AFTERMARKET GRILLE ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2010bigdog, Mar 8, 2020.
  1. Jan 8, 2022 at 3:40 PM
    What grill did you end up getting?
  2. Dec 31, 2022 at 6:39 AM
    RobertD
    Robert
    DFW, Texas
    Dude!!! Stop posting the same question on every thread. Wait for a response!
    Cpl_Punishment and GODZILLA like this.
  3. Dec 31, 2022 at 6:45 AM
    CAC
    CAC New Member
    Cac.
    Fl
    2020 toyota tundra
    Really because I see so many different ones so mind your business if you're not gonna help have a nice day
  4. Dec 31, 2022 at 6:48 AM
    Cthulhu
    :rofl:this zombie thread gonna come to life real quick...
  5. Dec 31, 2022 at 6:48 AM
    GODZILLA Introverted Troglodyte
    Spamming is against the rules of the forum. Your posts will just get deleted, and you might even catch a ban for it.
    Cpl_Punishment likes this.
  6. Dec 31, 2022 at 6:48 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    :duh:
  7. Dec 31, 2022 at 6:49 AM
    CAC
    CAC New Member
    Cac.
    Fl
    2020 toyota tundra
    I do not care About gettin band I see different trends that's why I did what I did
  8. Dec 31, 2022 at 6:49 AM
    Squatting Pigeon
    Holden
    North Texas
    You really need to chill, man.
    Just ask the question in one spot and if someone has the info they’ll offer it to you.
  9. Dec 31, 2022 at 6:49 AM
    :crazy:
    :wave:
  10. Dec 31, 2022 at 6:51 AM
    CAC
    CAC New Member
    Cac.
    Fl
    2020 toyota tundra
    Well this is my 1st time on here so I didn't realize you could put it on one and it'll go to a bunch Of different ones
  11. Dec 31, 2022 at 6:53 AM
    RobertD
    Robert
    DFW, Texas
    Ironically was I making a response to your initial post and was doing a fact check when I saw you posting in multiple places. I then had to check each post to see if you provided more info.
    I think you are asking if your oval TSS cover will fit your Pro grille insert? No it will not. The Pro grille requires a rectangle cover below the TOYOTA. But the sensor that is inside the grille should fit your new Pro insert. Hope that helps
  12. Dec 31, 2022 at 7:02 AM
    CAC
    CAC New Member
    Cac.
    Fl
    2020 toyota tundra
    I apologize for not explaining myself right this is all new to me on here I have an aftermarket pro grill with a cheap eBay sst cover But I was wondering if I take the cheap one out can I put an oem in It's replacement And will it fit Like the cheap one did
    Thank you
  13. Dec 31, 2022 at 7:05 AM
    RobertD
    Robert
    DFW, Texas
    If you have a Pro grille, both the affordable ebay/knock off rectangle garnish and the expensive OEM garnish should fit it the same.
  14. Dec 31, 2022 at 7:06 AM
    Do you have pics of the Aftermarket Grille? There are so many that there may be variations in the sensor cover area, so it may work on some and not on others. If we can see the grille you are using, and specifically the sensor cover portion, somebody might be able to give a more accurate answer. As it stands it'd be a guess at best.
  15. Dec 31, 2022 at 7:07 AM
    CAC
    CAC New Member
    Cac.
    Fl
    2020 toyota tundra
    Awesome that's The answer I was looking for before I dropped 300 on a sensor thank you so much appreciate your time
  16. Dec 31, 2022 at 7:12 AM
    CAC
    CAC New Member
    Cac.
    Fl
    2020 toyota tundra
    GODZILLA likes this.
  17. Dec 31, 2022 at 7:23 AM
    Shape looks correct, and about the right size. The only way I see you having an issue would be if the aftermarket grille has the mounting points in a different spot, but I highly doubt that. I think you'll probably be good to go.
    Cpl_Punishment and CAC[QUOTED] like this.
  18. Dec 31, 2022 at 7:32 AM
    CAC
    CAC New Member
    Cac.
    Fl
    2020 toyota tundra
    Thank you GODZILLA I HAD outside bulge and Surrounded Peace painted But when it was all done I did not like the stock grill so I got the Aftermarket insert the 1st SST sensor worked But the glass fell out I got a second one and it did not work I Put In the one that worked without Glass Back in for now so I'm gonna go to oem appreciate your time and your help
  19. Dec 31, 2022 at 7:41 AM
    #49
    Good luck with the sensor garnish! :thumbsup:
    CAC[QUOTED] likes this.
  20. Dec 31, 2022 at 8:30 AM
    #50
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Zoltan, Bammer, CAC and 2 others like this.
  21. Dec 31, 2022 at 2:52 PM
    #51
    greg8765
    greg8765 New Member
    Greg
    Utah
    2021 Cement Tundra
    DB doesn't cut anything with letters on it anymore due to a cease and desist from Toyota. All they have now are just blank grilles. They still look good though
    the red and texasrho83 like this.
  22. Dec 31, 2022 at 3:52 PM
    #52
    TommyTundra
    TommyTundra Oh God the anger’s changing me
    Long Island NY
    2019 PRO
    Hey CAC. Im a little confused. Are you looking for the mounting bracket that goes on a PRO grille??? If thats it I just cut the honeycomb insert out of my PRO grille to replace it with a Royalty Core. Im re using the sensor itself and just relocating it. The old grille is sitting outside waiting to go to the curb next week. If you want it its yours. Hope this helps
  23. Dec 31, 2022 at 3:57 PM
    #53
    TommyTundra
    Long Island NY
    2019 PRO
    CAC likes this.
  24. Dec 31, 2022 at 4:14 PM
    #54
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    I saw they discontinued them. Guess I lucked out! Still rocking it.
    the red and RobertD like this.
  25. Jan 1, 2023 at 6:57 AM
    #55
    CAC
    CAC New Member
    Cac.
    Fl
    2020 toyota tundra
    Thank You Tommy Iwant to know if the OEM sensor cover will fit in after market pro grill which I Which I think it well I had the cheap sense of covers but 2 didn't work one lost the glass face
  26. Jan 1, 2023 at 8:46 AM
    #56
    TommyTundra
    Long Island NY
    2019 PRO
    I will strip mine down and send it to you if you want. Pm me.
