Android Headunit
Discussion in 'Audio & Video' started by bryanpwatson, Sep 1, 2017.
  1. Nov 30, 2018 at 2:06 PM
    #2011
    Cthulhu
    I got the FRAC harness working but the audio cuts off when I switch the cameras on. Happens when I throw the truck in reverse too; camera comes on, but audio shuts off. Anyone experience this, and might have any suggestions to resolve?
    Also, on the AC, I rebooted again, and 25 degrees celsius came up. I tried changing to fahrenheit under system settings, but it didn’t change it. Also, when I pressed the 25 degrees to adjust the temp, when I pressed the up/down for where the temp should be, it went back to HI and LO. So, this still seems to be buggy for a 2018. I spoke with Phoenix, and they said yes, there are still issues on the temps for 2018s. An update is expected, but not exactly sure when :(
    Overall though, making decent progress, and people are right, it’s plug n play, just takes some patience with the RCAs. There’s a shit ton of them! Still would be nice for the manufacturer to send instructions for wiring (in English of course :)).
  2. Nov 30, 2018 at 5:28 PM
    #2012
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    2015 Platinum Crewmax
    D.A.P. Tune Bilstien 6112/5160 33x12.50xr20 Toyo Open Country M/T 20x9 Fuel Coupler TRD Exhaust
    You go into the settings and make sure the parking sound is on42204034_10156770435787417_8748551105790607360_o.jpg
  3. Nov 30, 2018 at 5:51 PM
    #2013
    TundraLuv
    TundraLuv New Member
    Kent
    IA
    2018 Midnight Black Metallic Limited Crewmax
    Gonna try to install tomorrow. Any additional tools needed to make the install easier? Besides patience and beer.
  4. Nov 30, 2018 at 6:11 PM
    #2014
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    After disconnecting the battery, pry tool to remove the bottom plastic cover that houses the USB hubs is the first interior step.
    End cutter pliers to trim the notch on the HU, and the plastic from the truck where it meets, they really serve no purpose other than possibly damaging the screen by separating the digitizer.
    TundraLuv likes this.
  5. Nov 30, 2018 at 6:58 PM
    #2015
    Cthulhu
    That did it...thank you SO MUCH @AK-in-MI!!
    Here’s another one my Tundra friends...
    I have the combo factory USB/AUX port/jack, pictured below. I can get the factory AUX jack working with an outside audio source (my wife’s iPod) using a 3.5mm cable, through the speakers. However, when I plug in the iPod using a USB cable into the factory USB port, there’s no sound. Does the factory USB port turn into a “charging only” port once you plug in the Phoenix HU? If that’s the case, what options do I have for connecting my wife’s iPod to the Phoenix HU in order for it to play through my speakers using a USB cable?
    Thanks for everyone in advance for your help!
  6. Nov 30, 2018 at 7:00 PM
    #2016
    BayRunner
    2017 Tundra Platinum
    The temp read out is still an issue for ‘18 and ‘19 upper trim levels. It was fixed for ‘14 through ‘17 but Toyota changed something in the ‘18s. Phoenix is aware of it and working on a fix.
    Also the radio is designed to fade the sound when in reverse. I believe it is the “fade” setting in the advanced settings. However I personally think the fade setting smoothed out the music sound. When it’s off it is too loud at a very low volume level.
    Cthulhu[QUOTED] likes this.
  7. Nov 30, 2018 at 7:02 PM
    #2017
    BayRunner
    Yes, the factory USB will only act as a charger after install of Phoenix HU
  8. Nov 30, 2018 at 7:02 PM
    #2018
    Cthulhu
    Thank you SO MUCH @BayRunner for reassuring me about the temps! VERY appreciated!
  9. Nov 30, 2018 at 7:04 PM
    #2019
    Cthulhu
    Thank you sir! So any way an outside audio source can be played through the Phoenix HU using a USB cable? Don’t people hook up external hard drives for videos and music?
  10. Nov 30, 2018 at 7:06 PM
    #2020
    BayRunner
    Have not tried it, but have you tried one of the USB cables that come with the HU?
  11. Nov 30, 2018 at 7:08 PM
    #2021
    Cthulhu
    Yes, tried plugging the old lady’s iPod into one of the USBs that came with the HU...NO SIGNAL...
  12. Dec 1, 2018 at 3:09 AM
    #2022
    ZPMAN
    Minnesota
    Check page #29 post 867 I put a 2 TB hard drive in the glove box, easy to wire USB to glove box.
  13. Dec 1, 2018 at 7:00 AM
    #2023
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    That is strange, If you have hooked it correctly you should be able to use both the USB cable provided that can be ran into the glove box and retain the factory USB slot. I have a 2TB HD in the glove box and i use the factory for any updates for the unit.
  14. Dec 1, 2018 at 7:36 AM
    #2024
    Cthulhu
    I really haven’t tried a USB stick or a non-Apple product as a media source for music via USB, just been trying the wife’s iPod. Do you think that since this is an Android HU it doesn’t “play well” with Apple products as media sources? Or, might I have something wired incorrectly? Please see my pic below. I plugged the grey USB wire from the vehicle into one of the two USB females from the Phoenix HU (the shorter USB female, the longer USB female I’m going to run into the glovebox like @ZPMAN). That’s correct, isn’t it? Thanks as always to anyone chiming in...
  15. Dec 1, 2018 at 7:38 AM
    #2025
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Through the glove box above the filter cover, no cutting/drilling
    That’s where I store movies, 128GB sticks are cheap at Costco.
    The other cable I have coming through a blank switch, now hole beside the factory USB. That’s where I interchange multiple low capacity sticks with tons of YouTube vids. Use 4Kdownloader to capture them. Use the Video app to play them and steering controls work, I don’t actively watch driving.
  16. Dec 1, 2018 at 8:49 AM
    #2026
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Get the dongle and you can CarPlay your iPhones.
    ZPMAN and Watt maker like this.
  17. Dec 1, 2018 at 3:13 PM
    #2027
    TundraLuv
    Kent
    IA
    All installed and working good thus far.
    Jsena likes this.
  18. Dec 1, 2018 at 4:51 PM
    #2028
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    Anyone have video/photos of this in a Gen 2?
  19. Dec 1, 2018 at 8:11 PM
    #2029
    jasonusn
    jasonusn New Member
    I just purchased a 19 tundra and have been looking at these units. I saw one installed on a new tundra as a dealer upgrade. The one the dealership is getting is on Amazon, I just happened to notice the dealership wrote reviews on it.
    I’m reluctant to get it, hate to be disappointed with something that’s not inexpensive. What’s everyone’s take that got it? Are you happy with it?
    https://www.amazon.com/2014-2018-Na...sla+screen&dpPl=1&dpID=51n6bBbQd1L&ref=plSrch
  20. Dec 1, 2018 at 8:20 PM
    #2030
    LifeCycle
    LifeCycle Build..build..build..
    Hugh
    Barcelona Red SR5 XP CM 2017
    TRD Dual exhaust TRD headlights bedmat Elka with adjustment knobs, ARB leafs-ring Fuel Crush +1 offset 20 inch 5 in backspacing TOYO open country 275/65 R20
    Been trying out some car launchers on a day trip. Namely CarWebGuru (upper pic) vs CarLauncher pro (lower pic).
    limited vertical themes on CWG. But you can change background as you prefer. has dimmer option and reset for the launcher. inconsistently plays the music off the app you last set it to ( i use pandora ) on boot up, you tube music (you have to press play button). Also, cant seem to have it show widget music track album/artist (all i get is unknown and a fixed track1 on the widget).
    Car Launcher pro has also limited vertical themes but cant personalize background, only to what is available on the app themes. It does use permission to play your last audio app on boot up. It has options of pop up music track and artist on certain screens. I like that it does show music track album/artist unlike CWG. There were a couple of times i have had to reset to have GPS speedometer, locator work on both car launchers.
    JoshuaA and Watt maker like this.
  21. Dec 1, 2018 at 8:52 PM
    #2031
    G10dra
    G10dra Not a New Member
    @jasonusn that link on the Amazon is the 1st generation headunit from Phoenix Audio, i belive everyone was saying it was slow and laggy,
    The newer one is here on the the link below with a updated operating system.
    Here the link for the latest ones that everyone has been buying
    https://www.phoenixautomotiveinc.co...oyota-tundra-2014-2018?variant=15031665918009
    Members here have gotton it for cheaper via group buy. The installation seem to be straightforward but you need to understand android operation system to understand how this head-unit works, It can be tricky at times to figure things out but with some patience and help of the forum members here you'll find your answers.
    To get an idea what you're going to get yoruself into I"ll suggest your browse thru this thead from the first page.
  22. Dec 1, 2018 at 9:17 PM
    #2032
    LifeCycle
    Hugh
    I copied music from my itunes library in a 32 gb thumb drive and use the system music player to play it. You might have better luck using a dongle to play ios music from iphone rather than an ipod?
  23. Dec 2, 2018 at 5:23 AM
    #2033
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Ya, the 1st gen version with the big round knobs at the bottom is the old one, it boots slower and owners were complaining support is already starting to drop off for it. However it can be a bargain from people upgrading if you want to save some money, I’ve seen it being offloaded for as low as $300.
    The new version comes with small knobs and button, or no buttons on the L and R side. I’ve been glad I’ve had physical controls to reach many times.
  24. Dec 2, 2018 at 5:33 AM
    #2034
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    Thank you for this info. I have this headunit on the back burner as I’m waiting to make sure all the kinks are worked out.
  25. Dec 2, 2018 at 5:43 AM
    #2035
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Nice screenshots, I’ve been happy with CarWebGuru for its simplicity but most of the time I don’t see the launcher, either a GPS app is running or videos are playing.
  26. Dec 2, 2018 at 6:57 AM
    #2036
    TundraLuv
    Kent
    IA
    Anyone have issues with the heated seats not working after install of GEN2? I've messed with the settings, TUNDRA HI, Highlander 15-16AC, and it just doesn't seem to want to work. Thanks.
  27. Dec 2, 2018 at 8:21 AM
    #2037
    TundraLuv
    Kent
    IA
    Anybody with a Limited gotten the temp to show?
  28. Dec 2, 2018 at 8:24 AM
    #2038
    LifeCycle
    Hugh
    I have a 17 SR5. But FB discussions on the higher trims said Tundra Hi is for your trim. Try tundra Lo then save and reboot, then back to tundra hi then save and reboot. some peeps might still be having AC issues on higher trims.
    TundraLuv[QUOTED] likes this.
  29. Dec 2, 2018 at 10:37 AM
    #2039
    jasonusn
    jasonusn New Member
    I read entire thread last night but still leaves me with questions. How does the navigation look and work? I assume if you download maps it would not need to be hot spotting, is that correct? I didn’t see in videos or pics of navigation in use. Also, would it be easy to hook up after market amplifier and subwoofer to? I can’t imagine a dealership putting them in brand new vehicles and selling them with glitches.
  30. Dec 2, 2018 at 11:31 AM
    #2040
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    There’s various options. Hotspot Waze, hotspot Google Maps, download Google maps (will expire), download TomTom maps, CarPlay an iPhone. And several less popular 3rd party options to download maps.
    If I don’t feel like eating up paid data, I use TomTom, it’s a 6GB NA file stored on the HU, no hotspotting.
    I believe this is Waze:
    I can’t imagine these HU’s being sold in new trucks without a disclaimer, wouldn’t take much to mess it up playing with the settings. It’s not locked down like an iPhone or your standard aftermarket Kenwood, Pioneer, Alpine.
    Cthulhu and Watt maker like this.
