Advice on leaf spring upgrade for towing and a permanent heavy-ish load?
Discussion in 'Towing & Hauling' started by unsub1, Oct 10, 2021.
  1. Oct 29, 2021 at 8:04 AM
    :eek::eek::eek:
    Went all out! Looks like a great setup you built. :thumbsup:
    2mchfun[QUOTED] likes this.
  2. Feb 21, 2022 at 2:08 PM
    unsub1
    unsub1 [OP] New Member
    Steven
    2020 MGM Tundra 4x4 SR5 TRD Off-Road Package, Convenience Package,
    Victory 4x4 sliders, RSI SmartCap, ICI Alumilite front bumper, TRD Pro wheels, Nitto RidgeGrapplers, FrontRunner rack, National Luna DC25 dual battery, X2Power AGM main battery, Cascadia 4x4 hood-mount solar panel, NOCO X2 Pro charger
    Yeah it’s just a 7 gallon Yakima Roadshower. Pretty universal clamps.
    JIN[QUOTED] likes this.
  3. Feb 28, 2022 at 9:09 PM
    Dansly56
    Dansly56 New Member
    daniel
    does the RAS eliminate squat? Would I still be able to run a WDH with the RAS? I have Timbrens, TRD sway bar, WDH and a tekonsha brake controller but still squats more than I like.
  4. Mar 1, 2022 at 12:32 AM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    Squat with a weight distribution hitch? Id check out your leaf packs if they are not flat. You can have the RAS with all the other components and it will improve your squatting and ride comfort. It will lift you around 1-1.5" in the back empty.
  5. Mar 1, 2022 at 5:44 AM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (current)
    Why the RAS if you already have such a beefy spring pack? Isn't the RAS just another spring ?
    I find it odd that the RAS only hangs on to the back half of the leaf. Is it possible that making half of the leaf more rigid allows the axle to torque on the front half of the leafs by making the axle a pivot point? I guess this would be axle wrap...
    Has anyone experienced any negative affects from running RAS?
  6. Mar 1, 2022 at 5:52 AM
    2mchfun
    At times I haul heavy loads and don't care to destroy $1000 leaf packs. Plus I like the truck to appear empty even when loaded. Also I have BDS recoil traction bars. So, all in all, this truck don't really ever sag or suffer from axle wrap regardless of how much load it is towing or hauling. Not your average Tundra or average owner.
    Retroboy1989[QUOTED] likes this.
  7. Mar 1, 2022 at 6:21 AM
    Mobeyk
    Mobeyk New Member
    Mechanical forces are absorbed differently. Leaf springs are great absorbing downward force but poor in taking anything horizontal, same to certain extent with shocks. RAS kicks in in that category plus aiding in taking some downward forces off. Axle wrap is horizontal force which RAS greatly reduces. Driving forward, accelerating requires the spring to be at back part of the axle and you have ideal attachment point there. The pressure on the spring allows for a non fixed attachment points.
  8. Mar 1, 2022 at 8:14 AM
    Dansly56
    Dansly56 New Member
    daniel
    See the squat with the Timbrens on? Granted my front had a coilover lift to 2.5” and the WDH is set up
  9. Mar 1, 2022 at 8:50 AM
    FlightMedicRN
    FlightMedicRN New Member
    2020 Super White Crew Max- TSS SR5
    Interior chrome delete- AJT Designs, S&B Cold air intake, 10" BAMuffler exhaust system, color-keyed bumper covers, LED fog lights, TuffSkins interior inserts, black exhaust tail pipe and tip, Peragon tonneau cover.
    I have the RAS HD kit on my 2020 CM Tundra for towing our 27' TT with a WDH. My Tundra does not have a lift and is not 4x4. The RAS made a significant improvement with towing after having only Sumo Springs installed. Squat is pretty much gone along w/ improved handling characteristics (sway, porpoising, etc....).
    Mobeyk and Dansly56[QUOTED] like this.
  10. Mar 1, 2022 at 8:52 AM
    Dansly56
    Dansly56 New Member
    daniel
    Are you running the sumo with RAS and WDH?
  11. Mar 1, 2022 at 8:54 AM
    Mobeyk
    Mobeyk New Member
    Ya, this is more looking like a squat cause your are lifted up front. RAS will get the back 1-1.5“ higher. Im not as much familiar with blocks etc for lifting the back, so maybe someone else can recommend more.
    Dansly56[QUOTED] likes this.
  12. Mar 1, 2022 at 8:54 AM
    FlightMedicRN
    Yes, I just edited my last post to include that info. and a picture....
  13. Mar 1, 2022 at 8:56 AM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    OP, can I get some more deatails on your bike slide?
  14. Mar 1, 2022 at 8:56 AM
    FlightMedicRN
    Agreed, to my knowledge it is very difficult to eliminate squat on a truck with a lift and/ or a set up for off-roading....
    Mobeyk[QUOTED] likes this.
