275/65/20 or 275/60/20 on 3rd Gen
Discussion in '3rd Gen Tundras (2022+)' started by Jack Straw, Apr 2, 2022.
  1. Sep 8, 2022 at 9:01 AM
    #61
    benca1
    benca1 New Member
    2023 TRD Offroad SR5 Crewmax 4x4
    295/60/20 Wildpeaks 20” limited wheels TRD running boards TRD exhaust OEM bed mat OEM bedcover OEM all weather Mats 4Knines rear seat cover
    also one thing to consider like the Lunar above is if you are a sport or not as well. The sport is .5" lower than the others. So if leveled with say a 1.75" RC kit it is still .5" lower than a non sport.
    Henry1jg likes this.
  2. Sep 8, 2022 at 9:03 AM
    #62
    benca1
    benca1 New Member
    Here is your comparison of 275/60/20 vs 295/60/20. My buddy who did the westcott kit on his SR5 did 295/60/20 and wishes he had gone 35x11.50x20 instead now.
  3. Sep 8, 2022 at 10:19 AM
    #63
    99ways2die
    99ways2die New Member
    Side profile on OEMs with 285/60/20 Cooper Discoverer AT3 XLTs (Wescott 3/1 Platinum lift/level kit (so in reality a 2" front lift))
    Like everyone else, i took a 3-4 MPG hit going to E rated, and larger tires.
    ...and I can only add one thing - don't go too wide on OEM rims as aside from any handling floatiness (if any), trucks with "ballooned tires" looks weird IMO.
    -99
    Libagui, =JSG= and HeyMcFly like this.
  4. Sep 15, 2022 at 1:10 PM
    #64
    ponchopd
    ponchopd New Member
    Lift or leveling?
  5. Sep 20, 2022 at 8:35 PM
    #65
    ELiDirtTundra
    ELiDirtTundra New Member
    WA
    2022 Tundra Limited
    Did you guys replace the spare tire as well? What comes close to the 18” rim for the spare tire if your tires are 275/65R20? Also, if you didn’t replace them did you leave it there or took it down to remove some weight since it is unusable.
  6. Oct 18, 2022 at 1:55 PM
    #66
    kimw880
    kimw880 New Member
    will
    22 Tundra
    275/60/20 Falken Wildpeaks at3
    Fuel Rebel 20x9 +20 offset
    Stock suspension
  7. Nov 6, 2022 at 5:56 PM
    #67
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    2023 Supersonic Red Platinum Hybrid
    Thanks for these pictures, it helps in trying to decide what size to go with!
  8. Jan 9, 2023 at 10:17 AM
    #68
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    Really like your thinking @Troa. Which tires did you get? And how do you like them now?
  9. Jan 10, 2023 at 6:20 AM
    #69
    jilez253
    jilez253 New Member
    So no leveling kit and just offset? Truck looks great! If you mind me asking, how much was the offset and hit on mpg or turning radius?
  10. Jan 10, 2023 at 8:41 AM
    #70
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    beautiful truck. I wanted white so I could redo the same rim with it like I had on my 20 . On my 22 I might have to do the same
  11. Jan 11, 2023 at 2:42 AM
    #71
    b0yax
    b0yax New Member
    you think this would fit without issues on trd pro 18 inch wheels? like rubbing or removing. i dont plan to lift or remove flaps. i want the falken wildpeak at3 295/70/r18. initially wanted the 35s but i think i will have issues with and mpg would hit low. what was your mpg so far? im still waiting for my trd pro to arrive to me from out of state dealership
  12. Jan 23, 2023 at 5:18 PM
    #72
    Llamafood
    Llamafood New Member
    2023 limited hybrid
    Just put a set of 275/65R20 nitto recon grapplers on. p metric versions that in weight 47 lbs, Definitely fits in the wheel well no issues. I can feel the gearing change a little. Slightly more sluggish off the line with a taller tire. I was worried about the tire being a little squished in without a level kit, but I think they look ok. Just a brief drive home and highway noise was fine. 65749B51-2B7F-4E29-B96E-D68B0EF0A5F8.jpg 969AA3A4-F233-4250-85B5-87FB44EDA1D7.jpg
  13. Jan 23, 2023 at 6:24 PM
    #73
    Durtywrench
    Lou
    23 Tundra platinum
    None
    almost pulled the trigger on them today but I live where it snows a lot . I’m jelly you get them
  14. Jan 23, 2023 at 6:40 PM
    #74
    Paul Moll
    Paul
    Idaho
    I've finally decided on continental terrain contact at in 275/60/20 not LT at 44 pounds. Will be 1 inch diameter larger and 1 inch wider than the OEM xt3wA junky tires. I'd go more aggressive but want to retain very good highway performance when towing. My penalty is mediocre only in mud.
  15. Jan 23, 2023 at 7:33 PM
    #75
    Llamafood
    2023 limited hybrid
    are they not good in the snow ?
    Durtywrench[QUOTED] likes this.
  16. Jan 23, 2023 at 8:07 PM
    #76
    Durtywrench
    Lou
    23 Tundra platinum
    None
    I thought they were till tire guy informed me so I didn’t pull the trigger on them until I did some research . I got mixed reviews from doing that . I’ve never owned them so I can’t give you first hand experience
  17. Jan 24, 2023 at 8:18 AM
    #77
    Llamafood
    2023 limited hybrid
    so, maybe not an issue for the non- hybrid owners.... but I did not enjoy my commute this am. the larger tire sapped way too much of the power from the final drive by lowering the ratio too much. basically rendering the hybrid mode useless for cruising. to engage it you need to be at speeds too fast for city and too slow for highway was about the only way I could get the transmission into a power band was by switching from ECO to standard drive mode and it only helped a little but didn't entirely solve the problem. I think I'm going to go down one size to a 275/60/20 so its much closer to factory ratios. The only other solution would be to run in normal or sport modes full time to keep the truck in a useable power band but it completely kills the economy. If you're looking for a balance of looks, economy and midl offroad capability... even though my 34" was a P metric at 47lbs the overall diameter is a bridge too far for my rear end gear ratios. Since i'm not willing to change gear rations im going to return the tires and go down a size. Hopefully going to a 33" gives me the balance I want. Again this may just be a complaint since mine is a hybrid and most posting seem to be running standard powerplants. or maybe my expectations were wayyyy off
    socaldad and Dhust27 like this.
  18. Jan 24, 2023 at 8:45 PM
    #78
    Paul Moll
    Paul
    Idaho
    Very interesting @Llamafood. I didn't consider that impact on a hybrid with quite large tires. I think this is a rather extreme example of what is happening even with non hybrids only they "just" have poor mpg and the trans takes care of the rest as it has lots of gears to choose from. Maybe I'm too conservative, but I'm going direct to 275/60/20 on a 1794 TRD non hybrid. OEMs are 265/60/20 Wildpeak AT3WA. When I measure them they are more like a 255/60/20 would be. They basically are chosen by Toyota mostly for mpg. Even the tread depth is a mere 9/32 on a new tire. Pretty lame. So I'm hoping that the 275/60/20 will give a bit of a diameter and ride boost without torpedoing mpg.
    Llamafood[QUOTED] likes this.
  19. Jan 24, 2023 at 8:54 PM
    #79
    Llamafood
    2023 limited hybrid
    After some more research the rear end is only 3.31 ratio … going from a 32.5” tire to a 34” dropped my ration to 3.16 … a 33” takes it to 3.25. I think anything over a 33” a new rear gear should be considered. Actually I’m kind of shocked the off road packages don’t come with a higher ratio… my old ram did and it made goi no larger a non issue without additional mods. Tomorrow am I’m swapping the 275/65r20’s for Pirelli at plus 275/60r20’s
  20. Jan 24, 2023 at 9:18 PM
    #80
    topdec
    topdec New Member
    AWD Sprinter, 2023 4R ORP, 2 3rd gen Tundras - sold
    Thanks for this info.
    I went with the Cooper AT3 4Ss in 33"s because of the weight savings vs the 34"s.
    I was regretting my decision given I could have fitted 34"s without raising the front, but your post tells me that 33"s makes sense for how I plan to use the truck as my main towing vehicle.
  21. Jan 25, 2023 at 8:17 AM
    #81
    Llamafood
    2023 limited hybrid
    I put the 33”s on at the tire shop this am. Night and day difference in drive-ability. The hybrid motor is working again in normal drive conditions and my mpg came back to 21 ish on highway. Albeit it doesn’t look as cool, this is a commuter truck, and I’m not willing to change my rear end.
    socaldad likes this.
  22. Jan 25, 2023 at 12:11 PM
    #82
    Paul Moll
    Paul
    Idaho
    This is great @Llamafood. I think you made a wise decision even though it probably cost you some $$ to make the switch.
  23. Jan 25, 2023 at 12:19 PM
    #83
    Paul Moll
    Paul
    Idaho
    Hi @topdec. I'm going with exactly the same size, only in Continental TerrainContact AT. I debated between those and the Cooper AT3 4S's. I admit the Coopers have very good reviews and are a touch more aggressive...in reality and looks. But....here's my heartache with them...a couple of buddies at work and I all decided to go with Cooper AT2 a few years ago circa 2010. It was a big mistake. We all had either balancing problems, early wear out, or very loud when worn, or all the above. Please understand that I'm not criticizing your decision as indeed I gave the Coopers a serious again look this time. My decision point came down to two things: 1) I had TerrainContacts on my previous vehicle (honda Ridgeline) and they were nothing short of excellent, even decent in the snow which many people complain about. 2- I can't get emotionally past the Cooper story in thinking that Cooper still needs some "punishing" by me not buying from them due to the multi-bad experiences with the AT2's. I know the later is not rationale, but it's just me.
    I wish you nothing but the best with the Coopers, and I can fully support BUY AMERICAN!!
  24. Jan 25, 2023 at 12:32 PM
    #84
    Fxclm5
    Fxclm5 New Member
    lakai536 likes this.
  25. Jan 25, 2023 at 12:41 PM
    #85
    topdec
    topdec New Member
    I think your experience was with a totally different tire. I had the AT3 4S on my 4Runner Trail and they were excellent. Here's my post regarding my previous 4Runner https://www.4runners.com/threads/tires-post-pics-if-you-have-them.20724/page-3#post-264652
    Also, if you look at tirerack, the continentals rate much lower than the coopers. I consider these ratings as well when picking out tires for any vehicle. Based on consumer feedback, it looks like the Continentals do poorly in snow. https://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?type=ORAT&width=275/&ratio=60&diameter=20&tireSearch=true&filter=y
    Since you don't like Coopers, perhaps look at the Falkens if you get a lot of snow.
    Best of luck.
  26. Jan 25, 2023 at 1:36 PM
    #86
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    I know the Nokian Outpost AT are also a light tire for a 275-60-20, they have LT and the non-LT:
    LT275/60r20 = 49.6lbs
    275/60r20 = 33.4lbs
    I got the LT275/60R20 Nokian Outpost AT for summer use, I'll report back come spring time how they perform!
  27. Jan 25, 2023 at 2:04 PM
    #87
    Paul Moll
    Paul
    Idaho
    I know what you're saying @topdec. Now I'm confused....the Continentals are rated top on Consumer Reports. The only real difference seems to be that Cooper wet braking is a touch lower, and the Cooper snow (probably mud also) traction is a touch higher.
    I will do some towing for sure, so want the best I can get there. But we'll also go off road to lite off roading on gravel/dirt roads with the travel trailer, so some decent capability is important there too. Ugh...decisions decisions...
    Thoughts welcomed :)
  28. Jan 25, 2023 at 2:11 PM
    #88
    raylo
    raylo not so new member
    Frederick, MD
    Which wheel is this? I have the OR 18s and am thinking that 33s on these 20s would be better for my 95% road use. And look better.
  29. Jan 25, 2023 at 2:38 PM
    #89
    Durtywrench
    Lou
    23 Tundra platinum
    None
    These are the stock platinum wheels
    raylo[QUOTED] likes this.
  30. Jan 25, 2023 at 2:42 PM
    #90
    raylo
    Frederick, MD
    Anyone know the part number for these?
