Anyone running 17" rims on your 2.5 gen?
Discussion in 'Wheels & Tires' started by BuckWallace, Apr 2, 2018.
  1. Jan 23, 2019 at 6:39 AM
    #61
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    I would be all over these if they were offered in an anodized orange!
  2. Jan 23, 2019 at 6:53 AM
    #62
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    From what I understand, nothing has changed with the 2019s. With that said, you may have to do some trimming or a CMC to run 35s with an offset that low. The consensus on here is that +25 to +35 is the sweet spot. But what works with one Tundra may pose problems for another one similarly situated. Either way, looking forward to photos of your setup once you get it done!
  3. Jan 23, 2019 at 9:21 AM
    #63
    Jman245
    Jman245 Just moving about my way.
    Jay
    R.CUCAMOMGA,CA
    '19 Tundra TRD SPORT, ‘21 Trail Edition
    Trd pro suspension
    Thank you for your help!
  4. Jan 23, 2019 at 9:32 AM
    #64
    JM_redsox
    JM_redsox New Member
    2014 Silver 4X4 tundra
    3.5 inch level
    I found a set of Rock warriors which are 17's. They are tougher to put on because of the size of the brakes. The brakes actually rubbed some of the weights for balancing it was so close.
  5. Jan 23, 2019 at 9:33 AM
    #65
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    What's the
    what are the specs on those? Is it only certain 17in wheels that clear?
  6. Jan 23, 2019 at 9:37 AM
    #66
    Pat
    Pat Sorta-new Member
    Pat
    Virginia Beach
    '16 MGM SR5 DC
    CAI, 5100's
    My rock warrior wheels just barely clear the brakes as well. My weights were in a spot where they didn't rub. Pretty sure any 17" wheel will clear the brakes though.
  7. Jan 23, 2019 at 9:53 AM
    #67
    JM_redsox
    3.5 inch level
    I am unsure what the offset is on the rock warriors. I agree that any 17" wheel should fit.
  8. Jan 23, 2019 at 10:08 AM
    #68
    JM_redsox
    3.5 inch level
    These are my wheels. Got the tires with them so going to wear them out before upgrading.
  9. Jan 23, 2019 at 10:26 AM
    #69
    Pat
    Pat
    Virginia Beach
    '16 MGM SR5 DC
    CAI, 5100's
    EDIT: Misread, they're +50 offset, not +60 like the rest of the stock wheels.
  10. Jan 23, 2019 at 12:04 PM
    #70
    AZ_Tundra64
    AZ_Tundra64 New Member
    2018 TRD CM MGM
    295/70/17 ridge grapplers
  11. Jan 23, 2019 at 1:44 PM
    #71
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Rock warrior wheels are +50mm offset
    SoCal619 and Pat like this.
  12. Jan 23, 2019 at 1:52 PM
    #72
    Berdine
    Binghamton, NY
    Those red Fuels are awesome! Have to be careful with certain 17" wheels, a guy I know just bought 17s and brand new stt pros went to mount the wheels and they hit the brake calipers. Sean Hillaker is running RW wheels and 37 13.50 17s on 3.5" lift with 3/4" wheel spacers. Truck looks awesome!
  13. Jan 23, 2019 at 2:34 PM
    #73
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    17" Methods fit, but are 0 offset and will have a wide tire sweep when turning. So trimming is required. 18" has offset.
    Very close to the caliper on 17"s though. Be mindful of where the balancing shop puts the weights.
  14. Jan 23, 2019 at 2:40 PM
    #74
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    Man I wish the RG's in 295/70R17 had a "C" load version. I have no need for "E" load rated tires or the firmer ride, extra weight and lower gas milage that comes with them :(
    I think that is the exact setup I want (295/70/17 RG's with Icon's 17's Rebounds but in titanium) :cheers:
    My only hesitation is, your rig is obviously lifted (or at least leveled) mine is stock and I'm not sure if that combo will fit on a stock suspension? ThundraSr5 fit them on his stock but with a different wheel offset and no front bumper?
    Pillslinger likes this.
  15. Jan 23, 2019 at 3:46 PM
    #75
    AZ_Tundra64
    2018 TRD CM MGM
    I'm lifted 2.5" in the front and 1.25" in the back. I had to remove the small aero flaps in front as I barely rubbed in reverse 3/4 turn.
    I know coachbuilder makes some bumper spacers that might help you fit them if you don't want to buy an aftermarket bumper or lift the truck
    Jman245 likes this.
  16. Jan 23, 2019 at 3:52 PM
    #76
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    Just found out the 17s wont fit! I dont want 20s so I'm going with 17in methods
  17. Jan 23, 2019 at 5:24 PM
    #77
    HappyGilmore
    Trent
    Lakewood CA
    I love mine, but just want to make sure you are aware how far they stick out with the 0 offset. It will be an inch or 2 past your fenders. I didn't think it would be that bad on mine, but it's pretty wide. I don't mind it, just wider than i anticipated. Also cant be afraid to trim If you're gonna run a true 35 on a 2.5 inch lift.
    Jman245[QUOTED] likes this.
  18. Jan 23, 2019 at 6:32 PM
    #78
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    I actually like the lower offset look on all Vehicles, as long as it's not 3/4 of the way out. I have a shop here in central Texas doing a bmc on it. Thanks!
    HappyGilmore[QUOTED] likes this.
  19. Jan 23, 2019 at 7:11 PM
    #79
    airgunner
    N-KY
    2015 DC MGM TRD
    Wow even with a 2.5" lift, you still had some minor rubbing? That's disappointing seeing how even if I did lift mine, it would probably be no more then 2"? Good to know either way. Thanks
  20. Jan 23, 2019 at 7:21 PM
    #80
    equin
    Ed
    DFW, TX
    I’m guessing it’s the wheel offset that makes it more likely to rub. TRD Pros with only 2” of front lift and stock wheel offset of about +60 don’t seem to rub as much, if at all. The less offset (more they stick out), the more prone they are to rub the front bumper plastic liner or body mount or both, depending on tire size. On the other hand, the more offset, the more prone they are to rub the skid plate or upper control arm.
  21. Jan 24, 2019 at 5:32 AM
    #81
    airgunner
    N-KY
    2015 DC MGM TRD
    I agree, its all a balancing act. Sticking with the factory +60 offset wheels is not an option for me as the main reason I want to upgrade is I feel the factory wheel are too recessed into the wheel wells. I'm looking for a wheel/tire package that will bring them out flush or just slightly protruding from the wheel wells but without having to lift it. Seems to me, a +25 offset wheel (to no more then a +20) is where I need to be. I was hoping to be able to run a 33" tall tire (like the 295/70-17) but it seems like that will be pushing it with no lift? I know some have installed 285/65-18 (a 32.5" tire) with no lift or issues so I'm thinking a 285/70-17 (which is roughly about the same size) should work?
  22. Jan 24, 2019 at 10:03 AM
    #82
    equin
    Ed
    DFW, TX
    Before my 2" lift and removal of the bumper liner, I ran 275/70/18 (33") on MB 352 wheels with +25 offset and no lift. I had rubbing on the front little flap in reverse and while turning. I'm now running 285/75/17 (33.8") on Icon Rebounds with +25 offset. I removed the plastic bumper liner and have no rubbing with 2" of lift. I think you should be fine with 285/70/17s and +25 offset. You might have a bit of rubbing on the front little flap, but you can easily remove that.
  23. Jan 24, 2019 at 4:00 PM
    #83
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    I've decided on running 305/70/17 on 17x8.5 0 offset, with a bmc and fender trim
    Pjholt likes this.
  24. Jan 24, 2019 at 8:44 PM
    #84
    Bmbulldog2013
    Bmbulldog2013 New Member
    Alfred
    Placentia, CA
    2018 Tundra tRd Sport CM 4x4
    Post some pictures when done.
  25. Jan 25, 2019 at 4:24 AM
    #85
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    For sure!
  26. Jan 25, 2019 at 6:39 AM
    #86
    Big J
    Big J New Member
    2020 4x4 crewmax
    Love the FN's on the 18. What was the specs in the wheel and lift? Is that the gunmetal color?
  27. Jan 25, 2019 at 8:58 AM
    #87
    Phantom Lord
    Phantom Lord New Member
    Byron
    2017 MGM CM Limited
    17” Rebounds with 315/70r17 ko2’s.
    3/1 suspension, only had to remove the front mud flaps and push the fender liner in 1/2” towards the bumper by drilling new holes for it.
    CAAD408E-708A-4834-916A-6E983BA0EC59.jpg CC922269-1FE4-4F0E-BEB4-584962296CF6.jpg
    dpast88, Northernheat, Pjholt and 7 others like this.
  28. Jan 25, 2019 at 10:51 AM
    #88
    Big J
    Big J New Member
    2020 4x4 crewmax
    Nice! Rebounds look good. Is about level at 3/1? I was thinking 3/2 for some rake
  29. Jan 26, 2019 at 8:34 AM
    #89
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    What's the wheel specs?
  30. Jan 26, 2019 at 11:35 AM
    #90
    dubless
    dubless New Member
    Al
    2016 Tundra/Old—>2018 Tundra/New
    New Ride- FOX 2.5 ExtTravel Reservoirs/2.5 Piggybacks, DirtKing UCA, Maxtrac +1. Ironman POLY bushings, Wheelers Superbumps, TRD Front/Rear Sways, TRDPro SkidPlate, 35" TOYO RT, ARE CX Topper, BedRug, Husky X-Act Mats Old Rig- Bilstein 6112/5160, TC UCA CB+2’s . 17” BMF Pro SSD, 35” KO2, Snugtop topper
    Thanks! The wheels are 17x9 et25 in gunmetal on 35x12.5 Toyo RT. Fox 2.5’s/Maxtrac shackles ~3/1” lift.
    Big J[QUOTED] and Jman245 like this.
