Anyone able to get Rigid Industries covers over their fogs on the Pro?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by kevinrath, Oct 14, 2020.
  1. Oct 24, 2020 at 10:43 PM
    JJ_TNDRA20
    JJ_TNDRA20 JJ
    SOCAL
    2020 TUNDRA TRD PRO SW
    *Wheels/Suspension -ReadyLIFT Plus 2 -ReadyLIFT skid plate adapter -Method MR701 18 x 8 + 25 -BFG KO2 305/70/18 *Exterior -BakFlip MX4 hard cover -Rigid Industries foglight caps *Audio -2 AudioMobile 10 in subs -Sealed dual 10 enclosure -Helix Class D 1 channel amp -Helix 4 channel amp -5 channel Line Out Converter -BLAM audio 6.5s/6x9s/tweeters
  2. Oct 25, 2020 at 8:34 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Second cover came in yesterday so did some grinding to the mounting tabs this morning and got them on. I like the look and will test out how they look/work when it gets dark.
    Blue Thunder likes this.
  3. Oct 25, 2020 at 11:04 AM
    kevinrath
    kevinrath [OP] New Member
    Kevin
    2021 Lunar Rock Tundra TRD Pro
    295/70R18 Nitto Ridge Grapplers
    Nice, do you have any pics of the covers before you put them on? Just curious about what it looked like after the grinding
  4. Oct 25, 2020 at 12:40 PM
    abomb60
    Massachusetts
    Sorry didn't take any pics until they were mounted.
    Most of the grinding was on the outside edge of the mounting tabs and I just kinda kept grinding then test fitting. Thread #6 has a photo from someone else that is what I did but due to these being the aftermarket Rigids on a homemade mount in Pro bezels I had to grind a bit more to get them in there.
  5. Oct 25, 2020 at 3:00 PM
    DjSamthrax
    DjSamthrax Master Certified Toyota Product Specialist
    Minnesota
    2020 8371 Army Green
    Coachbuilder Pro Kit, 35x12.5 BFG KM3s, Baja SquadPros on Rago Lo-Pro Brackets, Rago Dash Divot Plate, AJT Stuff, LED Lighting throughout, TRD Intake, Bedliner, Tint, Full front PPF, SPS Graphene Coating
    Yes. They fit. Tightly.
    Huckwheat likes this.
  6. Oct 26, 2020 at 6:37 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Much to my surprise, I got both of mine today. They went on fairly easily without any grinding or sanding. I love the light it puts out. Thank you for bringing these to my attention.
    thebeez likes this.
  7. Oct 28, 2020 at 7:21 AM
    Big dave
    Big dave Junk it baby
    Big dave
    Ft wroth Tejas
    2021 TRD PRO luner rock
    1996 Tahoe 2dr 4x4 2021 4 runner
    i had to give $58600 but they gave me $49500 for my army green pro with 25000miles so i was really cool with the deal..
    EN2TUNDRA likes this.
  8. Oct 28, 2020 at 7:29 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    IMPHO...If you want to run amber, sell what you have and buy the selective yellow.
    The new selective yellow is much more effective (visually) AND the Rigid covers have been independently tested to reduce output by 50%.
    Just something to mole over.
  9. Oct 28, 2020 at 11:25 AM
    abomb60
    Massachusetts
    I thought about that and if I decide that amber/yellow is going to be permanent I might just get the selective yellow ones. I do like that these also protect the lens and not sure how bright the TRD Pro Rigids are but the SAE's are stupid bright so cutting them down a bit isn't a bad thing for street use. Haven't had a chance to try them in fog but we're supposed to get snow Friday so maybe i'll get a chance to mess around with them in some actual inclement weather.
  10. Oct 28, 2020 at 12:05 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    in the lengthy first post, Rigid output cut:
    "While the amber covers do a great job completely eliminating the short wave length blue light spectrum spike, they also significantly reduce the effective output. I believe Rigid claims a 15% loss, I measured a 50% loss in a controlled indoor environment with a NIST certified digital spectrometer.
    Rigid lux at 18': 395.5
    Rigid lux at 18' w/ amber covers: 195.2, ~50% loss in output"
    post 257 gives a great run down on the selective yellows
    https://www.tacomaworld.com/threads...fog-light-review.554813/page-13#post-18889711
    abomb60[QUOTED] likes this.
  11. Oct 28, 2020 at 1:07 PM
    19TurdPro
    2019 Tundra TRD Pro
    Say I wanted to go this route, is there a plug and play solution?
  12. Oct 28, 2020 at 1:56 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Not sure what your OE wiring is but there is an adapter for previous years to wire in a Rigid to the OE harness retaining the OE stalk/fog functionaility.
  13. Oct 28, 2020 at 2:01 PM
    14burrito
    2014 SR5 CM 4x4 5.7
  14. Oct 29, 2020 at 6:13 AM
    Big dave
    Big dave
    Ft wroth Tejas
    My ridge
    Lol I did same thing!
    When one came i got pissed off then realized I did not read ad
  15. Nov 5, 2020 at 8:28 PM
    FiveO Enduro
    FiveO Enduro New Member
    Buffalo, NY
    2020 Army Green Pro
    Cool thanks, I've been researching this and almost just bought some lamin-x film. I wasn't sure if these would fit or not, so thanks for the info.
  16. Nov 5, 2020 at 8:56 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Zero issue here. No trimming, snapped on within a second.
    TundraPHX and thebeez like this.
  17. Nov 11, 2020 at 5:33 PM
    kevinrath
    Kevin
    i still can’t get mine on :(
  18. Nov 11, 2020 at 5:36 PM
    19TurdPro
    2019 Tundra TRD Pro
    Pop one side on but don't sink it in all the way, just make sure it's barely past the black trim. Put other side on and push like hell on that side. Took me about 5 seconds per light.
    thebeez and 14burrito like this.
  19. Nov 11, 2020 at 5:37 PM
    #49
    kevinrath
    Kevin
    gonna go try it now. Thanks
  20. Nov 11, 2020 at 5:47 PM
    #50
    kevinrath
    Kevin
    I must have very weak fingers or something because I could not get it lmao
  21. Nov 11, 2020 at 6:23 PM
    #51
    kevinrath
    Kevin
    Finally got it. I used a serrated knife to cut the flairs a bit and now it fits perfectly.
    thebeez likes this.
  22. Nov 12, 2020 at 5:31 AM
    #52
    blanchard7684
    blanchard7684 New Member
    I put these on last night.
    tight fit but with some finesse and a flat tip I got them to snap in.
  23. Nov 12, 2020 at 5:33 AM
    #53
    kevinrath
    Kevin
    nice! I probably could have gotten them on without grinding the flares down a bit if I used a flat head but I wasn’t thinking right lol
  24. Nov 12, 2020 at 4:40 PM
    #54
    Weavin Pro
    Weavin Pro New Member
    2020 Army Green TRD PRO
    Put mine on in a couple minutes....but don’t know if I like the snap on look?.?.?
    May try the Lamin X route before completely replacing.
  25. Nov 12, 2020 at 5:45 PM
    #55
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Why do yours look slanted?
  26. Nov 12, 2020 at 5:51 PM
    #56
    Weavin Pro
    Thanks for the concern....but only fit one way....just the pic angle I assume
  27. Nov 14, 2020 at 3:28 PM
    #57
    kevinrath
    Kevin
    Finally got a pic
  28. Nov 17, 2020 at 4:28 AM
    #58
    ScarWars
    ScarWars New Member
    2019 Toyota Tundra TRD PRO Super White
    Driver side was easy fit. Had to grind a little off the tabs on the passenger. F296D858-BEFB-4981-8842-F25F457E65E8.jpg
    Fotnot, EN2TUNDRA, Huckwheat and 2 others like this.
  29. Nov 17, 2020 at 2:36 PM
    #59
    DjSamthrax
    Minnesota
    I have a set of these if anyone wants them. Paypal me $20 and they will ship to your door step.
  30. Nov 17, 2020 at 2:50 PM
    #60
    Brettstation37
    Brettstation37 New Member
    Brett
    Catskills NY
    2020 Tundra CrewMax TRD Sport
    Wonder if these will fit over top of caliraised pods as well?
