Agm battery charging..
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mrf1987, Nov 2, 2021.
  1. Jun 18, 2022 at 9:22 AM
    #91
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm using the stock bolt down bracket and my AGM is fine. Doesn't move an inch.
    Wallygator and NewImprovedRon like this.
  2. Jun 18, 2022 at 9:32 AM
    #92
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I may have to go with dobinson instead of ARB since I have bushwacker flares and they may not fit without cutting the flare which I won't do....
  3. Jun 18, 2022 at 4:10 PM
    #93
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    Does group 31 'sit' beyond a group 27F tray, that's most of my worry. I mean, extra $200 in bracket is a little rich.
  4. Jun 18, 2022 at 4:14 PM
    #94
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This'll help:
    NewImprovedRon likes this.
  5. Jun 18, 2022 at 4:59 PM
    #95
    Ghost Rider
    Ian
    Cypress, Texas
    One inch longer.... Thanks.
  6. Jun 18, 2022 at 5:06 PM
    #96
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    What she said
  7. Jun 22, 2022 at 8:56 AM
    #97
    dkrou
    dkrou New Member
    dan
    2019 tundra
  8. Jun 22, 2022 at 9:21 AM
    #98
    daveeasa
    David
    MK3 is mini, mk2 is micro. Mini is needed for FGT but micro is stealthier for 2G Tacoma. MK3 is cheaper, likely because it’s easier to build with the extra space?
  9. Aug 27, 2022 at 8:59 AM
    #99
    Yzed608
    Yzed608 New Member
    Wisconsin
    Do you have issues with the mini fuse fitting correctly in the fuse box? Mine from day 1 (post #70) has been really loose, and have to keep tape over it from coming out. Looking at it compared to a regular fuse I don't really see why it isn't snug, the spades look to be the same width. Was thinking of just ordering another to see if it fits tighter. I can't find any other product that is the same with the 2 wires other than this one though unfortunately.
  10. Sep 3, 2022 at 8:28 AM
    #100
    Yzed608
    Yzed608 New Member
    Wisconsin
    Update, after looking at the reviews on Amazon again after remembering someone said it didn't work on their RAM, it makes sense. The plug is too wide to seat down all the way, filed the edges and fits nice and snug now. No more trying to hold it in with duct tape... Here's a before and after comparing it to a regular fuse.
    NewImprovedRon, F0X672 and AGSport like this.
  11. Sep 4, 2022 at 9:54 AM
    #101
    F0X672
    F0X672 New Member
    NEPA
    2016 Tundra TRD Pro
    If I remember correctly, I had to shave some of the fuse adapter body width with a file so it would fully engage into the fuse box. Il have to look. It initially fit like crap and needed some work to fit in there.
  12. Sep 4, 2022 at 10:35 AM
    #102
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  13. Sep 4, 2022 at 2:24 PM
    #103
    F0X672
    F0X672 New Member
    NEPA
    2016 Tundra TRD Pro
    Wallygator and 1lowlife[QUOTED] like this.
  14. Oct 8, 2022 at 8:53 PM
    #104
    AZTundra
    Paul
    Phoenix, AZ
    Been running the X2 battery for maybe just over a year now along with the HKB diode. Went to grab lunch and truck wouldn't start. Battery was low and showing 81% on my charger. I charged it up and it seems to be okay now. Do we still need to use the charger once in a while to top off the agm batteries? I was under the impression using the diode would eliminate the need for maintenance charging, but maybe I'm wrong.
    texasrho83 and reywcms like this.
  15. Oct 8, 2022 at 9:11 PM
    #105
    AZTundra
    Paul
    Phoenix, AZ
    Thanks that's what I thought. I went to batteries plus and they said the battery was low and they needed it charged fully before they could test. I'll take it back in the morning and get it tested now that I charged it up at home.
  16. Oct 8, 2022 at 9:12 PM
    #106
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You ain't wrong.
    I have noticed the HKB isn't really pushing the charging voltage as high as advertised. According to my OBD app-based plug-in thingamjigger, I was only seeing about 13.4v. The ammeter in the dash never touched 14. I knew at that point I'd have to slap the trickle charger over night once a month.
    I've reached out to HKB and was asked about what my truck was charging before the diode but have yet to hear anything back post response.
  17. Oct 8, 2022 at 9:19 PM
    #107
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I see you are in Phoenix (I am too for now), the heat takes a toll on batteries. I wonder if the Toyota charging circuit has any temperature compensation? My Battery Minder does.
    AZTundra likes this.
  18. Oct 8, 2022 at 9:57 PM
    #108
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Would the AGMs sold by Costco benefit from the diode upgrade? Would I need to trickle charge them ever?Screenshot_20221008-221546_Chrome.jpg
  19. Oct 9, 2022 at 4:57 AM
    #109
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If it's AGM, yes.
  20. Oct 9, 2022 at 9:03 AM
    #110
    DanTundra
    DanTundra Danny
    Wilmington, NC
    2015 Ribbon Blue Tundra SR5 4x4
    TRD sway bar, airbag kit, Diamondback HD, LED headlights, Pedal Commander, Bilsteins 6112's up front with shims (2.5 inch lift), 5160s in the rear with CB +2 shackles (1.5 inch lift), Falken Wildpeak AT3W 285/75/18, TRD Pro Grill insert, MattGecko under hood and bed light kit,
    You may want to check the HKB isn't installed backwards. I have a 2015 and installed the diode about 2-3 months ago. My ScanGauge II reads 14.7V on start up then will adjust. I'm usually at 14.3-14.5 on the drive to work every morning and below 14 on my drive home from work. Before the diode I was at 14.1V or below reading on the ScanGauge II.
    des2mtn and FrenchToasty like this.
  21. Oct 9, 2022 at 9:36 AM
    #111
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah I installed it backwards when I first got it and the battery light came on. Flipped it around so I know it's right.
  22. Oct 9, 2022 at 9:42 AM
    #112
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    That's a bummer. I know that the HKB guy was away for a bit, but hopefully they get back to you. I've never seen my voltage that low since installing the HKB.
    FrenchToasty likes this.
  23. Oct 9, 2022 at 9:43 AM
    #113
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm gonna pull it and go the diode route.
    FrenchToasty and des2mtn[QUOTED] like this.
  24. Oct 9, 2022 at 10:53 AM
    #114
    1lowlife
    DADA
    2014 MGM DC SR5
    That was my experience.
    I had an X2 with the HKB and ended up with a dead battery twice in 6 months.
    I no longer have an AGM..
  25. Oct 9, 2022 at 10:56 AM
    #115
    1lowlife
    DADA
    2014 MGM DC SR5
    That HKB was upping my voltage to 14.5, using a digital voltmeter in the dash.
    It ran 13.1 to 13.5 or so without it.
  26. Oct 9, 2022 at 11:14 AM
    #116
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Guess I got a lemon
  27. Oct 9, 2022 at 11:18 AM
    #117
    1lowlife
    DADA
    2014 MGM DC SR5
    Just like my X2...:eek2:
  28. Oct 9, 2022 at 11:20 AM
    #118
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Still have the HKB?
  29. Oct 9, 2022 at 11:23 AM
    #119
    1lowlife
    DADA
    2014 MGM DC SR5
    It sat in my desk for awhile, but I sold it a few months ago..
  30. Oct 9, 2022 at 11:24 AM
    #120
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Dammit man
