3rd Gen Suspension Lift - MEGA THREAD
Discussion in 'Suspension' started by KroppDuster, Jun 10, 2022.
  1. Feb 3, 2024 at 8:20 PM
    #1651
    Wmitch352
    Wmitch352 New Member
    i set these to 2.75 and had some rubbing and wanted to go up more. Tried every way to crank them while on the vehicle. No chance of it happening and I’m pretty mechanically inclined. Just have to pull them back out and use the spring compressor. Not the end of the world but kings are definitely easier to adjust on the vehicle. To your point on ride quality… these are absurdly smooth. I’ve had a few nice trucks with king, icon, etc. This is the best hands down for a daily. I haven’t gotten it off-road yet but I’m sure she will do great.
    What ride height are you looking for in the front?
    crikeymike likes this.
  2. Feb 3, 2024 at 8:54 PM
    #1652
    KroppDuster
    KroppDuster [OP] A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Ideally, I’d like to get back to a 3/2 setup, which I was running before I added all of my weight. Now, I’m down to about 2/1 with my current suspension setup.
    Since I have so much weight in bumpers, armor, winch, bed cap, racks, etc…it makes setting ride height more of an art form than the typical “set it at X distance to get Y ride height” Thankfully, I’m pretty well done adding weight (except maybe some sliders if I keep dinging these steps), so once I get them set then I should be good for awhile.
    Side note: And, I realized why you can’t adjust on vehicle. Dobinsons is a fully threaded aluminum body. With spring compression, it would be too easy to booger up the aluminum threads.
  3. Feb 3, 2024 at 9:25 PM
    #1653
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    I’ve been running the dobinsons for a week now and the ride only gets better . The springs broke in some Ave I absolutely love this kit . My spring compressor broke when I did the preload collar lift so I just had to manhandle it in lol
  4. Feb 4, 2024 at 7:58 AM
    #1654
    AND
    AND New Member
    Washington, PNW
    You could do this, check this out.
    DOBINSONS HOW TO ADJUST THE FRONT HEIGHT FREE D.I.y
    https://www.youtube.com/watch?v=--vOB3EWa88
    iiawah808 likes this.
  5. Feb 4, 2024 at 8:33 AM
    #1655
    Wmitch352
    Few more
    the spanner wrench with dobinsons vs the king pin method is much easier with the kings after having both.
  6. Feb 4, 2024 at 8:36 AM
    #1656
    Wmitch352
    great tip on the top nut! The main problem I had is getting and spanner wrenches in there with enough working space. I may give it another go with this method and see but will probably just end up pulling them out to adjust.
    AND[QUOTED] likes this.
  7. Feb 4, 2024 at 4:52 PM
    #1657
    Taikowaza
    Taikowaza New Member
    I have a question for you suspension experts in this thread, thanks in advance for your thoughts. I have the 3” TRD lift kit on my ‘22 Limited.
    I replaced the rear springs with OME2866 Coils (Pair) (240-300 Progressive). I expected there’d be a spring spacer I could remove when I swapped to the OME, but there wasn’t, and my rear is about 2” higher than front right now. I like it when towing trailer (everything becomes even), but otherwise not a fan of the rake.
    I don’t want to go back to the TRD limited rear spring and am considering raising the front by swapping to the TRD Pro front Fox coilover which I believe is adjustable (my current coilover is not).
    I think the coilover pair costs a bit less than 1k. Is there another adjustable coilover I should be considering instead that will let me up-adjust the front, and also give me a superior ride? Or, if the Fox TRD Pro coilover is great, I can definitely go with that. Thank you!
    Last question- is it worth upgrading the TRD lift kit rear shocks to the TRD Pro rear shocks? In retrospect, while I really like the UCA and other TRD lift kit parts, they really cheaped out on the quality of coilover and rear shocks (and didn’t even upgrade the rear spring).
  8. Feb 5, 2024 at 12:55 PM
    #1658
    Bird Dog
    Bird Dog New Member
    Dave
    Lindsay, ON Canada
    2022 Tundra CMLB Lunar Rock
    I installed Dobinson 2/1 in July. I notice today that I have a squeak in the front driver's side. I can hear the squeak when I am turning or moving the steer wheel back and forth. Any thoughts are appreciated.
  9. Feb 14, 2024 at 8:30 AM
    #1659
    virgilus11
    virgilus11 New Member
    2022 Tundra Capstone
    1/2" front spacer 37" Cooper ATX
    TRD Pro Fox are not adjustable. Tey are set to give you about 1" of lift in the front only.
    The rear shocks from a PRO are shorther then the TRD kit shocks. They will not work that well with your 2" of lift in the rear.
    There is plenty of adjustable front coils but is not cheap.. Kings, Dobinsons and so on.
    I installed a 1" spacer in the back and a set of air bags for towing.
    Taikowaza[QUOTED] likes this.
  10. Feb 14, 2024 at 8:32 AM
    #1660
    virgilus11
    Try to have someone turn that wheel and go under to see if you can pin point the noise.
  11. Feb 14, 2024 at 9:08 AM
    #1661
    virgilus11
    Anyone knows hwo much difference is between the stock lower knuckle attachment and the one that comes with the TRD kit ?
    Toyota mechanic is telling me that, is pushing the wheel from the bottom out and it is making the alignment much easier to do. You don't have to puhs the lower arm out from the cams that much to get the camber adjustment right. He stronlgy suggest that if you install a 2" lift kit or more.
    Now, I ask him if I don't need the extended axle as well now that you push the entire assembly out ??
    He said No.
    Just curious what the other people here think ?
  12. Feb 15, 2024 at 12:49 PM
    #1662
    adolfo
    adolfo New Member
    Can i install TRD Pro Fox take offs, on a TRD Sport (Black CV axels). Should add about 1.6 to 2.1 inches to the front.
    will this cause any issues??
    i wont be doing any off roading at all.
    I dont want to spend money on the red axel if i really dont NEED them.
  13. Feb 15, 2024 at 12:51 PM
    #1663
    wxman91
    wxman91 New Engine Enthusiast
    Montana
    2022 TRD Sport 4x4 Army Green / 2021 4Runner Limited
    CBI Baja Bumper / BD S2s Falken Wildpeak AT3W 315/70R17 Method 316s TRD Pro Fox Suspension w/Total Chaos UCAs TRD Dual Tip Exhaust TRD CV Axles TRD Pro Flares + Heritage Grille Alpharex Headlights Dobinson Coils RCI Skid
    Should be fine, I had the sport axles with a 2.5" lift before changing to the red axles and never had issues. Enjoy the better ride!
  14. Feb 15, 2024 at 4:54 PM
    #1664
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    I didn't do the fox's off the pro but I did put on the bilsteins from the trd off road and a 1" spacer from cornfed. May end up going back with a 1/2" spacer. . Either way, not a problem so far and don't expect it to be.20240206_170117.jpg
    ChucklesToy likes this.
  15. Feb 16, 2024 at 2:15 PM
    #1665
    DeepH2O
    DeepH2O New Member
    Ryan
    Mississippi
    2023 Tundra Platinum
    6” RC lift 37x12.50x20 Tires 20x10 Fuel Wheels BakFlip MX4 bed cover Westin Outlaw Steps JB4 Tuner TRD Shift Knob
    Can someone give me a “worth it” or “not worth it” when it comes to the Dr KDSS BOTCK? I have a 6” lift with 37’s.
  16. Feb 16, 2024 at 5:03 PM
    #1666
    virgilus11
    To give you a straight answer,, yes is worth it
    I have about 2" of lift in the back and I used the bottom hole. Is the closest to have the bar as parallel to the ground
    I tried the top hole and was giving me a reverse angle.
    Frankly if you plan a 6" lift ,, I would definitively consider a bar that you can adjust as needed
    Wmitch352 likes this.
  17. Feb 16, 2024 at 5:11 PM
    #1667
    DeepH2O
    DeepH2O New Member
    Ryan
    Mississippi
    I already have the 6” lift. Does anyone make an adjustable for that lift size?
  18. Feb 16, 2024 at 6:37 PM
    #1668
    virgilus11
    Adjustable pan hard bar is not specifically for a 6" lift, Will work on any lift
    I would contact Dobinsons or Icon .. Seems to be the most popular here
    They will guide you
  19. Feb 16, 2024 at 7:08 PM
    #1669
    DeepH2O
    DeepH2O New Member
    Ryan
    Mississippi
    I’ve never seen an adjustable trac bar that wasn’t designed for a specific lift height. Icon is only one I can find and it’s only designed for 0” - 2” lift.
  20. Feb 16, 2024 at 7:41 PM
    #1670
    virgilus11
    Try Dobinsons
    The specs are saying 1.25" or more
    DeepH2O likes this.
  21. Feb 21, 2024 at 4:19 PM
    #1671
    Rampking01
    Rampking01 New Member
    DOBINSONS 3-2" IMS LIFT KIT
    JBA HD HC UPPER CONTROL ARMS
    METHOD MR317 18X9 +18MM OFFSET 6X5.5 106.25MM CB MATTE BLACK WHEEL
    TOYO OPEN COUNTRY A/T III BW 35X12.50R18/8LT 118R
    BabyMoose and Dfrink like this.
  22. Feb 22, 2024 at 12:42 PM
    #1672
    osu1978
    osu1978 New Member
    Yes its worth it to reduce or eliminate bump steer. If necessary an adjustable bar can be used to align your rear axle but its not going to reduce the increase in angle from the 6" lift that much compared to the BOTCK. Install your bar in the top hole and then check your axle alignment. If the axle is not aligned to your liking you can purchase an adjustable bar to fine tune.
  23. Feb 23, 2024 at 5:10 PM
    #1673
    FlatEarthToyota
    FlatEarthToyota New Member
    Have a question that I could not find the answer to by searching the thread or Google.
    I have a 2024 limited crew cab SB with the TRD off-road package.
    I just received my C4 hybrid bumper (Weighs about 174lbs (mid height w/gussets))
    https://c4fabrication.com/collections/tundra/products/tundra-hybrid-series-front-bumper-3rd-gen-2022
    Wanted to know if the Toyota OEM 3 lift (ptccy-34000) could handle the weight of the bumper?
    If not can I use the Dobinsons front coil springs (C59-840 - 3.0" lift with 110-220LBS added weight) instead of the coils that come with the Toyota OEM 3 lift to handle the weight?
  24. Feb 23, 2024 at 6:29 PM
    #1674
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    TRD kit not rated for aftermarket steel bumpers. You can run it but you’ll lose an inch. You gotta get a Dobinsons kit with springs rated for the extra weight.. Prob can’t run the springs on the puny 2” TRD front shocks. As the Dobinsons are 2.5”
    Taikowaza and crikeymike like this.
  25. Feb 23, 2024 at 9:17 PM
    #1675
    FlatEarthToyota
    Thanks TexasTacoma713
    This helps a lot. I will go with the Dobinsons kit.
  26. Feb 24, 2024 at 9:25 AM
    #1676
    Wmitch352
    Troubleshooting almost 1" lower both rear and front (passenger side lean) with a dobinsons IMS 3/2 kit. Drivers COA has about 1/4" more threads showing compared to the L. I've seen some people saying the KDSS panhard bar correction kit can "pull" the drivers side down. Maybe I installed my rear springs installed incorrectly and they are not seated all the way down? Could be a combination of rear springs not seated and need a few more turns on COA. Thanks guys. @KroppDuster thoughts?IMG_9762.jpg IMG_9764.jpg IMG_9765.png
    Yaboy likes this.
  27. Feb 24, 2024 at 10:51 AM
    #1677
    TexasTacoma713
    2023 SR5
    Did you buy the fronts assembled or assembled them yourself?
    And what’s a COA?
  28. Feb 24, 2024 at 11:02 AM
    #1678
    Wmitch352
    Coil over assembly. I put them together myself. Just made a few turns on front driver side COA and got the front leveled out from side to side but still 1/2" lower on driver rear compared to pass rear which tells me its the trac bar or rear spring not seated appropriately.
  29. Feb 24, 2024 at 11:10 AM
    #1679
    TexasTacoma713
    2023 SR5
    When I assembled my fronts, I counted 6-7 threads showing. Measured it a million times per the manufacturers specs for spacing
  30. Feb 24, 2024 at 12:35 PM
    #1680
    ryanjay11
    ryanjay11 New Member
    • Fox Performance Elite Series 2.5 Coil-Over Reservoir Front 0-3" Shock Adjustable 883-06-218
    • Fox Performance Elite Series 2.5 Coil-Over Reservoir Rear 1.5-3" Shock Adjustable 883-26-141
    • TRD Upper Control Arms PT985-3432B & PT985-3431B
    • Dr. KDSS Trackbar correction kit
    • Yotamafia extended rear brake lines
    • Dobinson's C59-843V rear coils
    COTundra23, Narco, t300 and 5 others like this.
