Anyone running a Softopper?
Discussion in 'Tonneau Covers, Caps and Shells' started by JackWagon, May 23, 2018.
  1. Jan 31, 2024 at 6:33 AM
    #361
    king.cong.1119
    king.cong.1119 New Member
    I have that exact setup, xtrusion overland rack, decked system, softopper, they work well, although I have not removed the softopper with the decked drawer in there yet, I don't see it being a problem.
    CMTX 1794[QUOTED] likes this.
  2. Jan 31, 2024 at 12:59 PM
    #362
    CMTX 1794
    CMTX 1794 New Member
    Sheb
    2018 Silver 1794 edition 4x4
    Soon
    I’ll take a look at FasTop also. Thank you!
    outstanding. Thank you for the input. Do you happen to have pics you’ve posted? Would love to see INSIDE the set up as well. Having never seen one in person, I’m just struggling to wrap my head around how to best set it up for my wants/needs. Really appreciate your feedback!
  3. Jan 31, 2024 at 3:22 PM
    #363
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    The proper clamps from Softopper arrived and I got the top installed properly. The rails still twist inward a little, but nothing like before. I was planning on using the velcro and flexible magnet method to attach it to the tailgate, but with a bed lined tailgate the magnets were not strong enough to stick. Scouring the Tacoma forum I found a different approach that looks like it will work well. I ordered some high power magnets, cut a slit in the velcro, and slipped them in from the end. Easy, and they seem to do the trick. I need to order a few more as I purchased a 20 pack and it wasn't enough to span the full length. These are the magnets:
    https://www.amazon.com/dp/B078KTLWQ9?ref=ppx_yo2ov_dt_b_product_details&th=1
    koditten likes this.
  4. Jan 31, 2024 at 4:06 PM
    #364
    Just curious, what's that?
  5. Jan 31, 2024 at 5:19 PM
    #365
    kbahus
    kbahus New Member
    MI
    It's a tailgate from a Devolro Tundra, purchased as a replacement for my very dented one. I had hoped to be able to remove the badge, but they bed lined over it so it is bare underneath the badge. Not sure what to do with it as it is quite an eye sore. They also filled in the original Tundra emblem which is lame. Devolro appears to be a company that makes some monstrously ugly trucks.
  6. Jan 31, 2024 at 6:32 PM
    #366
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    I had to Google this company. A 2019 Tundra for $110,000…
    https://www.devolro.com/trucks-for-sale/2019-toyota-tundra-for-sale
  7. Feb 1, 2024 at 6:45 AM
    #367
    king.cong.1119
    Hi, I have posted a short video of my camping setup with it, here it is.
    https://www.youtube.com/shorts/07qSGmVe-Xk
    Hope it helps showing you what it looks like
    CMTX 1794[QUOTED] and koditten like this.
  8. Feb 1, 2024 at 8:25 AM
    #368
    CMTX 1794
    Sheb
    Soon
    Great set up. I miss my kiddos being that young :/
    thanks!!
  9. Feb 1, 2024 at 12:34 PM
    #369
    Kerbouchard!
    Kerbouchard! New Member
    Denver
    All the components work together as mentioned above. The XO rack doesn't allow the softtopper to be folded down without removing the pins and doing some manual adjustments. I haven't pulled the trigger on one for that reason. The UpTop overland softtopper racks claim to enable full functionality of the softopper because you can raise the top load bars a little higher than other brands.
  10. Feb 1, 2024 at 6:56 PM
    #370
    CMTX 1794
    Sheb
    Soon
    Very intriguing. Thank you. Checking those out now as well. Quite a few options to weigh.
  11. Feb 1, 2024 at 7:32 PM
    #371
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    Had mine for about 5 years now, it's great! I always have it up during camping season and usually strip down during the winter unless I'm covering for road trips and travel
  12. Feb 5, 2024 at 7:53 PM
    #372
    MTBTANDRA801
    MTBTANDRA801 New Member
    Ben
    2018 Limited DC
    King suspension, TRD Exhaust
    And the magnets just attach to bed itself?
  13. Feb 6, 2024 at 3:37 AM
    #373
    kbahus
    kbahus New Member
    MI
    Yes the magnets stick directly to the tailgate, the soft side velcro is against the paint. Works pretty well so far. I ended up adding some magnets to the front flap as well since I had some leftover.
  14. Feb 6, 2024 at 4:21 AM
    #374
    koditten
    Kirk
    Midland of the Mitten
    Are the 3 rd gen tailgates still iron?
    I'd hate to find out that the tailgate is aluminium. The magnets wouldn't work.
  15. Feb 6, 2024 at 8:54 PM
    #375
    MTBTANDRA801
    Ben
    2018 Limited DC
    I see, so does the rough side of the velcro with the magnets in it just stick to the softopper flap? or did you have to sew it/glue it?
  16. Feb 6, 2024 at 9:29 PM
    #376
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    '16 Super White CrewMax
    Alternatively you can do what I did and others I've seen and buy a strip of 1" velcro and attach the hook side to the topper flap - then use a 1" magnetic strip with adhesive back. I also put a 4" piece of 3m clear on the tailgate and it works flawlessly.
    https://www.amazon.com/gp/product/B08GSHFZYP?ie=UTF8&th=1
    https://www.amazon.com/gp/product/B078SZLKRC?ie=UTF8
  17. Feb 7, 2024 at 3:45 AM
    #377
    kbahus
    kbahus New Member
    MI
    I cut a little slit in the Velcro with an Xacto knife and slid the magnets between the Velcro and the outer vinyl skin of the back window flap. They stick to themselves end to end via magnetism and made a nice continuous magnetic flap, semi-flexible too. There is no rough side of the Velcro, the only thing to purchase is the magnets. These magnets are much stronger than the tape stuff too. I originally purchased a roll of magnetic tape and it wasn't strong enough to magnetize to my tailgate (bed lined).
  18. Feb 7, 2024 at 11:16 PM
    MTBTANDRA801
    Ben
    2018 Limited DC
    And when you say cut a slit in the “Velcro” you are talking about the Velcro that comes already pre attached to the soft topper flap?
  19. Feb 8, 2024 at 4:09 AM
    #379
    kbahus
    kbahus New Member
    MI
    Yep you got it, in the picture I am in the process of sliding the magnets in the slit. I pushed a magnet about halfway in then connected the next. I made the slit up a little from the bottom so the magnets would not slide back out the slit, but the velcro self-healed anyways and I am confident they will not come out. I would say you still might want to add paint protection film to the tailgate to keep it from getting scratch up over time.
  20. Feb 25, 2024 at 1:20 PM
    #380
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    I just ordered those magnets for mine. Thanks for the idea.
    kbahus[QUOTED] likes this.
  21. Mar 6, 2024 at 10:29 AM
    #381
    gregers05
    gregers05 New Member
    Has anyone looked at a WildTop topper?
    I really want a softtopper because I still use my bed to haul stuff, but would also like to be able t mount an awning as well as I camp out of my truck often. I really dont want to do the over the topper rack. WildTop seems to do almost what I need, but does not fold up.
  22. Mar 8, 2024 at 5:43 AM
    #382
    joe_from_iowa
    joe_from_iowa New Member
    Iowa
    2021 Tundra Double Cab SX
    Peeled off the SX stickers from the bed sides. Tyger running boards. A.R.E. DCU topper
    Pillslinger likes this.
  23. Mar 10, 2024 at 5:03 PM
    #383
    Retroboy1989
    Northern Utah
  24. Mar 11, 2024 at 12:18 AM
    #384
    MTBTANDRA801
    Ben
    2018 Limited DC
    Do you have to use Datin Fab cage offered on Soft toppers website? Or are there other compatible cages that can be used around the soft topper?
  25. Mar 11, 2024 at 2:43 AM
    #385
    mustangr2
    mustangr2 New Member
    There are a couple of racks that compatible with soft topper.
  26. Mar 11, 2024 at 9:44 AM
    #386
    MTBTANDRA801
    Ben
    2018 Limited DC
    Any recommendations?
  27. Mar 11, 2024 at 1:47 PM
    #387
    mustangr2
  28. Mar 11, 2024 at 7:46 PM
    #388
    MTBTANDRA801
    Ben
    2018 Limited DC
    As long as you have a 2022 or newer than alll your points are valid, i looked into those but they only make them for third gens
  29. Mar 12, 2024 at 5:20 AM
    #389
    KB Voodoo
    KB Voodoo New Member
    Chad
    2017 Tundra Pro Crewmax, Cement
    Many KB Voodoo Fabrications accessories!!
    We have an excellent one, soon to be released.
    Rc23, Pillslinger and DannyD303 like this.
  30. Mar 20, 2024 at 1:42 PM
    #390
    PAlittlematty
    PAlittlematty New Member
    Central PA
    2021 CrewMax TRD OR
    Is your top tan or gray? I can’t tell in the picture
