Anyone regret going to 275/70/18’s on their stock Tundra?
Discussion in 'Wheels & Tires' started by BigWheel, Aug 30, 2018.
  1. Sep 6, 2018 at 2:35 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Most will hardly notice a change moving up a size, but you will notice a gain moving back down to the smallest standard size.
    Rica25 likes this.
  2. Sep 6, 2018 at 3:10 PM
    zeke7681
    zeke7681 New Member
    Zeke
    PA
    2018 Black TRD Sport CM
    Mine did on the front small mud flap
    Rica25 likes this.
  3. Sep 15, 2018 at 10:00 PM
    matzelle
    matzelle New Member
    Eric
    2018 Tundra CrewMax Limited Cavalry Blue
    Greetings, all! I'm new to the forum... I just purchase my Tundra a couple of weeks ago... had the dealership install a 3" lift. I had the 275/70r18 BFG A/T KO2s installed yesterday. Modified the skid plate to get rid of the rub... Now I'm wondering if it's necessary to re-calibrate the speedometer. Anyone have any experience with calibration? How far off will my mph really be? I can't imagine it would be more than 3-4%. The hypertech module looks like a PITA to install, and I've been reading about some issues with them. Are there any others out there? I'm coming from a JK Unlimited, and re-calibration was a piece of cake.
  4. Sep 16, 2018 at 12:41 PM
    Chuckm
    Chuckm New Member
    Charles
    2015 Toyota Tundra TRD Pro
    None
    @matzelle I have the same size but did not have to remove anything and no rubbing issues. As far as the MPH, it isn’t that significant of a change. About +1-2mph if your going 65-75mph.
  5. Mar 30, 2019 at 1:25 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 GMC Sierra At4x AEV
    For any of you, I’m going to do stock wheels and suspension on 275/65/18 or 275/70/18 for this upcoming build. Any real rubbing besides that lame front screw in flap?
    I’m leaning Cooper AT3 XLT. I do a lot of camping and off-roading in the middle of legit nowhere Nevada. Can’t afford to get a flat or puncture out there in the 5ply Michelin’s even though they’re great for everything else.
    Skey44, kparrow and Rica25 like this.
  6. Mar 30, 2019 at 4:14 PM
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    That's the part some people don't seem to be getting. Going up one tire size larger would be almost unnoticeable if you stick with the same type of tire but when you go from a passenger car rated tire with a "highway" tread type to an "E" load rated heavy truck tire with an aggressive offroad or AT tread pattern, you're going to feel and see the difference, even if you stick with the same size.
    275/70R18 is a very common truck tire size right now and a lot of us aren't towing heavy loads so we have no need for an "E" load rated tire. Why there aren't any decent AT's tire in the "C" or "D" load range is beyond me?
    And that's the only downside of going 275/70R18 right now. No one makes an non "E" load rated tire in that size that's any good. Even the Michelin LTX's in that size are still E load rated tires weighing in at 61lbs each (which is ~20lbs per tire heavier then the factory installed tires)
  7. Aug 4, 2019 at 6:12 PM
    MR TRD PRO
    MR TRD PRO New Member
    Queens, NYC
    2019 VooDoo Blue Tundra TRD Pro
    HP Tuned
    I have a 2019 Pro and was thinking of getting the BFG K02 in 275/70/18
    Rica25 likes this.
  8. Aug 4, 2019 at 6:16 PM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
  9. Aug 4, 2019 at 7:22 PM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    I am very happy with my 275/70/18 Falken Wildpeak AT3W 2500 miles in! These Tundras can handle the tire size. On my 2015 f150 2.7l it was awful and I returned to stock tire size.
    Rica25 likes this.
  10. Aug 5, 2019 at 7:56 AM
    ComaArmy
    ComaArmy New Member
    Just got Bridgestone A/T 275-70/18 and love them. A bit rougher on road but worth it because they look better and will handle m
    silverstreak16, Skey44 and Raxman80 like this.
  11. Aug 5, 2019 at 8:37 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    I have stock size 275/65/18 Cooper AT3 4S in a p rated tire not LT. They are only 44lbs each which is nice, and my speedometer factory is 2 mph off to the negative at 80mph per GPS(speedo reads 78) Since the difference at 80mph between the two is 2.7mph and at 70 it is 2.4mph, your speedo should be spot on accurate if you go with 275/70/18. I’m considering the AT3 XLT or the ST MAXX when I need tires next in 275/70/18. I did want 295/70/18 but I don’t think I need to go much more than a 33” tire vs a 34.8”. I’m just looking to level it with 5100’s and then put on 1 or 1.25” BORA spacers
  12. Aug 5, 2019 at 12:55 PM
    Tzvia
    Tzvia Just an old woman in a pickup truck.
    Los Angeles County
    2019 5.7L Limited TRD Off Road 4x4
    Just a Bed Rug and Snugtop XTRA Vision
    I did those tires in 275-70-18 on my stock '19 TRD Offroad because I couldn't trust the stock tires offroad. It rubs that little mudflap in front when I am in full turn backing up. Haven't had the time to remove them yet but I will hopefully this weekend. Otherwise the XLT tires are really nice. Quiet at highway speeds, remarkably so. Did some offroad on my summer vacation in UT, CO, NM and AZ and they did really well most everywhere, and were even passable in damp clay. After decades on my previous trucks with the BFGs, I'm really impressed with the Cooper XLTs. No regrets (well, I did lose .5~1mpg depending on the conditions/speed but was expecting worse so I'm good). Good tires, worth losing a dinky mudflap.
  13. Aug 11, 2019 at 10:46 AM
    jtav2002
    jtav2002 Retired Adult Film Sound Man
    Josh
    Reading, PA
    2019 GMC Sierra 1500 AT4 6.2
    Stock suspension?
  14. Aug 11, 2019 at 2:44 PM
    HighonFirewood
    2019 Tundra
    Yup
  15. Aug 12, 2019 at 3:34 PM
    biebs96
    PA
    I’ve been debating on this increase as well. My previous two tundras 05 had standard 5 ply tires and my 10 had standard tires then upgraded to some rock warrior wheels with 10 ply tires. The ride handling was certainly more harsh feeling with the 10 plys, which is what makes me consider now on my 17 going with the tires I want but in the 5ply version to help keep the ride as comfortable as it is.
  16. Sep 9, 2019 at 2:20 PM
    vagrant
    vagrant New Member
    2017 Tundra 4x4
    What did it do to the speedo / ODO accuracy?
  17. Sep 9, 2019 at 3:47 PM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I didn’t do anything. Honestly my speedometer is on with these tires, but odometer is slightly off, but not much.
  18. Sep 9, 2019 at 4:05 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I just realized recently that it is a common truck tire because it comes stock on F350 trucks, thus why most brands are focused on e rated most likely
  19. Sep 10, 2019 at 11:16 AM
    #49
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Wrong.
  20. Sep 20, 2019 at 11:52 AM
    #50
    Keithbickford
    Keithbickford New Member
    Keith
    Seattle
    2020 Cavalry Blue Tundra
    King 2.5” suspension, Method Race 313 wheels, Nitto Ridge Grapplers 35x12.5x17, TRD exhaust, RCI Skid Plates, Alpine ILX-F309 stereo, Alu-Cab roof top tent on Yakima Overhaul HD, Line-X spray in bed liner, VLED LED reverse light bulbs and VLED LED license plate reverse light. VLED brake/tail light bulbs. VLED third brake light and cargo lights.
    OMG, you traded your kids in on tires and wheels! Was your wife mad?
  21. Oct 4, 2019 at 7:50 PM
    #51
    hood
    hood New Member
    Any rubbing? Offset?
    Rica25 likes this.
  22. Oct 4, 2019 at 10:31 PM
    #52
    HighonFirewood
    2019 Tundra
    +25. Removed front mud flaps and cut the bridge of the cab side mudflats. But no rubbing at all
  23. Oct 5, 2019 at 7:55 PM
    #53
    Stocky Balboa
    Stocky Balboa New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    This is the setup I’m looking for. Looks great.
  24. Oct 5, 2019 at 8:35 PM
    #54
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    Regrets on f150, not Tundra. Much more robust vehicle
  25. Nov 8, 2019 at 8:08 AM
    #55
    Joettrux
    Joettrux New Member
    2018 tundra trd crew max 4x4
    275/70 r18 duratracs
    I went with 275/70 r18 Goodyear duratracs. No rubbing stock suspension (2018 trd crewmax) I had removed the little wind deflectors the day I bought the truck new (they’re ugly as sin).
  26. Nov 8, 2019 at 10:33 AM
    #56
    Stig
    Stig New Member
    Maybe I'm missing something but it seems like the bigger change in going from P rated 275 65 to E rated 70 is with the heavier load rating (so 10-15lbs heavier and stiffer) rather than the rather insignificant 1" height increase.
    I can see the only reason to go with 275 70 is to get the E load rating if you tow, haul, or off-road often.
  27. Nov 8, 2019 at 5:06 PM
    #57
    Joettrux
    Joettrux New Member
    I don’t notice any difference in the ride quality at all going from the p to the e. I’m running 45 psi. I like that the 10 ply tire is more durable. These trucks shouldn’t come with p rated tires, they should have at D rated lts.
    Savmikey47 likes this.
  28. Nov 9, 2019 at 9:13 AM
    #58
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    I just put some 285/65/18 duratracs on last week and I love them. No rub, no trimming/skid plate modification. They come in a load range D- 5 ply so I don’t notice any mileage or difference in braking and very smooth on the highway!
    pro2amendment and jewsNbrews like this.
  29. Nov 9, 2019 at 9:27 AM
    #59
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    Dude, that is a really nice truck. I don’t see that color often
  30. Dec 12, 2019 at 5:12 PM
    #60
    favStaR
    favStaR New Member
    2020 Tundra TRD Sport Premium
    How much caliper clearance do you have in that 18" rim? Is that a TRD and what year is it?
    Thanks
