes 2 hours per side to replace. So I'm gonna be sitting there a while.
  19. Jan 11, 2023 at 8:02 AM
    #49
    Adam B
    Adam B New Member
    Ok thanks again. I would certainly like mine fixed as I'm sure 1000s others would. Look forward to the follow up, cheers!
  20. Jan 11, 2023 at 8:18 AM
    #50
    TheLordwoulddriveaTundra
    TheLordwoulddriveaTundra New Member
    2022 Tundra Platinum Crewmax 4WD, Mag Grey
    Talons Cat Plate Tuff Skinz Inserts RetraxOne XR Bed Cover Premium Shield PPF Revivify Coating OEM Console Safe WeatherTech Mats
    Yeah, they definitely have a new part that fixes this from the first run. My dealer proactively asked if I had concerns about the window seals when I took it in a few weeks ago. Told me they'll replace it witht the new part if I have issues.
  21. Jan 11, 2023 at 8:22 AM
    #51
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    New deals still have the gap. It just fixes the separation/ unhinging
  22. Jan 11, 2023 at 8:26 AM
    #52
    I'm not concerned with the gap, just don't want it coming unhinged. I do have a new issue that popped up with the rear window on the driver side though. When it rains hard or I run it through a touch free wash, the window does not go down smooth. It's kind of jerky going down until it's dry.
    Troyboy84 likes this.
  23. Jan 11, 2023 at 12:44 PM
    #53
    Adam B
    Adam B New Member
    If it's jerky going down until it's dry, wouldn't you prefer the gab was gone so it couldn't get wet in the first place? Should prolly be concerned about the gap.
  24. Jan 11, 2023 at 12:46 PM
    #54
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    Has nothing to do with the gap . My 22 crv front windows did the same thing. Needs the clamp tightened and the track greased
  25. Jan 11, 2023 at 1:01 PM
    #55
    Like Zoid said, gap has nothing to do with it. Those bottom seals aren't water tight on any vehicle. That's why all vehicle doors have drains at the bottom. The vast majority of people have no idea there are drains in every one of their doors unless they get clogged and their doors fill up with water. It's like the drains on a sunroof, moves water intrusion away unless its clogged. A lot of sunroof leaks and sloshing water in doors is because of a blocked drain.
    Sixty9Four20 likes this.
  26. Apr 14, 2023 at 11:15 AM
    #56
    NATE4SURF
    NATE4SURF New Member
    Laguna Hills, CA
    '23 TUNDRA TRD CREW 4X4, was ‘05 TUNDRA TRD CREW 4x4
    Yea picked up mine yesterday and still has the gap.
    iiawah808 likes this.
  27. Sep 4, 2023 at 8:42 PM
    #57
    Midnightyota
    Midnightyota New Member
    What is different on the new seal that keeps it from popping off? I took mine off and saw the tabs thats should retain the seal, I can't see why they aren't holding it on and I certainly hope the new seal doesn't pop off?
    My truck is a new 23 as of June fyi.
  28. Oct 5, 2023 at 8:22 AM
    #58
    extremes074
    extremes074 New Member
    David
    West Coast, Florida
    22 1794 TRD Off-Road
    Anyone happen to have the part number for the new seals? Is it true that newer trucks don't have this issue anymore?
    Haven't been on here in quite a while. Last, I went to my dealer for service they said they'd replace but I haven't heard anything and it's been a few months :(
  29. Oct 5, 2023 at 3:09 PM
    #59
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    My June 2023 build has the same gaps.
    Out of curiosity I looked at my wife's 2022 4Runner. It also has the same gaps, but they are less than half the width of the my Tundra's. I also noticed the seals on her ride seem to be made of stiffer rubber and they fit more snugly to the windows.
    Fortunately, my Tundra doesn't have any wind noise like so many others do...yet. In fact, I haven't had a single warranty issue or recall on it. It just rolled over 5K miles today. Hopefully I didn't just jinx it.
  30. Oct 5, 2023 at 3:40 PM
    #60
    Markus
    Markus Hermitic Member
    Mark
    Boring, MO
    2 1794 Tundys 2014 and 2023 AG TRD
    A few
    I prefer to live in denial and not look...
    Sixty9Four20 and Matt2015Tundra like this.
