4.9L 2uz Turbo build, I have questions
Discussion in '1st Gen Tundras (2000-2006)' started by VR6T, Aug 3, 2024.
  1. Aug 7, 2024 at 9:16 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Since i'm fine with the power i have, and dont wanna worry about excess heat or grenading my trans, i have entertained the idea of an air pressure referenced turbo for +5k ft altitude. But i keep coming back to e'ery day heat & not wanting premium fuel. I think i could learn how to set a knob to control a 30-50hp shot of nitrous to let me hold rpm in a high altitude climb. One thing i'd like to play with on a desktop dyno (or convince richard holdener) to play with would be rocker arms to convert this engine to a 16 valve setup. Find the right cam specs to move peak torque down to 2krpm or so. I figure with the tiny valves & induced swirl, i could trick it into building cylinder pressure early. I'm not here to rain on your parade, in fact, i'll be the first guy to cobble up a dry ice bath for the charge pipe, and tell you it needs more boost, but as a thought expieriment, the best way to haul weight is to gear it so this little engine can rev.
    455h0le_dachshund likes this.
  2. Aug 7, 2024 at 9:34 AM
    VR6T
    VR6T [OP] In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
    See in your case I'd say just bolt on a super and be happy Casey. Me and you are wanting similar yet different things.. a super will be best for your wants.
  3. Aug 7, 2024 at 9:39 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Heat. I know the trd super is a heaton & i dont know how to cook up methanol to cool things down. I'd bet the a340 is good to 350hp, the 8.4 axle to 450hp (unless you're rock crawling). I just want all 250hp from sea level to 14k ft.
  4. Aug 7, 2024 at 9:44 AM
    VR6T
    Just add in a medium dual core FMIC and a water meth injection system, it'll cool your ITs down
  5. Aug 7, 2024 at 9:46 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    that shits expensive.
    Hutcheson, BroHon and bmf4069 like this.
  6. Aug 7, 2024 at 9:47 AM
    VR6T
    You can literally use window washer fluid.....
  7. Aug 7, 2024 at 9:48 AM
    VR6T
    And it's not really not that expensive, and I'm fucking poor, you know this to be a fact
    bmf4069 and 455h0le_dachshund like this.
  8. Aug 7, 2024 at 9:55 AM
    455h0le_dachshund
    455h0le_dachshund Tesler Thought Experiment
    Reverend Hotdog
    TX...big surprise
    Electric supercharger tied into your altimeter?
    VR6T[OP] likes this.
  9. Aug 7, 2024 at 9:57 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Bullet supercharger has water to air intercooler. I'm seriously considering it next for the race truck.
    Can't have Frank being faster than me.... :p
  10. Aug 7, 2024 at 9:59 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I've heard of people buying the cheap stuff in bulk at Walmart for exactly this
  11. Aug 7, 2024 at 10:00 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    $15/gallon is expensive. Thats damn near beer money.
    bmf4069 likes this.
  12. Aug 7, 2024 at 10:04 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  13. Aug 7, 2024 at 10:25 AM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    Mr.bee[QUOTED] likes this.
  14. Aug 7, 2024 at 11:00 AM
    VR6T
    Look if I wanted to be fast I would have kept a 3.xxx gear ratio lol. I'm fine with being torquey and slowish lol
  15. Aug 7, 2024 at 11:02 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Me too, I still can't let you beat me (off the line or across the line) or I can't keep calling it the racetruck. :D
  16. Aug 7, 2024 at 11:05 AM
    VR6T
    As long as it's has the methonal evap mixture and not the glycol mix then you can. Have to read that label. Seen a kid at a car show grenade his engine during a burn out comp because he had to fill his water meth tank, went and got some cheap washer fluid, didn't read the label and then gunk seized his cams, which in turn nuked a piston into a valve lol. Nothing was really missed as a loss cause MKv golf 2.0 FSI
  17. Aug 7, 2024 at 11:08 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I've also heard a little (very little) concern from some people about the blue dye.
  18. Aug 7, 2024 at 11:10 AM
    VR6T
    Meh it's a 2 camp argument, those who don't care and those who think it'll ruin their engine. There is no real evidence to prove it'll ruin the engine. I mean those are also the same people that will exclusively buy the $14 a gallon snow red dyed water methanol solution. Methanol is clear water is clear so there's red dye apparently the red dye won't ruin the engine but yet blue dye will. It's a really dumb argument
  19. Aug 7, 2024 at 11:15 AM
    #49
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    I didnt really have anything to say, to someone whos gotten so angry after the post i made, which was pretty straight forward:
    I can assure you, i wont learn anything from you, and i wasnt shit posting but if a mod decided to give me a 30 day vacay, it wont be the first. If you wanna cry wolf and call the mods in on me, please give them my number.
    Man, you sure got mad real quick... Roid rage? Female problems? You just need someone to chat with to help cool you down? Whats really goin on buddy lets try to get to the bottom of this.
  20. Aug 7, 2024 at 11:20 AM
    #50
    VR6T
    Yeah you're not gonna last long here.
    I'm not mad, you're a know nothing in the internet. The fact that you think that highly of yourself that you can get somebody angry over the internet, how egocentric self-centered are you.
    My opinion is based on fact, so that would be knowledge not an opinion. And you refusing to learn says all we need to know about you.
    Go back to your little Tacoma Jeep shit posting threads. If you can't contribute to someone's knowledge gain you're a detriment to not just yourself but in the entire community
  21. Aug 7, 2024 at 11:27 AM
    #51
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
  22. Aug 7, 2024 at 11:35 AM
    #52
    VR6T
    So back to the original point here, anyone know what transmissions are compatible with the 2uz? Aside from other 2UZ transmissions. I would like to upgrade to a 6 speed of some sort, if possible.
  23. Aug 7, 2024 at 11:38 AM
    #53
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    @empty_lord used to talk about wanting to mate the 6 speed from a 3uz to his truck.
  24. Aug 7, 2024 at 11:40 AM
    #54
    VR6T
    That man is as elusive as a jackalope in the wild. I would love to have a sit down with that guy and pick his brain, through @shifty` in that table top as well.
  25. Aug 7, 2024 at 11:43 AM
    #55
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    He stays busy with his fleet of used and wrecked Toyotas that he's constantly restoring. Oh and racing his 1GR swapped MR2. Maybe he'll see my tag. Or maybe you should add me to your IG and maybe I'll invite you to the place you can chat with him. :wink:
  26. Aug 7, 2024 at 11:48 AM
    #56
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  27. Aug 7, 2024 at 12:03 PM
    #57
  28. Aug 7, 2024 at 12:39 PM
    #58
    FishNinja
    Lee
    06DC2wd
    CD009 outta a 350z. I text you the info. They also make 2uz to cd009 adapter plates. Lots of people use cd009's in other high HP engine swaps. Honestly might be a little over kill. But that means it should be bullet proof for what you're expecting it to do.
    soooo there's your 6 spd issue solved
    VR6T[QUOTED][OP] and bmf4069 like this.
  29. Aug 7, 2024 at 2:35 PM
    #59
    VR6T
    You in fact did. And I appreciates you for it
  30. Aug 7, 2024 at 2:53 PM
    #60
    Riverdale21
    OTP ATL
    To be fair, that is what this forum is all aboot.
    VR6T[QUOTED][OP] and KNABORES like this.
