3rd Gen Suspension Lift - MEGA THREAD
Discussion in 'Suspension' started by KroppDuster, Jun 10, 2022.
  1. Apr 26, 2023 at 5:32 PM
    #1111
    ncart
    ncart New Member
    2022 Lunar Rock TRD Pro
    Take a look at Runnin4tacos too. They answered a bunch of my questions and are pretty competitive on price.
    Kap1[QUOTED] likes this.
  2. Apr 26, 2023 at 6:09 PM
    #1112
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    I ran that kit on my 2018 4runner. By far my favorite setup. Perfect blend of cost, comfort and performance.
  3. Apr 29, 2023 at 9:32 AM
    #1113
    Tundratic
    Tundratic New (ish) member
    Canada
    2010 SR5 TRD OR 2023 Limited TRD OR
    Overland outfitters and Wheel Every Weekend put together a video series where they blind tested some of the top brands. They did these tests on a Tacoma… but still interesting FWIW
    https://youtu.be/u7cygv76f8Y
    edit: it was a multiple video series with lots of good info, but below is the conclusion video (spoiler alerts)
    https://youtu.be/sJEkSmewcQE
    AND and KroppDuster[OP] like this.
  4. Apr 30, 2023 at 9:29 PM
    #1114
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    adventure motors in KC is running a sale on them- call Caleb and tell him Dexter sent ya!
  5. May 1, 2023 at 3:17 PM
    #1115
    Bird Dog
    Bird Dog New Member
    Dave
    Lindsay, ON Canada
    2022 Tundra CMLB Lunar Rock
    I got my Dobinson 2/1 IMS installed today.
    Toyo AT III 295/70r 18
    Fuel Vector +19
    Full lock the tires rub on the mud flaps.
    Is there another option of mud flap without the hump on the inside like the OEM flaps.
    dragokvm, Yaboy and iiawah808 like this.
  6. May 1, 2023 at 4:15 PM
    #1116
    platinumcelest23
    platinumcelest23 New Member
    Eric
    I’ve seen someone recommend the weathertech mud flaps for this exact reason. Check them out.
  7. May 1, 2023 at 4:17 PM
    #1117
    Bird Dog
    Bird Dog New Member
    Dave
    Lindsay, ON Canada
    Will do... thanks!
  8. May 1, 2023 at 11:17 PM
    #1118
    NHKTundra
    NHKTundra New Member
    2022 Tundra TRD Pro Lunar Rock
    Retrax. Uptop AFS bed rack. Condor XL. Dobinson rear springs. BFG 35/12.5/r18. BD light bar and ditch lights. Prinsu roof rack. Diode dynamics fog upgrade.
    Sry for being this back from a while ago, I have similar set up to you, but on TRD pro, can I use same springs on the fox shocks to get the same result?
    appreciate it
  9. May 2, 2023 at 7:01 PM
    #1119
    alpinefd100
    alpinefd100 New Member
    curious where your caster setting is at, have you tried setting to max caster, does it clear?
  10. May 2, 2023 at 7:23 PM
    #1120
    Bird Dog
    Bird Dog New Member
    Dave
    Lindsay, ON Canada
    What would the max caster be?
  11. May 2, 2023 at 7:33 PM
    #1121
    alpinefd100
    Just wondering the caster setting everyone is ending up after various lift heights (by setting the lower control arm can to the max caster setting)
  12. May 2, 2023 at 8:21 PM
    #1122
    NHKTundra
  13. May 3, 2023 at 9:00 AM
    #1123
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    OME 2865 with icon 2.0 shocks
    Before
    After
    Tundratic and Yaboy like this.
  14. May 3, 2023 at 2:51 PM
    #1124
    moonrover
    moonrover New Member
    2022 Tundra SR5 TRD OR
    Anyone recently get King suspension setup? My kit has been backordered for months.
  15. May 3, 2023 at 5:43 PM
    #1125
    Tundratic
    Canada
  16. May 4, 2023 at 10:39 AM
    #1126
    Cajuntrd337
    Cajuntrd337 New Member
    23 Tundra
    Yaboy likes this.
  17. May 4, 2023 at 2:26 PM
    #1127
    cruiserhead
    cruiserhead New Member
  18. May 4, 2023 at 3:05 PM
    #1128
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    That is the OEM 3rd Gen Lift kit btw.
    3” up front and 2” at the back.
    Once you read through the thread that @cruiserhead provided you will learn all you wanted to know and more.
  19. May 4, 2023 at 7:04 PM
    #1129
    TMMTX
    TMMTX New Member
    None
  20. May 5, 2023 at 6:30 PM
    #1130
    Blacksheep6
    Blacksheep6 New Member
    2023 Tundra TRD Off Road
    What size tire?
  21. May 5, 2023 at 7:02 PM
    #1131
    TMMTX
    TMMTX New Member
    None
    285/75/18…technically a 34.8 diameter but equates to 34” exactly when mounted and loaded.
    Blacksheep6[QUOTED] likes this.
  22. May 7, 2023 at 12:40 PM
    #1132
    green_plaid
    green_plaid New Member
    So much to go through but not finding exactly what I need. I have a 2023 Tundra SR crewmax 4x4. I only want to add higher rate springs for the rear without really any lift. I tow a camper and the tongue weight is 600lbs. Do the higher trim levels than the SR have higher rate rear springs?
  23. May 7, 2023 at 1:53 PM
    #1133
    Kap1
    Kap1 New Member
    San Francisco, CA
    My guess is that all Oem coils on Tundra are about the same.
    Dobinson has more HD springs available: https://www.dobinsonsdirect.com/pages/product-result?rq=mk_toyota~md_tundra~yr_2022-on
    And OME had HD springs as well.
  24. May 7, 2023 at 9:07 PM
    #1134
    KroppDuster
    KroppDuster [OP] A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Just sharing to spread the knowledge…
    Looks ICON has a slew of new kit combos, including their IIC Control Modules (adjust your ride from the cab or phone). They also released a few new rear coil options now.
    Yaboy likes this.
  25. May 8, 2023 at 9:37 AM
    #1135
    TexasTacoma713
    2023 SR5
    Update*
    Added a 140lb C4 rear bumper and lost about an inch…
    This spring/shock combo is A LOT better than stock btw. Stiffer than factory.
    Yaboy and KroppDuster[OP] like this.
  26. May 8, 2023 at 2:09 PM
    #1136
    Cajuntrd337
    23 Tundra
    ryanwgregg likes this.
  27. May 8, 2023 at 2:15 PM
    #1137
    Cajuntrd337
    23 Tundra
  28. May 16, 2023 at 9:36 PM
    #1138
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    I installed my Dobinsons IMS kit today. Pics coming soon.
    Everything went smooth except the rear coils. Just too damn long lol. Ended up leaving my 1” spacers and stock rear coils in. However, I did install my rear IMS shocks.
    I needed longer brake lines and Yotamafia has a long lead time. I order coachbuilder Tundra rear brake line relocation bracket from 2-2.5gens. It worked perfectly. https://shop-coachbuilder.myshopify...ke-abs-relocation-kit-provides-2-25-of-length
    So if anyone wants a cost effective alternative to extended rear brake lines, this is money. I didn’t use the abs bracket that comes in the coachbuilder kit. I looked it over and couldn’t see how it could be used. I did bend the abs brackets to gain length.
    I also installed my track bar relocation bracket I bought in ebay. In needed to persuade it into place. It looks and operates exactly like the one that comes in the 3.5 RC Lift kit. It squared up my rear axle evenly. I will hold on to my Dobinsons track bar for now and I’ll maybe install later.
    The ride is incredible compared to my preload spacer I had installed. I will figure out my rear Dobinsons coils later. I still need to get an alignment and will provide final verdict in about 100 miles.
    AND, 4mm, DMackler and 1 other person like this.
  29. May 17, 2023 at 12:16 AM
    #1139
    Kap1
    Kap1 New Member
    San Francisco, CA
    How much lift? 2 inch?
  30. May 17, 2023 at 12:20 AM
    #1140
    iiawah808
    Oahu, HI
    3” Front and 2” Rear
    I also installed Trd Lift UCA’s too
