37s in stock suspension
Discussion in 'Wheels & Tires' started by longuyen88, May 8, 2024.
  1. May 8, 2024 at 2:57 PM
    longuyen88
    longuyen88 [OP] New Member
    Here’s my stock suspension Tundra with stock 20” wheels and 37s. No rub. I did a lot of research and many people said it couldn’t be done. The truck drives as smooth as any stock tundra without compromising COG and droop travel.
    You can follow me on IG @longborghini_wynn since I don’t post much here.
    The Dude, Racls6821, ARCOVT23 and 5 others like this.
  2. May 8, 2024 at 4:08 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Looks right! What's your wheel offset?
  3. May 8, 2024 at 5:23 PM
    longuyen88
    stock +60 offset and 1.25” spacers
    HulkSmurf14[QUOTED] likes this.
  4. May 9, 2024 at 9:58 AM
    Redseal199
    Redseal199 New Member
    2021 CM NightShade
    Not trying to sound like a debbi downer but you change the game once you go to 37's. If you wheel at all expect issues with ball joints control arms axle shafts etc. Truck looks great!
  5. May 9, 2024 at 10:05 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Wouldn’t recommend 20” wheels for off-road either…
    DexterL likes this.
  6. May 9, 2024 at 10:06 AM
    BreyTundy
    BreyTundy New Member
    Andrew
    Colorado Springs
    2016 White DC TRD
    Killer looking rig! Funny how people think you need a lift to run larger tires (I used to as well). If you actually use all your suspension travel, at some point in the range of motion your suspension will effectively be at stock ride height. If your tires don't fit at stock height, then they won't fit when your lifted suspension is compressed either.
  7. May 9, 2024 at 10:35 AM
    longuyen88
    THIS EXACTLY!!! A lifted truck isn’t desirable for many reasons. You want to fit the biggest tire with as low COG as possible. You start compromising a lot when you deviate away from the stock geometry.
    BreyTundy[QUOTED] likes this.
  8. May 9, 2024 at 10:37 AM
    longuyen88
    Ideally 17”. But realistically, I’m mall crawling 70% of the time. And when I do off road, I’m not going King of Hammers, I’m on fire roads and mild obstacles. Key is to know your limits of your equipment, if I wanted a crawler I wouldn’t buy a tundra.
    BreyTundy likes this.
  9. May 9, 2024 at 10:38 AM
    longuyen88
    Good opportunity to upgrade as those weak points come up!
  10. May 9, 2024 at 10:44 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Can't disagree with you! Having said that, I do think there is a happy medium between gaining ground clearance and wheel travel with aftermarket coilovers without pushing it to the point where CV angle is compromised. It's like anything else in life, a little give and take.
  11. May 9, 2024 at 11:56 AM
    longuyen88
    When a lift is needed, I’d take inspiration from the TRD-PRO, which is a mild 2” lift. Toyota probably have done a lot of research into the longevity of components at this height.
  12. May 9, 2024 at 12:05 PM
    mass-hole
    mass-hole New Member
    So you don't need to extend the bump stops or anything to keep the 37's from eating the tops of the fenders/wheel wells when you stuff them?
    I know on the 200 series Land Cruisers, they cannot run 37's without extended bump stops and/or cutting fenders or running a bodylift to gain more clearance above the tire. The extra 2.5-3" of tire radius puts the 37's into the tops of the wheel wells.
    Also, are these a full 37x12.5 or are the skinnies. I know there are 37x11.5's out there now.
  13. May 9, 2024 at 12:22 PM
    Skaufma0
    Skaufma0 Just a little stitious.
    Rock Hill, SC
    2018 MBM Limited CM
    That would be my main concern. I've had many a lowered vehicle's tire chew into the fender or liner because of the same premise.
  14. May 9, 2024 at 12:36 PM
    longuyen88
    Maybe at some point I’ll do the “auto fender delete mod”, but right now, I plan on using larger bump stops to increase the effective spring rate and decrease the likelihood of the wheel hitting the liners on hard bounces.
    Tire is 12.5” width. I would’ve used 11.5” if it was available from cheaper brands, but only Toyo makes them right now.
  15. May 9, 2024 at 12:57 PM
    mass-hole
    It it were me, I would run the extended bump stops and maybe do a small spacer on the coilover to regain some of that lost travel.
    The TRD Pro trucks usually come with longer travel shocks comparable to the aftermarket extended travel coilovers so I think that Toyota feels the extra droop travel is fine for the CV's.
    longuyen88[OP] likes this.
  16. May 19, 2024 at 11:24 PM
    Racls6821
    Racls6821 New Member
    Saturday
    Looks great! Are you able to run OEM wheel locks with the 1.25" spacers? I know some of the Land Cruisers and Tacoma have had issues with them.
  17. May 19, 2024 at 11:57 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    When I added the Fox TRD Pro shocks, I gained exactly 1.5".
  18. May 20, 2024 at 3:03 AM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    Not to derail this thread , but I like that gloss black grille! I was thinking of doing that on my MGM Tundra. Nice ride!
