Anyone recommend good replacement headlight assemblies?
Discussion in '2.5 Gen Tundras (2014-2021)' started by alcain42394, May 2, 2023.
  1. May 2, 2023 at 3:39 PM
    alcain42394
    alcain42394 [OP] New Member
    Looking to replace my headlight assemblies on my 2016. Looking for good reliable assemblies. What say you?
  2. May 2, 2023 at 3:47 PM
    Taco-Spike
    Two Trucks
    For $600 +/- for the OEM headlights. It’s really the best option for the money, I say
    GODZILLA, V3N0M, T500 and 4 others like this.
  3. May 2, 2023 at 3:49 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    memario1214 likes this.
  4. May 2, 2023 at 7:13 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I had some projector retrofits in my '16 and the output was amazing. The reliability left a lot to be desired. I ended up replacing the projectors with 18+ OEM leds and Ihacker harness for the sake of reliability.
    T500, 1UP, ryanwgregg and 1 other person like this.
  5. May 3, 2023 at 7:41 AM
    lerbud1
    lerbud1 New Member
    Larry
    Waco, TX
    2021 Tundra SR5
    I just changed mine to the OE led headlights. Very easy with the harness. Ordered from Sparks and got the harness from Headlight Revolution. $600 for both headlights is a deal! Our RAV4 has led headlights and one of those is $700!
    T500, WILLINH and ryanwgregg like this.
  6. May 3, 2023 at 7:50 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    another vote for oem trd pro headlights with ihacker harness. Best bang for buck.
    Sierradevil, V3N0M, T500 and 4 others like this.
  7. May 3, 2023 at 8:12 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    2017 Limited Crew TRD, Ironman Pros with JBA uppers. Prinsu rack. RSI, RCI sliders
  8. May 3, 2023 at 12:36 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I did the exact same thing, they are well worth the money! I hacker great guy and and quality harness.
    Sierradevil, GODZILLA, T500 and 2 others like this.
  9. May 3, 2023 at 4:25 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 DC Attitude Black
    OEM and done.
    1UP, WILLINH, GODZILLA and 3 others like this.
  10. May 3, 2023 at 4:44 PM
    MadMaxCanon
    Ya it's rare that oem is affordable, awesome upgrade and easy to do. Plus supporting a fellow forum member
    GODZILLA and T500 like this.
  11. May 3, 2023 at 4:44 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    If you're on a budget like I was, you can't beat the AlphaRex offerings and some 60w or 72w LED H7 bulbs.
    Not thrilled with the brights pattern at night but it's definitely a TREMENDOUS step upwards from the OEM ones in my '16 SR5 too.
  12. May 3, 2023 at 5:16 PM
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    Just did the exact same thing a month ago. It’s a no brainer. Can’t go wrong, easy peasy install too
    WILLINH[QUOTED] likes this.
  13. May 3, 2023 at 6:27 PM
    sonofdad
    sonofdad New Member
    steamboat springs, co
    2017 Tundra SR5
    i'll echo what most others have said above ... i did the OEM TRD Pro LEDs and @iHacker harness upgrade a month ago and haven't looked back. it's not cheap, but totally worth it and easy to do yourself.
    Sierradevil and WILLINH like this.
  14. May 3, 2023 at 8:51 PM
    Taco-Spike
    Two Trucks
    I agree but disagree.
    I feel it is cheap, my Tacoma OEM LED’s were $1300ish for just the headlights alone plus harness. I was stoked to find out the tundra’s were less than half the price.
    A bit different set up with entirely full LED’s and switchback drl turns but still… I can see where you’re coming from
    GODZILLA and sonofdad[QUOTED] like this.
  15. May 3, 2023 at 11:56 PM
    V3N0M
    V3N0M New Member
    Ryan
    Orange County, CA
    2020 Tundra SR5 Crewmax
    - Carven Type R Exhaust - TRD LED Headlights - (2) LED Ditch Lights Mounted on Hood - Cali Raised Ditch Light Brackets - (2) 42” LED Light Bars Behind Grill - Cali Raised Hidden Grille Mounting Brackets - AJT Interior Chrome Delete - AJT V3 Shift Knob - 8" ReadyLift w/ Bilstein 5100's (all around) - 18" Raceline 948B Split Wheels - Toyo Open Country MT 37 x 13.50 R18 - Amp Research Power Steps
    Definitely agree with OEM, I upgraded to TRD PRO assemblies and haven’t looked back as well.
  16. May 4, 2023 at 4:37 PM
    Ebrperk
    Ebrperk New Member
    2016 SR5 4wd Crewmax
    Factory LED headlights with ihacker harness, Bilstein 6112,s at 2" lift and 5100 in back, SABM, rear diff breather mod, Firestone Destinations AT2, metal oil filter mod, fumoto oil drain, stock skidplate mod to access oil filter
    YEPPERS!!!! OEM LED and Ihacker harness, great upgrade
  17. May 8, 2023 at 3:57 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    I also recommend the OEM TRD headlamps.
    A couple years ago I responded to a thread here where a rep from Anzo USA was looking for LED headlamp beta testers. He is legit and has been great to deal with but the china-made products are garbage, even when given to me for free.
    I am currently on my 3rd pair of free headlights in a little over two years. First set, one of them just randomly stopped working, so he sent me another set. 2nd set, same issue but it was because there was 3" of water inside the headlamp housing. Im now on my 3rd set and they are not nearly as bright as the first two sets.
    They look great but chinese products just completely suck. PERIOD.
    When this 3rd set of headlamps fail (and they will) I will whip out my wallet and run to the local Toyota dealer for a set of OEM TRD Pro headlamps.
  18. May 8, 2023 at 4:00 AM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Another vote for oem led here
  19. May 8, 2023 at 5:30 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    OEM. Nothing comes close to their build quality. Headlights are one of those things that tend to be very finicky in the aftermarket, even with some of the high dollar aftermarket models. If you're on a budget just buy used. I bought my OEM LED's for ~$300 total buying each one used and then using a conversion harness off ebay for another $50.
    FabioXc likes this.
  20. May 8, 2023 at 6:23 AM
    Scorpion006
    Scorpion006 I'm athletic - I’m known to surf the web for hours
    Austin, TX
    2017 White Tundra 1794
    Exactly this... you can get the headlights a lot cheaper used and getting a new harness from Amazon for like $40.
  21. May 8, 2023 at 6:30 AM
    Knox_Tundy
    Knox_Tundy New Member
    Knoxville, TN
    Same OEM is the way to go IMO. I went from clear LED to Pro version.
    V3N0M, WILLINH, reywcms and 3 others like this.
  22. May 12, 2023 at 12:36 AM
    50Shades
    50Shades Sin City Tundras
    J
    West Coast
    2021 Tundra SR5 CrewMax Trail Edition 4x4
    I had the halogen on mine originally.
    went with LED oem. then eventually went with morimoto xb. a lil pricey but i like the way it looks.
    almost 2 years with morimoto and no complaints.
    V3N0M, Warreng, memario1214 and 3 others like this.
  23. May 12, 2023 at 12:44 PM
    mista_g
    mista_g New Member
    2016 Quicksand TRD Pro
    Just installed these bad boys a few weeks ago, liking them a lot such an upgrade from the stock halogens:
    V3N0M, hi_rawb and 50Shades[QUOTED] like this.
  24. May 12, 2023 at 12:57 PM
    50Shades
    J
    West Coast
    agreed brother
    theres just something about those amber lights too! but their high beam is a bit underpowered for my taste. so i converted my fogs to driving lights and use the "fog lights" as my high beams.
    V3N0M likes this.
  25. May 13, 2023 at 5:08 AM
    Blkdmax
    Blkdmax New Member
    Tennessee
    2021 Cement CrewMax 4x4
    Do the OEM trd pro lights have a distinct cut off?
    V3N0M likes this.
  26. May 16, 2023 at 10:51 AM
    Chu
    Chu New Member
    2014 Crewmax
    It's not a clean and defined cutoff like you would see in an OEM style projector headlight, but yes, there's a cutoff. Just make sure you mark the cutoff in the stock lights before swapping so you get the same aim.
    V3N0M, WILLINH and Blkdmax[QUOTED] like this.
  27. Mar 12, 2024 at 8:20 PM
    ajrm2113
    ajrm2113 New Member
    AJ
    San Antonio, TX
    2016 Gray Tundra Limited
    Hopefully this isn’t a stupid question, but does the year for the replacement assemblies matter? My Tundra is a 2016, so should I go with that year? Or any year of the same generation?
  28. Mar 12, 2024 at 8:33 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Assemblies that fit a 14 will fit a 21 and vice versa so you’re good!
    WILLINH and ajrm2113[QUOTED] like this.
  29. Mar 12, 2024 at 8:53 PM
    ajrm2113
    ajrm2113 New Member
    AJ
    San Antonio, TX
    Thank you!
  30. Apr 3, 2024 at 3:31 PM
    Timberline
    Timberline New Member
    Colorado / South Dakota
    2016 Tundra TRD Limited ~ 2007 4Runner Sport ~ 2003 Tunda (sold)
    This was a big surprise for me with my 2.5gen, the lights are terrible pretty much the same as the lights in my '03 Tundra. But my wife's '-07 4Runner has excellent OEM projectors .... so why does my 9 year NEWER truck not have them makes no sense unless it was to keep cost down by Toyota
