Anyone running a 3'' body lift?
Discussion in 'Suspension' started by SullyMoto19, Jan 31, 2018.
  1. Feb 1, 2018 at 8:26 AM
    SullyMoto19
    SullyMoto19 [OP] New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    absolutely! :fistbump:
  2. Feb 1, 2018 at 8:55 AM
    SullyMoto19
    Tyler
    Houston, Texas
    Just downloaded the installation guide for a 3" body lift and looked it over.
    Verdict: Holy shit. SO much cutting to be done (lines, bumper, etc.) looks like a lot of work.
    I wonder if I would be able to do adjustable Coils and UCAs instead. That's a pretty penny for those things, but quality would be much better. I just don't know how I feel about cutting steering lines and break lines. Seems kinda sketchy to me.
  3. Feb 1, 2018 at 8:59 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Are you gonna off-road any Tyler?
  4. Feb 1, 2018 at 9:12 AM
    SullyMoto19
    Tyler
    Houston, Texas
    I do the occasional beach trips and hit the dunes out there. but nothing crazy. I wont know until I find out how the new gears affect power.
  5. Feb 1, 2018 at 9:31 AM
    rons23
    Ron
    Kill Devil Hills
    Full coilover gets my vote, better ride on/off. Good luck:thumbsup:
    trayday likes this.
  6. Feb 1, 2018 at 9:33 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    My little tundra on 35.4" with a 3"/2" lift next to my friend Ken's F250 on 38" tires.
    CJ21 and SullyMoto19[OP] like this.
  7. Feb 1, 2018 at 10:04 AM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    :annoyed:See that is what I am talking about... What a jerk...
    Vector W8[QUOTED] likes this.
  8. Feb 1, 2018 at 10:28 AM
    SuaveRC
    SuaveRC New Member
    Don't still need to replace the shocks as well? Or can you get away with just the blocks? As far as bigger tires, I think the biggest I would go is 35". Right now I have the TASK off-road package, blacked out with 285 55 R20. So I would like a 0 offset. Once these tires wear out (just bought a 2018 crewmax) , I may change the tires.
  9. Feb 1, 2018 at 10:39 AM
    SullyMoto19
    Tyler
    Houston, Texas
    you don't have to adjust any suspension parts for a body lift. the only thing a body lift does is lifts the cab from the frame. the frame and suspension will remain the same.
  10. Feb 1, 2018 at 10:44 AM
    SullyMoto19
    Tyler
    Houston, Texas
    so damn torn.. if I went with adjustable coils up front, what would I need to do to level out the back?
  11. Feb 1, 2018 at 1:13 PM
    SuaveRC
    SuaveRC New Member
    So when is it necessary to replace shocks or get coilovers and etc? Someone told me I should get a 4" lift and get the full kit. I won't do any off-roading, I have the front sensor, so I have to be careful about leveling it up front, I just want a lifted look for s slightly wider tire and not lose any smoothness when I'm driving
  12. Feb 1, 2018 at 1:34 PM
    SullyMoto19
    Tyler
    Houston, Texas
    https://www.tundras.com/threads/guide-different-types-of-lifts.546/
    if youre looking at lift ideas, check out this link. its basically a discussion on all the types of lifts. definitely helped me out. but this will be able to answer a lot of your questions. im just a jackass with a jacked up truck lol
  13. Feb 1, 2018 at 3:53 PM
    SuaveRC
    SuaveRC New Member
    Do you have any side pics of your truck??
    And man that F250 makes your truck looks like it's stock. Lol
  14. Feb 1, 2018 at 6:02 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    You might be able to clear 38's with an aftermarket bumper. Steers clear of the body lift. UCA's and a good set of coilover's should make your daily and off road driving more comfortable and look nice as well.
  15. Feb 1, 2018 at 7:21 PM
    SullyMoto19
    Tyler
    Houston, Texas
    I was thinking about the bumper.. but I know I'll have to chop the frame a little. Won't hurt, but I do a bunch of u-turns, so I like turning at full tilt
  16. Feb 1, 2018 at 9:30 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Some trucks need bumper lifts and steering shaft extension.
  17. Feb 1, 2018 at 9:30 PM
    Tracker
    Tracker New Member
    Shane
    My last truck with a 3 inch body lift needed longer brake lines.
  18. Feb 2, 2018 at 2:35 AM
    rons23
    Ron
    Kill Devil Hills
    Tyler when you figure. Out what coilover and how high, then you can see what you need for the rear. You have springs, shackles, blocks, and airbags if your going that far. I am @ top setting on my 6112's with a 1" tapered block. This set up left me with some rake, which I wanted. Obviously shackles are a better choice, but a 1" block serves the purpose. :thumbsup:
  19. Feb 2, 2018 at 6:28 AM
    #49
    SullyMoto19
    Tyler
    Houston, Texas
    yeah after reading over the install, a lot of lines have to be cut. I don't know how comfortable i am with chopping/ extending lines on a brand new truck..
  20. Feb 2, 2018 at 6:29 AM
    #50
    SullyMoto19
    Tyler
    Houston, Texas
    im going to talk to a buddy of mine about a coils/UCAs setup. hopefully i get a decent price. we shall seeeee haha
    is the top setting on you 6112s stiff? i heard cranking them all the way up can stiffen the ride a little
  21. Feb 2, 2018 at 6:38 AM
    #51
    rons23
    Ron
    Kill Devil Hills
    I haven't noticed. What I have noticed is I can barely feel anything going over bumps , holes, etc. I tell ya what is really nice is that big ass Nitto Ridge Grappled plowing through standing water with no steering wheel shake. My take on setting @ the top is I don't off-road with this Tundra and would rather get the height increase via max setting vs setting @ 1.9 like most guy's are doing, then putting shims on top. My mechanic said a shim is fine to correct a lean, but wouldn't recommend stacking shims to get more height. Keep us posted Tyler:thumbsup:
  22. Feb 2, 2018 at 12:26 PM
    #52
    SullyMoto19
    Tyler
    Houston, Texas
    update: most likely goin the coilover route. just got a quote for Fox adjustable coilovers, parts and install $1050. I still will need some UCAs and the ones ive found don't look very cheap.
    trayday likes this.
  23. Feb 2, 2018 at 12:47 PM
    #53
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Is that with reservoirs?
  24. Feb 2, 2018 at 12:57 PM
    #54
    SullyMoto19
    Tyler
    Houston, Texas
    @trayday
    no reservoirs.
    pretty stock price that ive seen.. are the reservoirs even necessary? not even sure of their function
  25. Feb 2, 2018 at 1:35 PM
    #55
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    The unit will hold more oil to prevent overheating, so the shock will work as intended for longer when putting to use and should require less service intervals. Plus they look cool.
  26. Feb 2, 2018 at 1:39 PM
    #56
    SullyMoto19
    Tyler
    Houston, Texas
    yeah they look cool as hell. but honestly, im not an offroad guy, so I don't think Ill need em. just going for some extra lift up front
  27. Feb 2, 2018 at 7:41 PM
    #57
    SuaveRC
    SuaveRC New Member
    I have the 2018 Tundra with the new collision safety feature. If I went with a 3" lift, what would I need in the back so I don't throw it off? From what I understand, it will mess the system up, so I'm not sure at what degree the rear needs to be higher than the front.
  28. Feb 6, 2018 at 9:14 AM
    #58
    Vector W8
    Yes Here are a couple. Since taking these photos I have added the 2018 Toyota Black LED head lights
    SullyMoto19[OP] likes this.
  29. Feb 13, 2019 at 6:16 PM
    #59
    handstriker909
    handstriker909 New Member
    SupaCharged Inferno 4x4 Tundra
    I have an 8in lift and thinking of throwing 3 inch body lift as well.
    TXRailRoadBandit73 likes this.
