6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Apr 22, 2024 at 5:36 PM
    #2311
    AKMI
    AKMI New Member
    17 CM
    6112/5160, CB +2 shackles.
    I probably should have added that in the post. #3 clip (1.9")
  2. Apr 22, 2024 at 5:37 PM
    #2312
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Nice! I’m doing the same setup. Glad I will have that look. Thanks!
    memario1214 likes this.
  3. Apr 25, 2024 at 4:22 PM
    #2313
    Motopilot
    Motopilot New Member
    Josh
    NC/FL
    2017 Tundra crewmax 4x4 Platinum edition
    2” level 285/75R17 Falken wild peak RT 34.1”x11.5” bilstein 5100
    Has anyone got pics sitting on 285/70/r18? Been searching trying to see what it looks. Just got a 2017 crew cab in quicksand.
    Time to sell the 1st Gen!
  4. Apr 25, 2024 at 6:16 PM
    #2314
    Motopilot
    Josh
    NC/FL
    @AKMI I somehow looked rt past your post…that’s exactly what I was wanting to see. What clip did you run your 6112’s on?
    Since those tires (285/70/r16) are 10lbs. lighter a piece than the 295/70/16 that most seem to be running I was wondering if you noticed much difference from your stock setup? Acceleration, mpg?
  5. Apr 26, 2024 at 5:49 PM
    #2315
    AKMI
    AKMI New Member
    17 CM
    I'm running 285/70/18 on my truck. Clips at #3 (1.9"). So far I have used 3/4 of a tank. Getting 13.5 mpg. I can tell the gas pedal is little bit sluggish. But at the end of the day she's a truck not a race car. I don't mind it at all. If you want to hit it hard put her in tow mode. I will say the suspension is amazing.
    Motopilot[QUOTED] likes this.
  6. Apr 26, 2024 at 6:34 PM
    #2316
    therealjonwick
    JR
    2019 OR
    Tune it and the sluggish feel will be gone! I did KDMAX.
    SDiegoTT and AKMI[QUOTED] like this.
  7. Apr 27, 2024 at 3:44 AM
    #2317
    Motopilot
    Josh
    NC/FL
    @therealjonwick what all is entailed in the tune? I went on their site but just says they’ve been acquired by yotaworkz.
  8. Apr 27, 2024 at 4:44 AM
    #2318
    therealjonwick
    JR
    2019 OR
    Ah I didn’t know that. Must be a recent development. I started when I had my Tacoma. The tune revolutionized that engine. Doesn’t do as much for the tundra. Did improve throttle lag. Has 3 settings for throttle. It also beefs up the tow mode. Better mapping. Also is octane learning so you can run 87+ and it will work it out. Also opens up for more add-ons down the road. I’ll have to reach out to Dave on Tacoma world and see what’s up with the buyout.
  9. Apr 27, 2024 at 6:25 AM
    #2319
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    @memario1214 Any help appreciated! Also, these are thoughts in my head now on paper. :bananadead:
    I have 38k on my current set of tires and looking to upgrade in stages as I buy new rubber. I was thinking of adding the lift now and buying the wheels/tire setup when time comes due. Based on what I gathered from this thread below, am I on the right path?
    Needs: DD and I look to tow a TT (~5-6k lbs.) in the next year or so for family vacations, that info should be helpful. Also not looking to level, rake is ok because of future towing.
    Current:
    -Stock suspension
    -20" OE wheels :(
    -KO2 275/65/20. Larger(taller) than stock but too skinny for my liking so I was gearing toward 285 being a DD.
    Suspension kit desired:
    -Order now to pair with current wheels/tires (step 1 in a sense)
    -6112/5160, 1.9", assembled.
    https://hotshotoffroad.com/collecti...kits/products/6112-5160-lift-kit-07-21-tundra
    -Coachbuilder Strut (x1) .50" of lift to FL tire.
    https://shop-coachbuilder.myshopify...ilder-strut-coilover-shim-provides-50-of-lift
    -Coachbuilder +2 Shackle. is this needed? (some rake is ok, towing in the future)
    https://shop-coachbuilder.myshopify...ilder-2-shackles-provides-1-25-of-actual-lift
    -Edit: or do I consider the RAS system (or both), @RobertD had the suggestion.
    Wheel/Tire desired:
    -Order when KO2 rubber is worn out (step 2)
    -SCS Ray 10 18x9 +25mm 5x150
    https://www.stealthcustomseries.com/collections/toyota/products/ray10?variant=26571894083
    -Wildpeak A/T4W, size is where I am stuck. Not looking to do any modifications, have an RCI Skid (no rub) there.
    -Considering: 285/75/18 or 295/70/18, due to E rating (towing). I wish the 285/70/18 was E rated, I would likely go with that.
  10. Apr 27, 2024 at 6:53 AM
    #2320
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    I see you! I’m travelling today so can’t punch up a full reply - my passenger is typing for me lol. You can call me if you’d like (406-936-0206) or if I don’t post by tonight ping me again!
    OHwendTrd[QUOTED] and RobertD like this.
  11. Apr 27, 2024 at 6:59 AM
    #2321
    RobertD
    Robert
    DFW, Texas
    How heavy is the TT? If you aren't off roading a lot, you might be fine with 5100 in the rear. Have you considered adding the RAS to the rear as well?
    OHwendTrd[QUOTED] likes this.
  12. Apr 27, 2024 at 7:30 AM
    #2322
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Thanks for the quick reply and very patient, so feel free to message when you can and enjoy your trip!
    I was considering that being an option as well, almost included it in my post. I would venture to say no more than ~5-6k lbs., maybe lighter depending on brand/need, haven't done a great deal of research yet but nothing over the top.
    RobertD[QUOTED] likes this.
  13. Apr 27, 2024 at 11:26 AM
    #2323
    therealjonwick
    JR
    2019 OR
    Will most likely have to modify with both those tire sizes. Maybe less with adjustable control arms. Remove mud-flaps, some trimming. If you want to do minimal modifications go 285/70/18. But 295 do look perfect. Some have had to do BMC.
  14. Apr 27, 2024 at 1:35 PM
    #2324
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Maybe plausible with the +25 wheel? However, I am completely open to suggestions with what I'm looking to achieve (which is nothing crazy).
    BMC, neverrary.
    Edit: unless guided differently, probably what I'll end up with based on what I've been reading: 295/70/18.
  15. Apr 27, 2024 at 5:56 PM
    #2325
    memario1214
    Colton
    Missoula, MT
    Alright here we go. Not as much for me to have to chatter through though as I look at it in depth!
    Purchasing the suspension before the rubber is likely the correct order of events, and the most typical. That said, at a fundamental level a lift will not make fitting a tire any easier. Sure, when in a straight line or when the suspension is not flexed a lift can allow for more clearance. However, when compressed, that pesky tire is the same size when it's tucked up in that wheel well. The LCA and it's interaction with the body is unchanged with a coilover setup.
    As far as the rear lift goes you'll just have to be realistic with your use. If you are only towing a handful of times per year, and pretty much all of the rest of the time you are empty or lightly loaded then a CB shackle will do you just fine. Sure, you don't get any additional support when you're towing, but you'll be able to enjoy the articulation benefits that come with a free moving leaf pack. If you do plan to tow/haul a decent amount of times then we're big fans of the RAS kit. When installed, it'll give you .75-1" of additional ride height. When you are unloaded you'll largely not know it is there, and when you do tow then the kit kicks into gear and supports your leaf pack directly. The downside to these kits is that they do act as a bit of a limit strap in that you'll lose a little bit of your maximum downtravel in the rear. Is that the end of the world? For primarily a pavement pounder I don't see that as a problem, but we all have our desired outcomes in terms of utility vs performance.
    As for tire size, I can tell you this - I personally have a 295/70/18 on a +25 wheel. I love the look, and think it's about perfect for the Tundy. That said, I can confidently say that in order for me to achieve full articulation and no contact in all scenarios both forward and reverse I had to cut back the cab mount. Your only potential workaround would be to purchase a UCA that has adjustment at the UCA itself (think SPC, Icon billet, etc). That way your alignment tech could push your cams as far forward as possible to clear that area, and then the alignment would be dialed in at the UCA. I can't confirm even this is the way, but you'd need to do SOMETHING there. My $.02 is to cut back that cab mount so that you can clear your new meats and be able to tell everyone how badass you are because you cut the frame on your 2021 truck! :devil: Seriously though do what you want.
    Regardless of the path you go we can help out. We also have coachbuilder stuff on the shelf. It's on my list of things to add to the site this week!
  16. May 6, 2024 at 11:07 AM
    #2326
    spectrasoul
    spectrasoul New Member
    Scrolled thru the whole thread but could find info if i need diff drop for 6112 top setting (with 0.5 shim driver side) and 5160 rear
  17. May 6, 2024 at 11:07 AM
    #2327
    memario1214
    Colton
    Missoula, MT
    Nope!
    spectrasoul[QUOTED] likes this.
  18. May 6, 2024 at 11:14 AM
    #2328
    spectrasoul
    thanks for quick reply. i've read yesterday on FB that some ppl experience driveshaft vibration on higher speed after more than 2.5-3 onch lift
  19. May 6, 2024 at 11:15 AM
    #2329
    memario1214
    Colton
    Missoula, MT
    The vibration is most likely coming from the carrier bearing. A CB drop is an easy and quick fix for that.
  20. May 15, 2024 at 7:17 PM
    #2330
    Jram58
    Jram58 New Member
    Jon
    2016 tundra
    Bilstein 6112s front & 5100s rear Spc UCAs
    2016 with some new muscles.
    6112’s at top clip, SPC UCA’s. 5100’s and just a fab tech 1” block in rear. Hoping to upgrade to shackles or maybe even a leaf kit in. Future. Currently sitting on some Toyo R/T 285/65s that have run the test of time lol upgrading soon. Love the stock look
    silverstreak16 likes this.
  21. May 15, 2024 at 9:34 PM
    #2331
    ThiRdChoice
    ThiRdChoice New Member
    Tommy
    Hi Everyone, I’m in need of help! I finally purchased the 6112s + 5100 after researching for a year (also just saving up). Going to be installing them this weekend!
    The 6112s are set at 2.5” (4th clip) and the 5100s are stock height. Also purchased .25” shim for front driver side to accommodate the lean. I need help determining the largest tires that will fit without any rubbing/body mount chop. I purchased SSW Dakars (17x9.0 +0 offset) and don’t know exact tire dimensions that will work. After looking through the 70+ pages, I’m pretty sure 34s will work but a lot of the wheels were 18s and have diff dimensions than the 17s I’ll be getting. Any help determining the largest tire size without any problems will be appreciated!
  22. May 15, 2024 at 9:58 PM
    #2332
    RobertD
    Robert
    DFW, Texas
    Another place to look.
    https://www.tundras.com/threads/largest-tire-you-can-run-stock-for-all-generations.9762/
  23. May 16, 2024 at 3:13 PM
    #2333
    therealjonwick
    JR
    2019 OR
    Couple weeks away from getting my lift installed. Shout out to @memario1214 at hotshot for hooking me up and answering my millions of questions. Currently doing 6112’s at 3rd clip (1.9) with 2 driver shims and 1 passenger. Zone off-road UCA and CB+3 rear shackles. Question for the thread: anyone regret not going to the top clip 2.5 who did 1.9? Or vice versa. Cannot decide which one to go with. I know it’s only a 0.5” in difference. Probably doesn’t matter much. But wanted to see what folks thought.
  24. May 16, 2024 at 4:14 PM
    #2334
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    The whole point of 1.9 is for alignment without UCA…
  25. May 16, 2024 at 11:56 PM
    #2335
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    On my "old" '20 Tundra, I had Bilstein 6112 on the 2.5" clip, two CB shims driver side, one passenger side, Bilstein UCA. I was topping out a lot. Like, A LOT. Off-roading, of course. In the street it was fine. I'd keep it at 1.9", and maybe you won't have the same issue.
  26. May 19, 2024 at 7:55 PM
    #2336
    Jram58
    Jram58 New Member
    Jon
    2016 tundra
    Some new 275/70 Toyo R/Ts and some dirt this weekend. Loving the suspension set up so far
    RobertD and BillyB like this.
  27. May 22, 2024 at 6:26 AM
    #2337
    Krisgo316
    Krisgo316 New Member
    Kris
    Western NC
    2015 MGM Tundra TRD
    I have a 2015 Tundra Crewmax 4x4. I don’t go off-road but I haul the occasional lumber, oil barrels, trailer, etc. I currently have a spacer in the front and blocks in the back. The UCA’s are stock. What setting of the 6112’s should I go with to keep my current stance in the truck.
  28. May 22, 2024 at 6:36 AM
    #2338
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    depends how much your spacer is giving you
  29. May 22, 2024 at 6:37 AM
    #2339
    Krisgo316
    Kris
    Western NC
    2015 MGM Tundra TRD
    I think it is 2.5 in the front and 2 in the back
  30. May 22, 2024 at 6:51 AM
    #2340
    b6graham
    b6graham New Member
    probably recommend #3 at 1.9" in the front with 2/1 CB spacers. a lot of people have reported a better ride there versus at #4/2.5"
    what are you plans for the rear?
