3rd Gen Suspension Lift - MEGA THREAD
Discussion in 'Suspension' started by KroppDuster, Jun 10, 2022.
  1. Oct 30, 2022 at 9:00 PM
    #511
    Shave Ice
    Shave Ice New Member
    j.robert
    2022 Tundra Sport
    167’s are in stock as per the website. 169’s are sold out.
  2. Oct 31, 2022 at 9:47 AM
    #512
    JoeInMinn
    JoeInMinn New Member
    2022 1794 Trd
    What's the ride quality like on the ICON? I have never used them. I have the wescott 3/1 want to upgrade to something better next spring. I'm most interested in ride quality as 90% of the time its my daily driver. Possibly would like to go a touch higher to a true 3" lift. I also talked to a dobinson retailer they said they were looking at January to have a kit out don't know much about them either.
    oxlsu40, ace9457 and Kap1 like this.
  3. Nov 1, 2022 at 12:19 PM
    #513
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    chatted with them and they recommended the c59-185's for the weight and height needed
  4. Nov 2, 2022 at 8:07 PM
    #514
    Shave Ice
    j.robert
    2022 Tundra Sport
    Did they mention the spring rate on that spring? Is it higher or lower than the 167’s?
  5. Nov 3, 2022 at 8:47 AM
    #515
    DexterL
    DexterL New Member
    they did not, I will ask them.
    Kap1 likes this.
  6. Nov 3, 2022 at 9:00 AM
    #516
    DexterL
    DexterL New Member
    C59-167 is 227lbs/inch spring rate
    C59-185 is 277ibs/inch spring rate
    Kap1 likes this.
  7. Nov 3, 2022 at 9:19 AM
    #517
    KroppDuster
    KroppDuster [OP] A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    This is good to know. I've been curious how the OMEs compare to the Dobinsons. I went progressive OMEs that range from 240lbs at the top end to 300lbs on the bottom end.
  8. Nov 3, 2022 at 12:27 PM
    #518
    DexterL
    DexterL New Member
    Will report back, ordered them today!
  9. Nov 9, 2022 at 12:34 PM
    #519
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    She’s Getting there.
    54269963-E8EB-48C0-9632-CC932E81F4DE.jpg 5AF56BB9-8DB3-450D-A8B1-6B5D6D48E470.jpg
    Yaboy, TOTAL CHAOS and Sparky916 like this.
  10. Nov 9, 2022 at 12:36 PM
    #520
    KroppDuster
    Bilstein 5100s
    Pittsburgh jacks....
    Kap1 and jgoliath[QUOTED] like this.
  11. Nov 9, 2022 at 12:40 PM
    #521
    jgoliath
    It’s a game of get it off the jack and onto the jack stands as fast as possible lol.
  12. Nov 9, 2022 at 12:43 PM
    #522
    KroppDuster
    Bilstein 5100s
    :rofl: I feel you. I kept one Pittsburgh jack as a backup. I do like their Daytona jacks though...the Snap On knockoffs. Got 2 of those and they've been pretty solid for me.
  13. Nov 9, 2022 at 12:44 PM
    #523
    jgoliath
    You should try out the Pittsburgh breaker bar.691BBEFD-B218-49DF-B4D5-1A6D3AE237A8.jpg
  14. Nov 9, 2022 at 12:45 PM
    #524
    KroppDuster
    Bilstein 5100s
    Don't you mean the "broken" bar? lol
    jgoliath[QUOTED] likes this.
  15. Nov 9, 2022 at 12:48 PM
    #525
    KroppDuster
    Bilstein 5100s
    In all seriousness...how did the UCA install go on the DS? You have to remove the air box & ECU, don't you? I'm always worried about fiddling with the ECU.
  16. Nov 9, 2022 at 12:52 PM
    #526
    jgoliath
    If you’re doing it all at once. Make sure you do the UCAs first, before the coilovers. I made the mistake on the passenger side to do the UCAs after the coilovers and had issues getting it all back together.
    The air box is just pulls out. No fasteners. The connections from the cables to the ECU are VERY robust so I’m not worried about how it was removed.
    also, compared to how you swap UCAs on a tacoma, this was nothing.
  17. Nov 9, 2022 at 2:14 PM
    #527
    Sparky916
    Sparky916 New Member
    Blake
    22 Lunar Rock Limited TRD OF
    Air box is super easy to remove and you just have to loosen a few screws holding the ecu and harness. When I did my UCA's I never unplugged the ECU.
  18. Nov 11, 2022 at 6:15 AM
    #528
    jgoliath
    Need to get some better pics on level ground. I also plan on bumping the front coilovers up another .75 inches when I get a chance. The front is Currently set to about 1.75” of lift so there is some rake. The rear equated to about 3 inches of lift without any load in the bed. 25AC0B8D-F91D-417D-8FEA-EB04B7E162D2.jpg
    Front
    Icon 2.5 VS RR COILOVER KIT
    Icon SWAY BAR DROP KIT
    Total Chaos UNIBALL UCAs
    YotaMafia Extended Brake Lines
    DuroBumps Front Bump Stops
    Rear
    ARB (Old Man Emu) 2863 Coils
    Dobinsons MRR 3-way Adjustable Shocks
    Icon BILLET REAR LOWER LINKS
    Icon BILLET UPPER LINKS
    Icon BILLET REAR ADJ TRACK BAR
    TRD Lift Kit Parking Brake Relocation Brackets
    TRD Lift Kit ABS/Differential Bracket
    Timbren Active Off-Road Bumpstops
    Sitting on RRW RR4-V wheels with Falken Wildpeaks 285/75/17 tires (about a 34” tire”). 37s coming soon.
    dragokvm and iiawah808 like this.
  19. Nov 11, 2022 at 6:24 AM
    #529
    DexterL
    DexterL New Member
    Selling my Dobinsons c59-559v, 2in lift no load, 440/470 height 19mm wire height
    used for 4k miles- $200 shipped.
    Installed C59-185 2-3in 220lbs 80 series coil yesterday
    Kap1 and ryanwgregg like this.
  20. Nov 12, 2022 at 5:21 AM
    #530
    bigjuice
    bigjuice Digging in for the rainy fall and winter.
    WA State
    2024 Terra TRD Pro
    Are these (c59-559v) stiffer than the OE that come with the TRD OR?
    Looks like it gives you the 2” rear lift without spacers (unlike the TRD lift setup) but trying to figure out:
    1: Are they progressive?
    2: Are they stiffer?
    Taikowaza likes this.
  21. Nov 12, 2022 at 6:20 AM
    #531
    DexterL
    DexterL New Member
    to be honest I have no idea, I drove the truck stock for 500 miles, had it lifted at Adventure Motor Sports, then drove it another 2.5k miles home. The truck rode better than stock for me. Best bet is to call dobinsons and ask them, they are great and super helpful
    ryanwgregg and bigjuice[QUOTED] like this.
  22. Nov 12, 2022 at 11:45 AM
    #532
    t300
    t300 New Member
    Manitoba
    22tundra
    Before I call Dobinsons, any known rear spring, preferable progressive, that adds 1” unloaded ride height? With 2” level in the front I don’t want to add more than 1” unloaded height in rear. Weight in box varies but I could use a higher capacity spring
    Dfrink likes this.
  23. Nov 12, 2022 at 12:25 PM
    #533
    DexterL
    DexterL New Member
    My truck was pretty dang dialed with coil overs are 2.5in up front and the rear springs. I added a topper and decked system and that put me in reverse rake so I swapped the springs
    Yaboy and ryanwgregg like this.
  24. Nov 16, 2022 at 1:06 PM
    #534
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
  25. Nov 16, 2022 at 1:46 PM
    #535
    KroppDuster
    Bilstein 5100s
    I thought these might be a suspension lift but looks like they only announced 2 different spacer lifts in the vid. Bummer.
    ryanwgregg likes this.
  26. Nov 16, 2022 at 2:04 PM
    #536
    iiawah808
    Oahu, HI
    He mentioned 4.5” and 7 beginning next year. If it’s anything like previous gen then it will be a bracket lift with lower shock extensions.
  27. Nov 16, 2022 at 2:21 PM
    #537
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    ryanwgregg and iiawah808 like this.
  28. Nov 16, 2022 at 2:34 PM
    #538
    iiawah808
    Oahu, HI
    I see the Elka's which are gorgeous. I didn't see anything FOX unless I'm just not looking in the right place.
  29. Nov 16, 2022 at 3:43 PM
    #539
    Maharisc
    Maharisc w/Patty
    Karl
    My bad, they are King's not Fox... Made the change in previous post.
    iiawah808[QUOTED] and ryanwgregg like this.
  30. Nov 17, 2022 at 11:31 AM
    #540
    KroppDuster
    Bilstein 5100s
    My OR shop of choice is also an Elka dealer. They said Elka was close to releasing something to market. More options is always better.
    iiawah808[QUOTED] likes this.
