5100 Bilstein Setting
Discussion in 'Suspension' started by swageit, Jul 9, 2018.
  1. Nov 18, 2018 at 4:04 AM
    #61
    MikeyMTBs
    MikeyMTBs New Member
    After a few days and a 500 mile road trip on the 5100’s, top setting. Here’s what I know.
    -the truck aligned fine with stock UCAs. Drives straight as an arrow and KO2s are smooth on the highway at 75-80mph.
    -the front end has settled already and is level on passenger side but driver side is lower due to the lean.
    -ride: much former than the stock TRd yellow Billy’s. Not bad, just firm. MPG dropped about 1-1.5mph on the highway with the taller front end. Got 15.9-16mpg at 75mph on the way home yesterday. That route typically yields 17-17.5mpg. I drive it a few times a month so am pretty entune with how the truck performs.
    -my trip is from Atlanta to the mtns of Brevard, NC, so lots of curvy and steep Mtn roads. The truck holds the road in the curves significantly better than stock. Noticeably so such that you can take curves way faster than a truck this big should be able to run.
    -stock Tundra brakes suck for Mtn road driving. They overheat and fade way too fast. My next investment will be slotted front rotors and better pads.
    Back to the ride... it’s firm. Firm enough that for ME, I think it will be worth opening back up the front end and dropping from the top setting to the middle. At the same time adding a @Coachbuilder1 shim, maybe two on driver’s side, and one passenger to fix the lean and give me some lift height between the first and second setting.
    My plan is to order up some shims and do this over the Holiday weekend. Will report back!
    PS, rear is stock height yellow Billy’s.
  2. Nov 18, 2018 at 6:03 AM
    #62
    Mikekoot
    Mikekoot New Member
    Canadia
    2018 MGM tundra sr5 DC /2014 SSM Toyota Tacoma sr5 DCLB
    So you went top front with stock rear? Is it nose high?
  3. Nov 18, 2018 at 6:27 AM
    #63
    Professional Hand Model
    Hand Protectors
    2002 Tundra SR5 TRD 4x4 on 285/75/r16. Billy 5100 installed back in July on all 4 corners. Front set at one (1) notch up from stock bottom. Did not do measurements so this is an approximate observation that the front rose 1/2” and (get this) the rear rose 1/2” also! I know this because my trailer hitch needs an additional crank higher to couple up.
    Anyway, the ride is definitely firm and sporty. Tows/hauls very nicely. Its a different truck. Overall very pleased.
    Side note that I reconnected the front sway bar and had new ball joints and lower control arms installed at the same time as shocks. New cam bolts with the high dollar front alignment has everything lined up nicely.
  4. Nov 18, 2018 at 8:01 AM
    #64
    MikeyMTBs
    Top setting in front, stock rears. Passenger side is level at 39-3/4”, driver’s side rear is 39-3/4” and front is 39-1/2” due to typical driver’s side lean.
  5. Nov 18, 2018 at 8:14 AM
    #65
    18Cement
    18Cement New Member
    Olympic Valley, CA
    2018 Cement Tundra Limited
    5100's on all fours Icon rear leaf Fuel Vector 20" Nitto Ridge Grapplers 305/55/R20 Leer Shell
    Yes, Fuel Vector 20's with +1 offset. Good eye
    OR18TRD[QUOTED] likes this.
  6. Nov 18, 2018 at 9:37 AM
    #66
    Mikekoot
    Mikekoot New Member
    Canadia
    That's awesome that you got dead level! With mine I had to go mid setting. It may have settled now. If I went top I would be nose high by 1/2 inch
    Rica25 likes this.
  7. Apr 14, 2019 at 6:12 PM
    #67
    skatebass1958
    skatebass1958 New Member
    Felix Javier
    2017 Tundra SR5 Xp
    Removed mudflaps
  8. Apr 15, 2019 at 12:05 PM
    #68
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Had 5100s installed today up front. Measurements to bottom of fender flare- PRE INSTALL- FRONT- passenger- 36.5", Driver- 36.25", POST INSTALL on MIDDLE SETTING- passenger- 38.25", Driver's- 38.0".
  9. Apr 15, 2019 at 12:20 PM
    #69
    skatebass1958
    Felix Javier
    2017 Tundra SR5 Xp
    Removed mudflaps
    Can you share pics please? Factory tires and wheels?
  10. Apr 17, 2019 at 12:22 PM
    #70
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    I'll try and remember to get some tonight.
    What's everyone paying to have the 5100s installed up front, with and without alignment?
    Celt likes this.
  11. May 3, 2019 at 3:29 PM
    #71
    Celt
    Celt New Member
    NY
    2019 Crewmax TRD/OR Cement
    Im curious about pics and pricing too.
    I have a 2019 cm trd or and am considering the 5100s for up front only. I dont want to be nose high and would be happy with about 1" of rake so from what ive read the middle setting will get me the closest.
    Rica25 likes this.
  12. Dec 16, 2020 at 4:49 PM
    #72
    Luis101
    Luis101 New Member
    Luis
    White tundra
    Lift 2"
    2017 tundra platinum 20" stock wheels
    275/60/20 nitto g2
    Bilstein 5100 middle ring setting at 1.57"
    Before/after
    Maybe not the best angles but this is my truck now
    rv740 likes this.
  13. Dec 23, 2020 at 10:20 AM
    #73
    co2owen
    co2owen New Member
    VA
    2020 Cement Limited CM TRD Off-Road
    Trans Cooler. 5100's up front at mid-setting. ESP Plastic Storage.
    Here are a couple additional photos of before and after 5100's. I chose the middle setting and have a slight rake. I didn't want to do anything to the rear and figured the top setting would put me a bit nose high so I went middle. Ride is very similar to stock in my opinion.
    Before:
    After:
  14. Feb 5, 2021 at 6:52 PM
    #74
    Florida Man 82
    Florida Man 82 New Member
    2021 TRD Off Road 4x4
    White size tires do you have in this pic?
  15. Feb 21, 2021 at 11:46 AM
    #75
    Florida Man 82
    Did you have any lean toward the driver's side? Before or after? Did you use a shim? Looks great.
