3D Printing Tundra Mods/Accessories
Discussion in 'General Tundra Discussion' started by THORYOTA, Sep 21, 2021.
  1. Oct 3, 2021 at 7:51 AM
    Redman333
    Redman333 New Member
    Jared
    Tundra
    Yes
    I use fusion 360. It’s similar to Onshape, though I personally prefer fusion 360. There is a free version still, even though it’s a bit confusing to find.
    mostly though I use Shapr3d on my iPad Pro 12.9”. I absolutely love modeling on my iPad. Way most intuitive then fusion or Onshape and more powerful then Tinkercad. It’s a paid service though, but I have found it’s worth it for me. I’m just learning modeling and having my iPad on me all the time and being able to model when ever there’s a free second has helped me a ton in learning this hobby.
    clarkritchie and t300 like this.
  2. Oct 3, 2021 at 9:03 AM
    PJR202
    PJR202 New Member
    Thanks for the info. I'll check it out. I wouldnt have thought it can be done on an ipad. I use an ancient laptop that likes to randomly lock up and need rebooted. I have a slightly newer one, but it's one of those kind that is a detachable tablet. it runs windows mobile, but can be switched to classic windows view as well. It wouldn't run tinkercad. It was so slow it was maddening. Maybe Fusion 360 will operate on it.
  3. Oct 3, 2021 at 9:08 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Shapr3d is also what I use, though still just learning
  4. Nov 29, 2021 at 12:24 PM
    angkorstrong
    angkorstrong New Member
    2020 Sequoia TRD Pro
    sub'd ! let me know if you guys need things printed in abs/asa. I run a 3d print farm
  5. Mar 2, 2022 at 5:20 AM
    THORYOTA
    THORYOTA [OP] God of Thunder
    Thor
    Asgard
    2021 MGM TRD CM "Mjölnir"
    @angkorstrong @RainMan_PNW @Redman333 I found a nice .dae model of a 2014+ tundra. Y'all know what I can use to convert it to .stl or .obj? I cant open it with autocad or shapr3d
  6. Mar 2, 2022 at 10:33 AM
    angkorstrong
    i dont use .dae files but a quick search there are converters online. Its a model/mesh? most of the time you lose alot of detail when converting it
  7. Jan 13, 2023 at 7:16 AM
    THORYOTA
    Thor
    Asgard
    New project I'm working on:
    upload_2023-1-13_10-13-59.jpgupload_2023-1-13_10-14-26.jpgupload_2023-1-13_10-14-45.jpgupload_2023-1-13_10-15-9.jpg
    I basically used pictures and rough approximations for the dimensions. I know it will fit on a truck, I don't think it would dimension exactly as the real thing. @RainMan_PNW, do you think you could bust out your caliper when you get a chance?
  8. Jan 18, 2023 at 9:06 AM
    Efreet6669
    Efreet6669 New Member
    '07 Limited Red Salsa Pearl,'23 TRD Pro Solar Octane
    Have this shifter in my '07.
  9. Jan 18, 2023 at 3:56 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Call me Tom
    Tom A. Hawk esq.
    RainMan_PNW likes this.
  10. Jan 19, 2023 at 7:11 AM
    THORYOTA
    Thor
    Asgard
    Would you mind measuring the width of the top, the overall height, and the diameter of the circle?
  11. Jan 19, 2023 at 7:24 AM
    Efreet6669
    No worries, be home this weekend and send you the measurements.
  12. Jan 19, 2023 at 7:36 AM
    THORYOTA
    Thor
    Asgard
    RainMan_PNW and M3Tundra-JK like this.
  13. Jan 27, 2023 at 6:59 AM
    Htoad
    Htoad New Member
    Larry
    2018 Gray Tundra Crewmax Limited 4x4
    Has anyone made or seen a 3D printed Fuel Door? I have a 2018 Crewmax Limited. My Gas door either blew off or got stolen a few days ago and can not find anything but "covers" for an existing Door (Lid), but you still need the door to attach it to.
  14. Jan 27, 2023 at 6:18 PM
    Efreet6669
    Thoryota,
    Full length: 6 in
    Width of cylinder: 1 5/8 in
    Length of cylinder: 2 1/2 in
    Bottom square: 1/2 in
    Bottom square to edge of cylinder: 5 in
    THORYOTA[OP] likes this.
  15. Jan 28, 2023 at 7:12 PM
    THORYOTA
    Thor
    Asgard
    Thanks, Dude!
    :fistbump:
  16. Jan 28, 2023 at 7:29 PM
    THORYOTA
    Thor
    Asgard
    I don't believe i've seen one. Do you mean only the door? send a pic of the aftermath and maybe I can help more.
    Here's the Fuel door part on Toyota:
    https://parts.toyota.com/p/Toyota_2...ted/Fuel-Filler-Door/63220793/773510C090.html
  17. Jan 28, 2023 at 8:43 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Sorry - I missed this tag
    It looks like you got the critical dimensions
    THORYOTA[QUOTED][OP] likes this.
  18. Jan 30, 2023 at 4:35 AM
    Htoad
    Htoad New Member
    Larry
    Thoryota: The hinged part is still there, still opens/closes, just the "Lid" (I think it's technically called) is missing. I did order an OEM unpainted one for about $70 but in case it goes missing again would still like to have the ability to have one 3D printed. Also, there's an RBP one that looks pretty cool that apparently has been discontinued and I think the company is out of business or something because you can't get it anywhere. If a 3D printed one was available I would think it would be easy to add a simple custom something to the outside of it.
  19. Jan 30, 2023 at 11:08 AM
    #49
    THORYOTA
    Thor
    Asgard
    OK, that makes more sense now. The "lid" just came off, right? Does it just snap on to the "arm"?
    I'll look at mine and see if I can mock something up when I have a sec.
  20. Jan 30, 2023 at 1:06 PM
    #50
    Htoad
    Htoad New Member
    Larry
    That would be awesome, thank you! Yes, it does appear to just snap on. Two rows of three, one on top one on bottom. And all the "clips" or whatever you'd call them seem to be intact on my end. Don't try hard enough to break yours though, I can take better pictures, measurements, whatever when I get my new one.
