Amazon Plasma Cutters....anyone?
Discussion in 'Electrical' started by Cruzer, Jun 2, 2023.
  1. Jun 3, 2023 at 10:58 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Most of us can't afford a Hypertherm for intermittent home shop use, and paying 10-20$ for a set of consummables... no thx. Almost all these machines are made in the same dozen factories in China with stolen IP to begin with and plasma cutters aren't actually all that complicated. At the price theyre selling them for you can totally get your moneys worth as long as you dont lose the Chinesium QC lottery which admittedly is always a factor.
    Aerindel, chugs and Mater like this.
  2. Jun 4, 2023 at 7:56 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    You started looking at compressors yet? Their listing says 45L/min which I don’t think is all that much. Who knows though :notsure:
  3. Jun 4, 2023 at 8:29 PM
    Gravy
    Yucaipa, California
    As long as you have a decent amount of air storage capacity you should be good, rarely have I needed to use a cutter for anything more than short bursts and the wait in between pump ups gives the cutter a chance to cool. Now if your trying to run a cnc plasma table... definitely get a high-flow compressor and some air dryers.
    2mchfun and Mater[QUOTED] like this.
  4. Jun 4, 2023 at 10:17 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    I got an Amico CUT-40 for $200 on Amazon. Been going strong for 4 years. If the bestarc is pilot arc instead of HF start, that's a better setup.
    If you a have 220v outlet, they cut way better on the higher voltage. May be important of you're doing something like cutting a tundra frame in half. :sawzall:
    Cruzer[OP] and Mater like this.
  5. Jun 5, 2023 at 7:58 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I don't have a cutter yet, but I'm pretty happy with my MIG welder from Eastwood. Neighbor got Eastwood MIG, too, a bit beefier model, and he's happy with it, too. Price-wise it is in the same league with PrimeWeld. The units are made in China, however the company resides in US and it provides US-based support. Mechanically and electrically it has all the critical points done right. The price is higher than the cheapest ones on Amazon, but still way below Miller, Lincoln, etc.
  6. Jun 5, 2023 at 2:37 PM
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Pulled the trigger on this compressor.
    New compressors are hella expensive so I went on Craigslist. People are selling a shitload of compressors on CL for cheap so I'm going to get at most a 30 gallon that can push at least 5 CFM, which typically has a 3HP motor.
  7. Jun 5, 2023 at 2:48 PM
    Aerindel
    Aerindel New Member
    Montana
    My HF compressor is the weak link in my cutting set up. I'd go so far as to say its more important to have a good compressor, than a good cutter.
    NewImprovedRon likes this.
  8. Jun 5, 2023 at 2:48 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    That is the goal.
    helidave[QUOTED] likes this.
  9. Jun 5, 2023 at 2:53 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    I'm trying to get this one. 5.1 CFM @ 90psi
    helidave and Mater like this.
  10. Jun 5, 2023 at 2:57 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Damn. Where do you have space to store all this stuff..
  11. Jun 5, 2023 at 2:59 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    I don't :rofl:
    When not in use this will have to go in the backyard and be covered or something.
    Mater[QUOTED] and Aerindel like this.
  12. Jun 5, 2023 at 4:38 PM
    Gravy
    Yucaipa, California
    Home Depot has one with a lil less capacity and flow but claims to be 80% quieter for 100$ more. If you like using air tools (like me), it's worth a thought, oil-less compressors are LOUD AF.
    For those of you looking for welding equipment above hobbyist grade, I personally recommend Everlast. It's high-grade Chinesium from an American company with stateside support. They have excellent customer service, excellent warranties and from my experience their equipment is medium to high grade shop duty depending on how much you want to spend. I ran a small welding repair shop for years and I've run the usuals... Miller, Lincoln, Esab and Hobart. All good/excellent in their own right, but they all also think their shit don't stink when it comes to prices. If you've got the budget, buy the domestic tried and true but if you need best bang for your buck I run Everlast for my home shop. I've got several thousand dollars worth of their stuff and have had no complaints. Think I spent just under 2k on a dual voltage AC/DC GTAW(TIG) with all the trimmings (water cooler, adjustable pulse, flex cables/torch, premium pedal etc) and personally I'd put it right up there with a Miller Dynasty for performance. The Dynasty is a beauty and a champion of a machine, I love welding with them, but is it 5k$ better than my Everlast, PFFT!
    Also, if any of you are thinking about buying an Everlast, I recommend calling their sales department directly. I've had them knock decent amounts of money off any online price you'll find, including their own website. Granted it was during covid and they may not be as hungry for business as they used to be, but to save up to 3 digits in $ for a phone call... worth the effort.
    And no, I'm not sponsored lol.
    Cruzer[QUOTED][OP] likes this.
  13. Jun 5, 2023 at 5:50 PM
    Talon2006
    Talon2006 New Member Vendor
    If you ever have ambitions of putting it on a cnc machine get a hypertherm.
    if you just want to get it for hand cutting, the lotus ones are actually pretty nice and it’s what I would by.
  14. Jun 5, 2023 at 6:56 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Wanted to recommend a good cheap air compressor I've got just before COVID, but jeez, it's twice more expensive now... Why the salaries didn't grow?...
    Mater likes this.
  15. Jun 26, 2023 at 8:32 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Just bought that Bestarc cutter. Amazon offered a $30 coupon, so $219 total, which is pretty nice for such a machine. Went with the previous gen (analog controls).
    Cruzer[OP] likes this.
  16. Jun 26, 2023 at 8:50 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Mine should’ve arrived at work today. Will find out soon.
  17. Jun 28, 2023 at 12:45 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    It's heeeere!
    It looks pretty good. Solid build.
  18. Jun 29, 2023 at 6:04 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Third try on a 14 GA 304 stainless sheet (for stainless need to go hotter, just like with welding it). Pretty happy with the unit. It is not Miller or Lincoln Electric, but still decent.
    Talon2006 and Cruzer[OP] like this.
  19. Jun 29, 2023 at 6:16 PM
    #49
    Cruzer
    Cruz
    Sunnyvale, CA
    I think my first plasma project will be to make 3/16 thick alignment cams for the LCA so that I can get a little more caster to fit the new tires.
  20. Jul 12, 2023 at 3:00 PM
    #50
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    These plasmas are on sale right now. Might have to scoop one
    vtl likes this.
  21. Jul 12, 2023 at 4:01 PM
    #51
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Wow! I thought it was a good deal at $219 I've paid! $189 is no brainer.
    Mater[QUOTED] likes this.
  22. Jul 12, 2023 at 4:02 PM
    #52
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    By the way, I cut a 2.5 ft long 14 GA 304 stainless sheet and it didn't even warp! The only problem I tripped my weak 20 Amp garage breaker like 4 times. Will be installing a 220 V outlet this summer. Need more powah for cutting and welding!
    Mater likes this.
