Anyone use Shell Rotella oil?
Discussion in 'General Tundra Discussion' started by db52282, Nov 1, 2019.
  1. Nov 23, 2019 at 7:23 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    At Autozone? I was in a hurry so I didn't check for the 5quart jugs. Hell, the 5 quart jugs of almost all of the synthetic oils are normally $22-$25 at walmart.
  2. Nov 24, 2019 at 1:45 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    Full synthetic (blue jug) is all I ever use in my motorcycle's along with automotive filters. Never had an issue.
    -Jason
  3. Nov 24, 2019 at 4:50 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Yep, the jugs are $10 and singles are $2. It's all marked down. One autozone had em at $4/qt and the rack was still full of every grade oil. It's a slow seller. I raided the 2nd autozone at $2/qt and the clerk looked at me as if I was crazy. I left all the 30wts as I no need longer need them. Just made out with all the 20wts.
  4. Nov 24, 2019 at 9:18 AM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    autozone has some valvoline 0-20 synthetic for $10 -5qts. On clearance
    no rebate but a really good price
    Hbjeff likes this.
  5. Nov 24, 2019 at 4:13 PM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    I have used Mobil 1 for the last 700,000 miles over the last 10 years in whatever 3 vehicles we own. Never had a bit of problems. I have been using the 0w-20 Advanced Fuel Economy in our Tundra and 4Runner. These engines are pretty loud and rattley with the Mobil 1, but would probably never experience a problem with that oil. I used Rotella Gas Truck 0w-20 for the last change in my Tundra and it completely quieted down the upper valve train noise. I will be using the Rotella Gas Truck going forward in my Tundra and 4Runner.
    in my opinion, the Rotella Gas Truck is probably on the "thicker" side for a 0w-20, and Mobil 1 Advanced Fuel Economy is in the thinner side for a 0w-20.
    georgiey22 and Luckydog like this.
  6. Nov 25, 2019 at 11:15 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    There's an all state autozone coupon for $7 off $30. Google for it. Makes the clearance + rebate even more of a no brainer. I have 60 qts in the garage. Be good for a couple years.
  7. Nov 25, 2019 at 4:40 PM
    Jeffro22
    Jeffro22 New Member
    I got a good 5year supply
    Of oil. Not sure if I need anymore
    Zebruaj likes this.
  8. Nov 25, 2019 at 7:45 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Dammit y'all are making me want to go buy more. It's too cheap not to.
  9. Nov 26, 2019 at 4:41 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Doooo iittttt!
    The wife told me to stop. and I ran out of trust worthy addresses to use for the rebates.
  10. Nov 27, 2019 at 9:20 AM
    Jeffro22
    Jeffro22 New Member
    I know, I ended up picking up a mixture of another 30 qts yesterday. Hard to pass up on that deal
    they still had some valvoline 0-20 synthetic for $10 /5 qts that I passed on . I am probably good for the next 5 years or would have grabbed all the valvoline also
  11. Nov 28, 2019 at 11:26 AM
    ifishinxs
    ifishinxs New Member
    Bob
    Cedar city, Utah
    2015 Tundra limited
    None! I tow a boat weekly
    Bought 32 quarts yesterday at Autozone. I bought every qt they had. I even brought my own box to put it in.
  12. Dec 11, 2019 at 12:08 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    My score. Just checked and my 2 extra rebate submissions just mailed out. So all this was free!!
    georgiey22 and Black Wolf like this.
  13. Dec 12, 2019 at 7:13 PM
    1BlinkGone
    1BlinkGone New Member
    Oil hoarder! :rofl:
    Great deal!
    Zebruaj[QUOTED] likes this.
  14. Dec 22, 2019 at 5:50 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    What benefit does this oil have over Mobil 1 Truck & SUV oil?
    georgiey22 likes this.
  15. Dec 22, 2019 at 5:51 AM
    Jeffro22
    Jeffro22 New Member
    The biggest benefit for me is the rotella was free! IMO- Almost any of the oils today that meet correct spec are good to use
  16. Dec 22, 2019 at 8:50 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
  17. Dec 26, 2019 at 9:31 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Best to approach this scientifically. Due and oil and filter change. Use oil #1 (your call). At the recommended oil change interval drain the oil and send it out for analysis. I use Long Island Analytical Labs, other use Blackstone. Use the second oil of your choosing. replace the oil filter with the same type. At the recommended oil change interval drain the oil and send it out for analysis. Review results. Not only will this let you know if you have engine issues, but if the oil results are the same, go with what is cheapest oil in your study.
    Pudge likes this.
  18. Dec 26, 2019 at 7:27 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    I just cleaned both of my local 2 AutoZones out of all that they had left, 33 quarts worth @$2 a quart. Rebate time! Sounds dumb but I won’t be using in the truck, I run Schaeffer’s. Will use in my wife’s car....it’s still good oil!
  19. Dec 27, 2019 at 6:32 AM
    #49
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I've used Rotella T6 0-40 for years on my polaris (makes those 500s purr) and other small engines. Since its intended for the Dirtiest of engines, diesels, it cleans out carbon and engine internals rather well.
    If you're concerned about affects on cats you may want to steer clear on those engines - though the label says it is intended for All engines.
    Luck and enjoy those Toyotas. : ^ )))
    Mountun Goat[QUOTED] likes this.
  20. Dec 27, 2019 at 8:40 AM
    #50
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    There's another RGT rebate scheduled to start 01/2020 after the 2019 one expires. Looks like Shell is hurting trying to get this stuff off retailer's shelves.
  21. Dec 30, 2019 at 1:24 PM
    #51
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    Just a heads up. Tractor Supply has the 5qt jugs on sale for $18 each till the end of February.
    Rob's Inferno and db52282[OP] like this.
  22. Jan 4, 2020 at 7:43 AM
    #52
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Shell just pushed out another $2/qt rebate for 2020 for this Gas Truck oil. My autozone still had clearance jugs on the shelf. And you can Google for the autozone allstate insurance $7 off $30 purchase.
    Basically getting paid to take this stuff.
    thearborbarber and Pudge like this.
  23. Jan 5, 2020 at 11:36 AM
    #53
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Thanks for the heads up .Ill be stopping by there for more.
  24. Jan 5, 2020 at 11:44 AM
    #54
    BarcelonaSX
    BarcelonaSX New Member
    2019 Barcelona red SR5 SX
    Bilstein 6112 front coilovers @2.5”. Bilstein 5100 rear shocks with toytec shackles @1”. 20x9. Xd grenade wheels with 295/60/20 ridge grapplers. Tinted windows. Gibson single side dual exhaust.
    Just did my first oil change at 5500 miles. Used rotella.
  25. Jan 5, 2020 at 11:56 AM
    #55
    lakenorcan
    lakenorcan New Member
    jon
    northeastern Pa
    2016 4x4 DC limited
    Leer cap, weathertech vent visors, & floor mats, interior LEDs, drone remote start, front camera, tinted glass, trd rear sway bar, Thule cross bars, morimoto hid headlights, morimoto led fog lights
    I need suggestions on where to get deals on oil filters now.
  26. Jan 5, 2020 at 12:34 PM
    #56
    Pudge
    CT
    If you have a toyota dealer nearby then just get them there. They are cheap and better than others from an auto parts store
    WILLINH likes this.
  27. Jan 5, 2020 at 3:35 PM
    #57
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I buy them in bulk off Amazon. Sometimes you'll find them packaged with the drain plug crush washer too.
  28. Jan 16, 2020 at 9:10 AM
    #58
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    For those who are partaking, you can also register for Shell Rewards too and redeem your receipts for points. I've been using T6 for other stuff and have been able to redeem Amazon gift cards. And I also won a free mini grill from their summer sweepstakes.
    (Just submit your receipt after you get your $2/qt rebate check in hand. The call center seems to get both rewards points and rebate dollars mixed up).
    Pudge likes this.
  29. Jan 16, 2020 at 10:11 AM
    #59
    TheBeast The Beach
    costco just released their own Kirkland brand oil. Bottle looks strangely similar to Shell oil..;) ymmv
  30. Jan 16, 2020 at 11:32 AM
    #60
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    You mean they released a rebottled WPP oil. Great 2fer pricing this week if you need it.
    TheBeast[QUOTED] likes this.
